shifter wont move
shifter wont move
Postby SIGHTS AND SOUNDS [OP] » July 28th 2009, 6:15pm
Ok , i just walked out to get in my van. started it up and tried to shift into reverse. nothing. i put almost all my weight into it and it wont budge. i rocked the van back and forth thinking it was stuck but nothing. my driveway has a very minumal slope but i have noticed lately it has been tough to shift out of park. now i am stuck home trying to think of what is wrong. i guess i need to see if the linkage cable is still there or at least not kinked or something. If anyone has any suggestions please help me out plzzzzzzzz kind of need to find a job lol :banghead:
96 chevy astro ,burnt orange, 20's, xenon body kit ...looking for cat grill...more to come
SIGHTS AND SOUNDS
Years of Membership: SIGHTS AND SOUNDS has been a member for 11 full yearsSIGHTS AND SOUNDS has been a member for 11 full yearsSIGHTS AND SOUNDS has been a member for 11 full yearsSIGHTS AND SOUNDS has been a member for 11 full yearsSIGHTS AND SOUNDS has been a member for 11 full yearsSIGHTS AND SOUNDS has been a member for 11 full yearsSIGHTS AND SOUNDS has been a member for 11 full yearsSIGHTS AND SOUNDS has been a member for 11 full yearsSIGHTS AND SOUNDS has been a member for 11 full yearsSIGHTS AND SOUNDS has been a member for 11 full yearsSIGHTS AND SOUNDS has been a member for 11 full years
Topics: 7
  • number 2 on automatic transmission shifter
    by Olivier02 » June 13th 2020, 9:22pm in Automatic
    Last post by SportsBoy View the latest post
    June 14th 2020, 12:51am
    39
    September 23rd 2020, 5:40pm
Re: shifter wont move
Postby Leeann_93 » July 28th 2009, 6:54pm
Do you put the parking brake on before you take your foot off the brake when you park?
Sounds to me like the parking pawl is stuck in the tranny...
Postby SIGHTS AND SOUNDS [OP] » July 28th 2009, 6:57pm
Leeann_93 wrote:Do you put the parking brake on before you take your foot off the brake when you park?
i have been recently but i didnt do it this time. i noticed when i do put the parking brake it has been easier. guess i am gonna have to reseaqrch where the parking pawl is .
SIGHTS AND SOUNDS
Topics: 7
Postby Leeann_93 » July 28th 2009, 7:01pm
It's in the transmission...
Postby SIGHTS AND SOUNDS [OP] » July 28th 2009, 7:03pm
darn..that means its got to go to the shop.
SIGHTS AND SOUNDS
Topics: 7
Postby xequar » July 28th 2009, 8:27pm
Van's a '96? From '93 and onward, the Astro/Safaris had a safety switch that requires one depress the brake pedal, or else you can't shift from park. The basic idea was to keep little kids from firing up the engine and accidentally shifting into a gear. Most GMs had these switches from the early '90s onward, and it was pretty common for them to fail.
Try this: Get in and put your foot on the brake. Turn on the key (to the Run position), but do NOT start the engine. Try shifting to Neutral.
If you can shift it to neutral, that means that the safety switch (can't remember what it's called now...) has gone bad. The good news is that you can start the van in Neutral and shift into whatever gear once it's running.
xequar
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: xequar has been a member for 11 full yearsxequar has been a member for 11 full yearsxequar has been a member for 11 full yearsxequar has been a member for 11 full yearsxequar has been a member for 11 full yearsxequar has been a member for 11 full yearsxequar has been a member for 11 full yearsxequar has been a member for 11 full yearsxequar has been a member for 11 full yearsxequar has been a member for 11 full yearsxequar has been a member for 11 full years
Extra Info: Formerly 4.3L XT
Postby SIGHTS AND SOUNDS [OP] » July 28th 2009, 8:34pm
xequar wrote:Van's a '96? From '93 and onward, the Astro/Safaris had a safety switch that requires one depress the brake pedal, or else you can't shift from park. The basic idea was to keep little kids from firing up the engine and accidentally shifting into a gear. Most GMs had these switches from the early '90s onward, and it was pretty common for them to fail.
i have tried the whole brake thing. just got off the phone with my local chevy dearler ...go figure its called Jeff Gordon Chevy, and they said its not the pawl switch. they said its probally electrical, something with that brake switch...who the eff knows now. i will have to try and find the brake switch.
ty for the help. :ty:
SIGHTS AND SOUNDS
Topics: 7
Postby xequar » July 28th 2009, 9:10pm
Even with the engine off, but the key on, you still can't shift out of Park? Hmm... On all the GMs I've ever experienced that safety switch failure, as long as the engine wasn't running, you could shift from park into Neutral, start the engine, then drive away. I don't know if the switch is a solenoid of some sort or just an electric switch in the 90s GMs, though.
The parking pawl that was mentioned earlier is a physical bit in the transmission. It's a pin that, when you shift into park, mates into a groove on a disk, and it's that force that keeps the vehicle from rolling while it's in Park (when you shift into Park and feel the vehicle roll slightly, that's the pawl slipping into the groove). Forgive me if I'm going over stuff you knew, but I sensed some confusion earlier.
Please, do let us know what you come up with, though, and good luck!
xequar
Fueling (1/2 tank)
Fueling (1/2 tank)
Postby SIGHTS AND SOUNDS [OP] » July 28th 2009, 9:27pm
ok i got brake lights so my brake switch is good from what i was told. i hear the seloniod clicking too after i took all the plastics off the column ,,,,btw anyone have those pieces for sale.....dont ask..lmao but i cant think of anything else it could be
SIGHTS AND SOUNDS
Topics: 7
Postby SIGHTS AND SOUNDS [OP] » July 30th 2009, 12:01am
ok towed the van to a shop and it was the parking rod inside the tranny. it was shot. only ran me $183. not too bad. i was expecting the worse. thank you for everyone and their input.
SIGHTS AND SOUNDS
Topics: 7
Postby Leeann_93 » July 30th 2009, 12:19am
SIGHTS AND SOUNDS wrote:ok towed the van to a shop and it was the parking rod inside the tranny. it was shot. only ran me $183. not too bad. i was expecting the worse. thank you for everyone and their input.
not too bad from a shop, considering it's inside the tranny.
Postby xequar » July 30th 2009, 12:31am
Thanks for the info, and glad it worked out for you!
xequar
Fueling (1/2 tank)
Fueling (1/2 tank)
Postby SIGHTS AND SOUNDS [OP] » July 30th 2009, 1:43am
tell me bout it. i thought i was gonna have to grab my ankles!!!!! lmao
SIGHTS AND SOUNDS
Topics: 7
Return to Automatic
It is currently September 23rd 2020, 5:40pm
Automatic Forum
Chunkstyle
in Automatic
Date: Aug 11 '20
Time: 8:25pm
MmusicmanMmusicman is online!
in Automatic
Date: Jul 26 '20
Time: 1:22pm
Olivier02
in Automatic
Date: Jun 13 '20
Time: 9:22pm
SoccerMom4x4
in Automatic
Date: Jun 12 '20
Time: 2:50pm
SoccerMom4x4
in Automatic
Date: Jun 11 '20
Time: 2:12pm
