Overdrive power loss & code..
Postby AnimeImpact [OP] » June 4th 2009, 4:14am
I have a 96 RWD with 4L60E tranny. Has been doing great up until the other day. First thing I noticed was at highway speeds (65 - 75mph) was loss of my A/C (very noticeable in Texas) until I let off my throttle. Then it would come back. I don't know it is connected to what happened next though. While trying to get on the freeway I pushed the accelerator down and when I did the tranny instead of going into OD it started to slip. Top speed just under 60mph. Going over a local high bridge I got a similar reaction. I got a check engine code of P1870. The next day I changed my fluid and filter. Test drove on local roads with OK results. There was a little jerking every now and then. I rechecked fluid levels and proceeded with highway test. Same results as before filter and fluid change. Does anyone have any ideas before heading to the transmission shop?
AnimeImpact
Years of Membership: AnimeImpact has been a member for 11 full yearsAnimeImpact has been a member for 11 full yearsAnimeImpact has been a member for 11 full yearsAnimeImpact has been a member for 11 full yearsAnimeImpact has been a member for 11 full yearsAnimeImpact has been a member for 11 full yearsAnimeImpact has been a member for 11 full yearsAnimeImpact has been a member for 11 full yearsAnimeImpact has been a member for 11 full yearsAnimeImpact has been a member for 11 full yearsAnimeImpact has been a member for 11 full years
Alias (AKA): Animeimpact
  • P0894 Code
    by Lowcountry » September 16th 2020, 4:52am in Automatic
    Last post by Lowcountry View the latest post
    September 18th 2020, 7:40pm
    94
    September 21st 2020, 3:37am
Re: Overdrive power loss & code..
Postby astro355 » June 4th 2009, 3:56pm
Hello,
for the A/C problem, did you check the serpentine belt? Was there in loss in power from the engine or was the power loss restricted to only the a/c?
And when you had the problem with the OD slipping, was the engine revving up also? When you changed the fluid, how did it look and smell? Are there any leaks regarding the transmission?
astro355
Firing on 4 Cylinders (L6)
Extra Info: 355 V8 700R4
Postby AnimeImpact [OP] » June 4th 2009, 4:21pm
Power loss only to A/C. Can't find any leaks. The fluid was dark red but not quite burnt brown when I changed it.
AnimeImpact
Postby astro355 » June 4th 2009, 11:54pm
astro355 wrote:Hello,
astro355
Postby AnimeImpact [OP] » June 5th 2009, 7:33pm
Belt is OK and the engine did rev up.
AnimeImpact
Postby astro355 » June 5th 2009, 7:42pm
With your description of how the a/c worked and didn't work (while on the gas), it would either be the serpentine belt or the tensioner.
The slipping in the trans good just be caused by old trans fluid or a low fluid level. My trans in particular likes to be a pint over the full line otherwise it doesn't work quite right. Your problem could be other things but I don't have enough info.
astro355
Return to Automatic
It is currently September 21st 2020, 3:37am
Automatic Forum
Chunkstyle
in Automatic
Date: Aug 11 '20
Time: 8:25pm
in Automatic
Date: Jul 26 '20
Time: 1:22pm
Olivier02
in Automatic
Date: Jun 13 '20
Time: 9:22pm
SoccerMom4x4SoccerMom4x4 is online!
in Automatic
Date: Jun 12 '20
Time: 2:50pm
in Automatic
Date: Jun 11 '20
Time: 2:12pm
