THIS is... Your TC.
THIS is... Your TC.
Postby [email protected] [OP] » May 22nd 2014, 2:44am
Just thought I'd show you what your Torque Converter most-likely looks like inside and out. (If your van is a Gen 2 and if you have your stock transmission.)
Hub is bad. Gotta cut it off :lol:
I labeled it. Just for you. :)
It's numbered in order Flywheel side to Transmission side.
EDIT: Your ATF fluid is supposed to be Reddish-Pink by the way. NOT BROWN. SO CHANGE YOUR FLUID. :thumbup:
'06 Impala 3.5(FF)
'91 Civic Hatch 4-sp - Sold
'97 Astro AWD - Cracked Head
'80 C10: "Arianne" -SOLD
[email protected]
Years of Membership: Aaron@OER has been a member for 6 full yearsAaron@OER has been a member for 6 full yearsAaron@OER has been a member for 6 full yearsAaron@OER has been a member for 6 full yearsAaron@OER has been a member for 6 full yearsAaron@OER has been a member for 6 full years
Topics: 7
Images: 6
Extra Info: AWD 3.73
Re: THIS is... Your TC.
Postby SilverBullet1997 » May 22nd 2014, 4:54am
o.O
R.I.P.-1997 Astro AWD SilverBullet I 4-9-1997 to 2-17-2015 - Cause of death: Rear-ended
R.I.P.-1999 Astro AWD SilverBullet II 1-4-1999 - July-2016 - Cause of death: Roadrash passenger side
Current: 1999 Astro AWD GreenBullet I - Purchased 02/2018
SilverBullet1997
Firing on 6 Cylinders (L2)
Years of Membership: SilverBullet1997 has been a member for 8 full yearsSilverBullet1997 has been a member for 8 full yearsSilverBullet1997 has been a member for 8 full yearsSilverBullet1997 has been a member for 8 full yearsSilverBullet1997 has been a member for 8 full yearsSilverBullet1997 has been a member for 8 full yearsSilverBullet1997 has been a member for 8 full yearsSilverBullet1997 has been a member for 8 full years
Topics: 55
Images: 247
Alias (AKA): Silver or Bullet or SB
Extra Info: 7in Lift AWD Z71
Postby 97cargocrawler » May 22nd 2014, 5:10am
Internally, how do a high stall and low stall converter differ? Spring force, or?
Thanks for the pix. I wouldn't mind a full explanation of what each part does :mrgreen:
97cargocrawler
Topics: 42
Alias (AKA): KING OF OVERKILL
Postby [email protected] [OP] » May 22nd 2014, 5:58am
97cargocrawler wrote:Internally, how do a high stall and low stall converter differ? Spring force, or?
ONLY because you asked. :rofl:
A Torque Converter is basically a fluid coupling. With an A/T transmission, your engine and your transmission aren't directly connected. Take two fans and face them towards each-other. Turn one on and it will spin the other. But- hold the 2nd fan and the first continues spinning, right? Same concept with a TC. The Impeller (#5 in photo) is connected to the cover (#1) which is connected to the flywheel, in turn directly connected to the engine itself. The turbine (#3) is connected to the transmission input shaft. So in other words, unless the [vehicle] is in park or neutral, any movement of the turbine moves the vehicle.
It doesn't use air like the fans though (as you know.)
It uses a thick, non-compression-able liquid (ATF.) The spinning impeller (sometimes referred to as a pump) pushes the ATF into the turbine to cause movement. The thing to keep in mind is that once the ATF has been pushed into the turbine blades, it needs to get back to the impeller so it can be used again. (remember the fans? They were a room full of air- Unlike the transmission, which is a sealed container that only holds so much fluid.) That's where the stator (#4) comes in.
It's not attached to the impeller or turbine. It's "freewheeling". And only in the same direction as the other parts of the converter. A one-way clutch inside of it ensures that it can only spin in one direction. I can take a picture of that tomorrow.
When the impeller spins, the moving fluid pushes against the stator fins. The one-way clutch keeps the stator still, and the fins redirect the fluid back to the impeller. When the turbine speeds up, the fluid begins to flow back to the impeller on its own due to the turbine's design and centrifugal force. Then the fluid pushes on the back side of the stator's fins, and the one-way clutch allows it to spin.
Unfortunately, because it's a fluid design, the impeller will always spin faster than the turbine and this is called "slip" which has to be controlled or the vehicle wont move. That's where the stall speed comes in.
EXAMPLE: a torque converter has a stall speed of 2,500 RPM. If the vehicle isn't moving by the time the engine and impeller reach 2,500 RPM: either the vehicle will start to move, or the engine RPM will stop increasing. If it won't move when the converter reaches the stall speed, either it's overloaded or the brakes are locked. (Driver caused or mechanical issue.)
Stall speed determines when power will be delivered to the transmission. Racing engines produce power at high RPM, so racers will use a converter with a high stall speed, which will slip until the engine is producing high power. Diesel trucks put out most of their power at low RPM, so use a torque converter with a low stall speed.
The use of a lockup clutch (#2) is to directly connect the engine and the transmission once slip is no longer needed. When the lockup clutch is active, a plate attached to the turbine is hydraulically pushed up against the front cover (which is connected to the impeller) creating a connection between the engine and transmission. Having them directly connected lowers the engine speed for a given vehicle speed, which increases fuel economy.
'06 Impala 3.5(FF)
[email protected]
Topics: 7
Images: 6
Postby 97cargocrawler » May 22nd 2014, 7:13am
Awesome. Thank you for the detailed explanation. So, what all do you do in there to rebuild the unit? Which parts get replaced and which re-used? I ask because I bought a low stall converter from Monster Transmissions a few years back and it was probably a rebuilt unit.
