Drive Gear & Driven Gear w/Same Tooth Count- Possible?
Postby Casey [OP] » December 19th 2009, 4:39am
Is it possible to use a drive and driven gear in a TH350/T5 trans with the same tooth count on each gear> For instance, can I use a 19-tooth drive gear on the output shaft and a 19 tooth driven gear in the speedo housing so the speedo turns at the same rate as the mainshaft?
Casey
Years of Membership: Casey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full years
Topics: 24
Extra Info: 4.3L LT 5-speed
Return to Automatic
It is currently October 1st 2020, 6:37am
Automatic Forum
