99 AsroLS Flexplate Broken
Postby CougarsLS [OP] » February 19th 2014, 1:00am
Can anyone tell me why my flex plate broke and is there other possible damage related to it braking? Thanks for any help.
CougarsLS
Years of Membership: CougarsLS has been a member for 9 full yearsCougarsLS has been a member for 9 full yearsCougarsLS has been a member for 9 full yearsCougarsLS has been a member for 9 full yearsCougarsLS has been a member for 9 full yearsCougarsLS has been a member for 9 full yearsCougarsLS has been a member for 9 full yearsCougarsLS has been a member for 9 full yearsCougarsLS has been a member for 9 full years
Topics: 18
Extra Info: LS
Re: 99 AsroLS Flexplate Broken
Postby chevymaher » February 19th 2014, 1:08am
Flex plates do that from time to time on alot of different makes and models. They flex it is their job. Makes stress cracks. Imperfection in the metal.
No other damage fix it and it is over.
Topics: 91
Postby CougarsLS [OP] » February 19th 2014, 1:28am
Any brand you would recommended? Upgrades?
CougarsLS
Topics: 18
Extra Info: LS
Postby chevymaher » February 19th 2014, 1:35am
CougarsLS wrote:Any brand you would recommended? Upgrades?
I just use the factory ones. What you had happen is very rare.
Topics: 91
Postby CougarsLS [OP] » February 19th 2014, 1:39am
Really? The van has 168,000 miles on it. Possible abuse? or just my luck?
CougarsLS
Topics: 18
Extra Info: LS
Postby chevymaher » February 19th 2014, 1:40am
Just luck of the draw.
Topics: 91
Postby CougarsLS [OP] » February 19th 2014, 1:45am
Well how about that! I also been hit by lightning why driving my pick up! Thanks for the help.
CougarsLS
Topics: 18
Extra Info: LS
Postby chevymaher » February 19th 2014, 1:49am
Welcome. LeAnn had the same thing. Just replaced it and that was the end of it.
Topics: 91
Postby CougarsLS [OP] » February 19th 2014, 1:57am
Is that a dearer part of can a buy a factory on on line?
CougarsLS
Topics: 18
Extra Info: LS
Postby chevymaher » February 19th 2014, 2:07am
Summit and Jegs will have them. I get next day shipped to my door if it is in stock.
Topics: 91
Postby CougarsLS [OP] » February 19th 2014, 2:12am
Excellent! Thanks again for everything.
CougarsLS
Topics: 18
Extra Info: LS
Postby sunkiss » February 19th 2014, 2:20am
It brakes from stress and it made of junk metals.and it make alot of noise but it dosen't hurt anything most of the time
sunkiss
Years of Membership: sunkiss has been a member for 7 full yearssunkiss has been a member for 7 full yearssunkiss has been a member for 7 full yearssunkiss has been a member for 7 full yearssunkiss has been a member for 7 full yearssunkiss has been a member for 7 full yearssunkiss has been a member for 7 full years
Van Model Year: 1996
Extra Info: 4.6 awd
Postby CougarsLS [OP] » February 19th 2014, 3:53am
Just my luck it damaged the starter but on a positive note I now have a new starter!
CougarsLS
Topics: 18
Extra Info: LS
Postby WoodButcher » February 19th 2014, 10:17pm
Flexplate broke?, :confused:
lightning strike? :o
:think:
Stand over there, willya? :?
Waayyy over there....
:rofl:
WoodButcher
Firing on 5 Cylinders (L6)
Topics: 30
Images: 514
Alias (AKA): Bruce
Extra Info: 5.7L RWD
Postby MmusicmanMmusicman is online! » February 21st 2014, 12:35am
Same happened to me once... flex plate broke. Fairly easy to change... just scoot trans back only far enough to get a wrench or ratchet/socket in. Easy swap. I think I got my replacement from Summit. I'm not convinced that factory stock is better in this case, but certainly more expensive.
It is possible that a minor imbalance of the torque converter. or possibly even a small discrepancy with the mounting tabs, could cause the flex plate to "flex" a little more than typical.
Topics: 73
Images: 59
Postby CougarsLS [OP] » February 21st 2014, 8:45pm
Thanks for the tip. Do you need to remove the exhaust or is there enough room with still on? and can I leave the transmission support on and just unbolt it from the frame?
CougarsLS
Topics: 18
Extra Info: LS
Return to Automatic
It is currently April 13th 2021, 12:13pm
Automatic Forum
Bikley
in Automatic
Date: Mar 29 '21
Time: 5:42am
95AstroLT
in Automatic
Comments: 19
Date: Mar 06 '21
Time: 3:49am
95AstroLT
in Automatic
Comments: 19
Date: Mar 06 '21
Time: 3:42am
in Automatic
Date: Mar 01 '21
Time: 7:14pm
AngryPunk
in Automatic
Date: Feb 18 '21
Time: 11:47pm