97cargocrawler
Topics: 42
Postby Big_kid » May 22nd 2014, 12:43pm
AWESOME write up! Thank you!!
Topics: 185
Images: 344
Extra Info: 2WD 5.7 V8
Postby [email protected] [OP] » May 26th 2014, 3:52am
The lockup clutch:
'06 Impala 3.5(FF)
[email protected]
Topics: 7
Images: 6
Postby [email protected] [OP] » May 26th 2014, 3:55am
97cargocrawler wrote:Awesome. Thank you for the detailed explanation. So, what all do you do in there to rebuild the unit? Which parts get replaced and which re-used? I ask because I bought a low stall converter from Monster Transmissions a few years back and it was probably a rebuilt unit.
Let me get back to you on that, I know that we add bearings but I'm not sure what else besides just repairs or changing the stall.
'06 Impala 3.5(FF)
[email protected]
Topics: 7
Images: 6
Postby gtfasteddy » June 2nd 2014, 3:56pm
Very very good write up man scrumptious food for thought. I'm gonna be rebuilding my 4l60e in a month or to getting all the pieces now, question what determines the stall speed ?
gtfasteddy
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: gtfasteddy has been a member for 8 full yearsgtfasteddy has been a member for 8 full yearsgtfasteddy has been a member for 8 full yearsgtfasteddy has been a member for 8 full yearsgtfasteddy has been a member for 8 full yearsgtfasteddy has been a member for 8 full yearsgtfasteddy has been a member for 8 full yearsgtfasteddy has been a member for 8 full years
Topics: 13
Images: 21
Alias (AKA): ED
Extra Info: cs 4.3L RWD
Postby 97cargocrawler » June 2nd 2014, 4:17pm
gtfasteddy wrote:Very very good write up man scrumptious food for thought. I'm gonna be rebuilding my 4l60e in a month or to getting all the pieces now, question what determines the stall speed ?
HA! I figured the answer is someplace in that write-up though I couldn't pinpoint it myself...and it was my original question> I thought I would research it further, but I'm too lazy. :oops:
97cargocrawler
Topics: 42
Postby chevymaher » June 2nd 2014, 6:38pm
gtfasteddy wrote:Question what determines the stall speed ?
Size of the vanes in the torque converter and the torque the engine produces.
A 4.3 may stall at 1500 and the same converter on a big block will stall at 2500 rpm for example. More torque the higher the stall speed.
Topics: 91
Postby [email protected] [OP] » June 3rd 2014, 8:38pm
Sorry, too busy with the explanation to see your question.
The fins on the Impeller and Turbine; the spacing between them, how many there are and how high your RPM is determines the stall speed.
'06 Impala 3.5(FF)
[email protected]
Topics: 7
Images: 6
Postby raziko » June 4th 2014, 10:54am
"[email protected]"
sorry for the interruption...
i learned from you a lot
thanks for the information :ty:
:thumbup:
raziko
Years of Membership: raziko has been a member for 8 full yearsraziko has been a member for 8 full yearsraziko has been a member for 8 full yearsraziko has been a member for 8 full yearsraziko has been a member for 8 full yearsraziko has been a member for 8 full yearsraziko has been a member for 8 full yearsraziko has been a member for 8 full years
Topics: 45
Images: 10
Alias (AKA): raziko
Extra Info: 4.3l v6 slx rwd
Postby [email protected] [OP] » March 6th 2015, 9:31am
Felt the need to revisit an old post.
We fix the industry, engineering, and factory mistakes companies make.
Machine what needs to be cut down- I find a lot of lockups when they fail tend to shred the cover plate when it activates. It doesn't look nice afterward. So I make things pretty and useable again.
A higher stall converter internally will be heavier (maybe a more accurate word is resistant) and harder to spin, (you know, trying to get high RPM before slipping stops) and the fins will look as if they wont move much with fluid travel. So they'll be spread apart and much more open. It would take quite a bit of force to get them going.
Low stall is the opposite of above^
Easy to spin, starts turning immediately upon fluid contact, etc.
(This part I feel like everyone reading should already know, but I'll say it anyway)
Your stall should closely match the power-band of your motor.
So a standard '97 4.3, you're looking at... 190 hp (140 kW) at 4,400 rpm, 250 lb·ft (339 N·m) at 2,800 rpm
Means your TC stall should be around 2200-2600. Which is a pretty high stall.
Thinking it's the 'High Output' part.
Anybody got any insight on what precisely "High Output" means? I see there's a numbers difference, but what mechanically is it?
'06 Impala 3.5(FF)
[email protected]
Topics: 7
Images: 6
Postby MmusicmanMmusicman is online! » March 6th 2015, 1:40pm
[email protected] wrote:Anybody got any insight on what precisely "High Output" means?
Higher than standard, normal, or average... It's a "relative" term.
I have a "high output" street engine.. but not a high output race engine (by race engine standards).
Topics: 73
Images: 59
Postby Lumpy » March 6th 2015, 5:21pm
Every time I get one of those free LED flashlights from Freight-By-The-Bay, it comes with Chinese batteries marked "HIGH OUTPUT".
Years of Membership: Lumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full years
Return to Automatic
It is currently April 22nd 2021, 1:00am
Automatic Forum
Bikley
in Automatic
Date: Mar 29 '21
Time: 5:42am
95AstroLT
in Automatic
Comments: 19
Date: Mar 06 '21
Time: 3:49am
95AstroLT
in Automatic
Comments: 19
Date: Mar 06 '21
Time: 3:42am
in Automatic
Date: Mar 01 '21
Time: 7:14pm
AngryPunk
in Automatic
Date: Feb 18 '21
Time: 11:47pm
