2000 Astro AWD LS / CONVERT AWD to manual shifting 4WD.
Postby MIKEmachine [OP] » October 16th 2009, 3:53am
Is anyone familiar with this idea and have any knowledge of the TOPIC. I am looking at "Dana Model 18 or 20 Transfer Cases" for this task I think. At least that is what I would like to use. Any input or suggestion or information would be extremely appreciated.
Thanks Mike.
MIKEmachine
Years of Membership: MIKEmachine has been a member for 12 full yearsMIKEmachine has been a member for 12 full yearsMIKEmachine has been a member for 12 full yearsMIKEmachine has been a member for 12 full yearsMIKEmachine has been a member for 12 full yearsMIKEmachine has been a member for 12 full yearsMIKEmachine has been a member for 12 full yearsMIKEmachine has been a member for 12 full yearsMIKEmachine has been a member for 12 full yearsMIKEmachine has been a member for 12 full yearsMIKEmachine has been a member for 12 full yearsMIKEmachine has been a member for 12 full years
Alias (AKA): Mike, (MIKEmachine)
Extra Info: LS 4.3L V6 AWD
  • 1997 AWD - can you assist re my trans/ xfer case
    by swing » October 26th 2020, 6:01am in Automatic
    October 29th 2020, 10:44pm
  • Where to get 2005 AWD shifter cable ?
    by astrofinland » January 5th 2021, 4:50pm in Automatic
    Last post by astrofinland View the latest post
    January 7th 2021, 3:01pm
    March 7th 2021, 7:44am
Re: 2000 Astro AWD LS / CONVERT AWD to manual shifting 4WD.
Postby Jasen » October 16th 2009, 4:52am
All I can offer is the tranny from a 96 S10 blazer 4x4 fit in my 97 AWD Astro.
I would think the whole drive train from an S10 4x would fit, you'd just need to find one with a manual box.
I've got no idea what diffs they offered for the S10's
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
Postby doyoulikeithere » October 17th 2009, 10:28pm
is there a place already there to hang a clutch pedal in the 97 vans? What did you use for a clutch pedal? The s10 stuff?
:twisted:
doyoulikeithere
Firing on 7 Cylinders (L1)
Years of Membership: doyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full years
Topics: 26
Images: 11
Postby Leeann_93 » October 18th 2009, 2:49am
^ You don't need a clutch for a 4x4, so no pedal - he's not talking about a 5 speed. He just needs a place to mount the lever. When he says manual shift, he means for the 4x4. Later Blazers had push-button 4x4.
Postby MIKEmachine [OP] » October 18th 2009, 1:22pm
Jansen, do you know the MODEL of the Transfer case that you put in from the S10? Also to confirm, it is a manual(mechanical) shifter for your Transfer Case?
MIKEmachine
Postby MIKEmachine [OP] » October 18th 2009, 1:25pm
MIKEmachine
Postby $uperJoe » October 18th 2009, 7:24pm
multiple models would potentially work here. since you say a manual shift lever one that will cut down on the options. first do you want a manual for a specific reason? also will you be changing the front endcomponets or leaving the current drive axle assembly in the front?
Check out my Van build
$uperJoe
Firing on 4 Cylinders (L2)
Years of Membership: $uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years
Topics: 59
Postby MIKEmachine [OP] » October 21st 2009, 12:37pm
I would like a MANUAL shifting TC because I am a bit fed up with ELECTRONIC FAILURES(encoder motors,sensors etc.), electronics have their place but I don't think it needs to be in the TC. I would like to be able to continue to use the existing front axle with perhaps the addition of some reinforcement components. I like the parts I see at the "OVERLAND VANS" and "NOVAK" websites. I am fairly sure that the drive shafts will either require modification or replacement. I am also thinking that the "DANA model 300" TC may make a better choice then the 18 or 20. I am prepared to make the hole in the floor for the shifter and that doesn't bother me. I see that Novak has rebuild kits,adapter components etc for the 18,20 and 300 DANA TC's. All I need is information at this point.
If anyone has working knowledge of these modifications, I would greatly appreciate their input.
My dream would be to pull 1 of my friends Z71 trucks out of the snow bank with my "GOOD OL FAMILY WAGON" LOL.
http://www.novak-adapt.com/catalog/kit_4l63.htm
MIKEmachine
Return to Automatic
It is currently March 7th 2021, 7:44am
Automatic Forum
95AstroLT
in Automatic
Time: 3:49am
95AstroLT
in Automatic
Time: 3:42am
in Automatic
Date: Mar 01 '21
Time: 7:14pm
AngryPunk
in Automatic
Date: Feb 18 '21
Time: 11:47pm
Youngblood
in Automatic
Date: Jan 15 '21
Time: 1:24am
Users browsing this forum: Google Adsense [Bot] and 22 guests
