95 Astro 4.3 v6 Cargo Tranny Issue Questions
Postby ahillworks [OP] » June 6th 2009, 8:56pm
If you can help great if not I understand. Went home for lunch parked the van in the drive way which is on a hill. Went to go back to work van started no issue. But the van will not go into Reverse - Over Drive - Drive - 2 or 1 it will go into park and neatrual no issues but other than that nothing. Any idea what it may be? Thanks.
ahillworks
Years of Membership: ahillworks has been a member for 12 full yearsahillworks has been a member for 12 full yearsahillworks has been a member for 12 full yearsahillworks has been a member for 12 full yearsahillworks has been a member for 12 full yearsahillworks has been a member for 12 full yearsahillworks has been a member for 12 full yearsahillworks has been a member for 12 full yearsahillworks has been a member for 12 full yearsahillworks has been a member for 12 full yearsahillworks has been a member for 12 full yearsahillworks has been a member for 12 full years
  • V8 4l60e in v6 van?
    by hckynut » July 25th 2021, 12:33am in Automatic
    Last post by hckynut View the latest post
  • Can I switch to deep tranny pan from shallow?
    by the_bruce » May 2nd 2021, 10:31pm in Automatic
    Last post by the_bruce View the latest post
    July 2nd 2021, 1:51am
    August 5th 2021, 1:26am
Re: 95 Astro 4.3 v6 Cargo Tranny Issue Questions
Postby gtkane » June 7th 2009, 1:43pm
The fluid level may be low.
Being parked on an incline, the fluid may be at one end of the pan and is not getting sucked up.
It would be best to push the van to level ground to check the level to avoid overfilling.
User album #4...check it out!
gtkane
Alias (AKA): Astruck
Extra Info: nasty 4.3
Postby msgale » June 7th 2009, 7:01pm
are you sure the trans is actualy shifing from park to neutral?
( you can tell, bcs it will start rolling in neutral, since you are on a hill)
it may be that there is no shifting at all,in which case, thinkof 2 possibilities:
1. linkage disconnected
2. the pressure of the car weight pushing on the parking pawl in the trans is too strong, and the linkage broke because of that.
msgale
Years of Membership: msgale has been a member for 12 full yearsmsgale has been a member for 12 full yearsmsgale has been a member for 12 full yearsmsgale has been a member for 12 full yearsmsgale has been a member for 12 full yearsmsgale has been a member for 12 full yearsmsgale has been a member for 12 full yearsmsgale has been a member for 12 full yearsmsgale has been a member for 12 full yearsmsgale has been a member for 12 full yearsmsgale has been a member for 12 full yearsmsgale has been a member for 12 full years
Return to Automatic
It is currently August 5th 2021, 1:26am
Automatic Forum
fryaeggontheground
in Automatic
Date: May 05 '21
Time: 5:30pm
OldSchoolNoe
in Automatic
Date: May 03 '21
Time: 7:56pm
Bikley
in Automatic
Date: Mar 29 '21
Time: 5:42am
95AstroLT
in Automatic
Comments: 19
Date: Mar 06 '21
Time: 3:49am
95AstroLT
in Automatic
Comments: 19
Date: Mar 06 '21
Time: 3:42am
