Trans mounts: Quality manufacturer?
Postby swharris [OP] » July 24th 2014, 9:49pm
I had horrible luck with motor mounts and don't want to repeat that "Chinese" experience. So, who is making a quality trans( Oem Hydraulic) mount? Any experience with DEA? https://www.rockauto.com/catalog/moreinfo.php?pk=441397&cc=1028089
swharris
Years of Membership: swharris has been a member for 11 full yearsswharris has been a member for 11 full yearsswharris has been a member for 11 full yearsswharris has been a member for 11 full yearsswharris has been a member for 11 full yearsswharris has been a member for 11 full yearsswharris has been a member for 11 full yearsswharris has been a member for 11 full yearsswharris has been a member for 11 full yearsswharris has been a member for 11 full yearsswharris has been a member for 11 full years
Topics: 81
Images: 4
Alias (AKA): S4
Extra Info: 4.3 Vortec 2wd
  • 2005 Astro awd trans interchange?
    by offroad safari » May 23rd 2020, 3:39am in Automatic
    Last post by lllharris View the latest post
    May 23rd 2020, 12:05pm
  • Trans Removal Crossmember Question
    by Huckleberry » May 31st 2020, 9:14pm in Automatic
    May 31st 2020, 10:47pm
    54
    October 27th 2020, 3:10pm
Re: Trans mounts: Quality manufacturer?
Postby RECox286 » July 24th 2014, 10:11pm
There are Poly inserts that you can use with your old M/M clamshells.
When I did my M/M and T/M, I got COO=India from Napa.
I have no idea if you can do better than that, as I have heard that
even Stealerships are selling the COO= China M/M. Take a stroll
down "Search' [Lane] for Motor Mounts for more excellent reading.
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby Mmusicman » July 25th 2014, 2:13am
I just went through this very same issue (with engine mounts)... wondering where I could get quality American built motor mounts.
At first it didn't occur to me. I had purchased cheap mounts from Summit made by "Anchor"... they were only $4.95/ea. After looking at them, they looked rough and cheap. No doubt they were cheap... but after doing some research and reading customer reviews, I found there to be a huge amount of people complaining about them being junk with their premature failures.
I considered NAPA or other stores, only to learn that many of their products are just re-banded cheap products too. It's hard to track exactly who makes what for who.. since they keep switching sources.
I finally elected to go with factory OEM mounts from the dealer. The mounts cost me $53/ea... quite a bit more than my cheap $5 mounts. The price of the part pales in comparison to the work involved in changing them when they fail. Ironically, they say "Made In China" right on the ACDelco tag.
It is my hope that despite coming from China, that at least the ACDelco (China) part is at least made to better standards, as "hopefully" spec'd by the dealer.
Firing on 6 Cylinders (L5)
Topics: 72
Images: 49
Postby sfeaver » July 25th 2014, 2:41am
Ive been down this road with my V8 swap. Got Anchor ones.. 500 miles later had to replace and got GM china ones. They are good. Hate that they are Chinese, but they have been just fine. Its not a fun job to do a second time, so I would go OEM.
sfeaver
Firing on 8 Cylinders (L1)
Topics: 29
Images: 21
Van Model Year: 2001
Extra Info: LT RWD 350ci V8
Postby Corsemoto » July 25th 2014, 2:42am
So what, if any are the differences in AWD and RWD motor mounts?
GM shows two different part numbers for left/right AWD motor mounts and being no longer available. RWD different than AWD part number but same part number for both sides and still available.
I went with Energy Suspension 3.1145 urethane motor mounts (made in USA) as I don't want to be replacing again any time soon and I just couldn't trust a $5 aftermarket mount to last. I'll also be installing an Energy Suspension 3.1129 transmission mount (AWD) soon.
Since I replaced one side at a time, I didn't compare the stock mounts before installing the urethane mounts.
Stock rubber motor mounts passenger / driver side. Driver mount cracked all the way through and beat up so she be flexin'! :D
Passenger side mount
Energy Suspension mount in original bracket
Ready to install
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Postby WoodButcher » September 26th 2014, 10:32pm
My '93 I'm using the energy suspension in a new "Anchor" mount shells. Some years back I bought them for my '97 and didn't need them and now that I'm doing the swap in the '93 I couldn't bring myself to put that junk in. I looked at the metal and it was similar to what I took out so I drilled out the new rubber and put in the poly.
WoodButcher
Firing on 5 Cylinders (L6)
Topics: 30
Images: 512
Alias (AKA): Bruce
Extra Info: 5.7L RWD
Postby markmitch » September 26th 2014, 11:55pm
me too- I am going to do the trans soon too
Topics: 608
Images: 20
Extra Info: RS V8
Return to Automatic
It is currently October 27th 2020, 3:10pm
Automatic Forum
Chunkstyle
in Automatic
Date: Aug 11 '20
Time: 8:25pm
in Automatic
Date: Jul 26 '20
Time: 1:22pm
Olivier02
in Automatic
Date: Jun 13 '20
Time: 9:22pm
SoccerMom4x4
in Automatic
Date: Jun 12 '20
Time: 2:50pm
SoccerMom4x4
in Automatic
Date: Jun 11 '20
Time: 2:12pm
Users browsing this forum: gravelygravely is online! and 9 guests
