Tranny shifts into neutral at stop,,,Help
Postby lpat72 [OP] » May 23rd 2014, 10:01pm
Help,,,,
Have problem with my 1995 Safari( 4spd auto tranny, RWD),,
After driving,1/2 hour or longer,when I come to a complete stop and
step on gas pedal to go, the tranny drops into neutral...
I just shift it backinto gear and go,,,Anybody experiance the same ,,,?
Is it something I can fix or will I need to go to the tranny shop,,,????
Thanks,,Pat,,,
lpat72
Years of Membership: lpat72 has been a member for 6 full yearslpat72 has been a member for 6 full yearslpat72 has been a member for 6 full yearslpat72 has been a member for 6 full yearslpat72 has been a member for 6 full yearslpat72 has been a member for 6 full years
Alias (AKA): Pat
  • Low rumble when starting from stop...no vibration
    by gordo999 » November 12th 2020, 2:38am in Automatic
    Last post by gordo999 View the latest post
    November 13th 2020, 2:16am
  • Tranny cooler install help
    by Chunkstyle » August 11th 2020, 11:13pm in Automatic
    August 14th 2020, 12:06am
    9
    29
    December 3rd 2020, 10:53am
Re: Tranny shifts into neutral at stop,,,Help
Postby Astrofarian » May 30th 2014, 5:45am
Probably your shifter linkage needs an adjustment...but you should maybe rule out a bad motor mount or trans mount first. Adjustment is easy, common sense kinda thing if you've ever done any work on your vehicles it'll take longer to lift it up than to adj the linkage. Good luck!
Astrofarian
Alias (AKA): M!ke
Extra Info: Someday......
Postby lpat72 [OP] » May 30th 2014, 4:09pm
Thanks,,, Astrofarian,,
Motor and trans mounts are good,, and I adjusted the shifter linkage,,but no change,,
lpat72
Alias (AKA): Pat
Postby Astrofarian » May 30th 2014, 4:20pm
Something inside the trans then? Internal detent maybe? Someone here will know more....pm Chevymaher, he'll have an answer for you.
Astrofarian
Alias (AKA): M!ke
Postby lpat72 [OP] » June 8th 2014, 9:04pm
ASTROFARIAN,,,
PM'd CHEVYMAHER,,,He said to check the detent spring for carcks or wear,,,
Today..dropped the tranny pan and checked the detent spring,,
It was in good condition and still stiff ,when compressing by hand,,
Guess I'll have to bring it to the Tranny Shop,,,
Unless some else has an easy fix,,,,
Thanks guys,,,Pat :ty:
lpat72
Alias (AKA): Pat
Postby lpat72 [OP] » June 29th 2014, 6:18pm
Bit the bullet,, had tranny fixed ,,The man said the main problem was a cracked sprag,,
Thanks again,,,,,Pat
lpat72
Alias (AKA): Pat
Return to Automatic
It is currently December 3rd 2020, 10:53am
Automatic Forum
Chunkstyle
in Automatic
Date: Aug 11 '20
Time: 8:25pm
in Automatic
Date: Jul 26 '20
Time: 1:22pm
Olivier02
in Automatic
Date: Jun 13 '20
Time: 9:22pm
SoccerMom4x4
in Automatic
Date: Jun 12 '20
Time: 2:50pm
SoccerMom4x4
in Automatic
Date: Jun 11 '20
Time: 2:12pm
Users browsing this forum: Yandex [Bot] and 6 guests
