isnt there a bolt in 2 speed transfercase upgrade?
Postby mattds [OP] » February 6th 2014, 5:00pm
Hi there,
i'm more into jeep than i am these vans, but as my jeep has now become a little too wild for regular usage, i tend to use the van for poor weather, and although I am thrilled (seriously, i can drive though about 2 feet of snow no problem, and it's very stable) i was wondering about this upgrade (mainly to get the 4 low). Can't we just swap in one of the electronic transfercases from a Blazer? i've done a bit of searching and i'm still a little lost.
I don't mind shortening the drive shafts, but shouldn't in input splines be the same, etc?
mattds
Years of Membership: mattds has been a member for 7 full yearsmattds has been a member for 7 full yearsmattds has been a member for 7 full yearsmattds has been a member for 7 full yearsmattds has been a member for 7 full yearsmattds has been a member for 7 full yearsmattds has been a member for 7 full years
Topics: 12
Alias (AKA): Matthew
Extra Info: awd cargo 3.42 g80
Re: isnt there a bolt in 2 speed transfercase upgrade?
Postby redfury » February 8th 2014, 2:55am
It's a direct fit. The real work is putting in the system that disconnects the front axle. You don't have to, but you lose your shift on the fly capability. I have a 4wd transfer case in my van. The real issue is the front drive shaft, whether it's a splined shaft or bolt on style, that's the only major mechanical thing I saw that would be a fitment issue. Beyond that, it's a matter of 3 or 4 button style. 3 button is easy for wiring, but the 4 button style would probably require extra work to figure out the auto 4wd mode...you'd have to have a 99 or newer AWD van in order to have the sensors required to make it work AFAIK.
redfury
Firing on 8 Cylinders (L3)
Topics: 53
Images: 13
Extra Info: LT 5.7L 4wd
Postby gavio » February 8th 2014, 5:25am
I don't have anything beyond basic wrenching skills, and I just put a np233 case from a 2000 Blazer into my 04 Safari, and it really did just bolt in, no driveshaft mods or anything else - speedo works, no CEL etc. I haven't wired it up yet, but will soon, the info is online from folks who've done it before..... I haven't seen yet where anybody documented a swap of the np236 case, which is the 4 button kind, though many have talked about how cool it would be. Also a number of folks have converted the np233 to manual shift, but that requires some fabbing skills as there isn't a bolt in way to do that part, far as I know....
That said, I have seen where some folks have had to notch crossmember to fit the front driveshaft.... And all bets are off if you try to swap in the manual shift np241 case, which works for older Astros, but not for later vans....
gavio
Topics: 77
Images: 4
Postby thegreenmachine » February 8th 2014, 6:54pm
The 233 is direct fit for my 03. And it works great.
Sent from AutoGuide.com App
"that looks legit"
95 AWD Safari money pit
thegreenmachine
Firing on 6 Cylinders (L2)
Years of Membership: thegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full years
Topics: 62
Alias (AKA): Shane a lane
Postby bluesea » February 14th 2014, 12:46pm
Is this the same for the Borg Warner in a 1995?
[_] -------- [_]
1995 Astro AWD once Ambulance
bluesea
Years of Membership: bluesea has been a member for 7 full yearsbluesea has been a member for 7 full yearsbluesea has been a member for 7 full yearsbluesea has been a member for 7 full yearsbluesea has been a member for 7 full yearsbluesea has been a member for 7 full yearsbluesea has been a member for 7 full years
Images: 3
Extra Info: 4.3L AWD
Return to Automatic
It is currently January 26th 2021, 10:26pm
Automatic Forum
Youngblood
in Automatic
Date: Jan 15 '21
Time: 1:24am
allenstoltzfus
in Automatic
Date: Jan 14 '21
Time: 7:36pm
runawayjim
in Automatic
Date: Jan 07 '21
Time: 2:09pm
Attached by: SportsBoy
SportsBoy
in Automatic
Date: Jan 05 '21
Time: 11:16pm
Chunkstyle
in Automatic
Date: Aug 11 '20
Time: 8:25pm
