2003 transmission only?
Postby astroman97 [OP] » August 15th 2014, 11:48pm
Went to the boneyard looking for a 4l60e supposedly 2003 only for an interchange on a rwd? Does this seem right? For those in the know if so why? :confused:
astroman97
Years of Membership: astroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full years
Topics: 78
Images: 2
Extra Info: Also 97 both 2wd
Re: 2003 transmission only?
Postby Lumpy » August 15th 2014, 11:54pm
What? ... :confused:
Postby astroman97 [OP] » August 16th 2014, 12:23am
Lumpy wrote:What? ... :confused:
Was told the 2003 is the only transmission that will fit...pretty much thought they are almost all the same 2002-05 with the tow haul and even with that there is only a wiring issue (harness can be changed to make older ones work? While I know a 4x4 and I believe the. M30 version(one piece none removable bell housing) are different?
astroman97
Topics: 78
Images: 2
Postby redfury » August 16th 2014, 2:03am
Perhaps they only made AWD models in the last two years? I don't know really...not much changed in the years they switched to the 6 lug versions from what I've read/seen.
redfury
Firing on 8 Cylinders (L3)
Topics: 53
Images: 13
Extra Info: LT 5.7L 4wd
Return to Automatic
It is currently January 19th 2021, 9:16am
Automatic Forum
Youngblood
in Automatic
Date: Jan 15 '21
Time: 1:24am
allenstoltzfus
in Automatic
Comments: 9
Date: Jan 14 '21
Time: 7:36pm
runawayjim
in Automatic
Date: Jan 07 '21
Time: 2:09pm
Attached by: SportsBoy
SportsBoy
in Automatic
Date: Jan 05 '21
Time: 11:16pm
Chunkstyle
in Automatic
Date: Aug 11 '20
Time: 8:25pm
