Slow 1-2 shifts when cold
Postby 99Super [OP] » April 8th 2008, 10:57pm
My 2000 AWD has a slow 1-2 shift in the morning when it's cold. It only seems to happen when my fan clutch is also cold and the fan is pulling hard (or so it sounds). When it does finally shift, it's a bit firm. The van has high miles (200K +)
and it appears someone has been into the tranny at least once already. The fluid is nice and red, not burnt.
I'm going to install a heavier radiator and/or tranny cooler here in a few weeks and am going to change the fluid/filter at the same time to see if that helps.
Anyone ever use RedLine Synthetic ATF?
What are the odds I'm just wasting my time and I need to start saving for a new tranny? :cry:
john
99Super
Years of Membership: 99Super has been a member for 12 full years99Super has been a member for 12 full years99Super has been a member for 12 full years99Super has been a member for 12 full years99Super has been a member for 12 full years99Super has been a member for 12 full years99Super has been a member for 12 full years99Super has been a member for 12 full years99Super has been a member for 12 full years99Super has been a member for 12 full years99Super has been a member for 12 full years99Super has been a member for 12 full years
Topics: 7
Re: Slow 1-2 shifts when cold
Postby gtkane » April 9th 2008, 4:52am
I don't think your tranny is on the way out. Good fluid usually means good clutches.
Ther have been some problems with the 1-2 shift solenoid(also known as "shift solenoid A"). It may be slow to engage when cold, and will not set a trouble code.
Replacing it is easy once you have the pan off, and it's less than $75.
As for the fluid, I'd just stick with good 'ol Dexron 6.
User album #4...check it out!
gtkane
Alias (AKA): Astruck
Extra Info: nasty 4.3
Postby 99Super [OP] » April 9th 2008, 3:20pm
Thanks!
That sure could be it! Since I was gonna change fluid anyway, maybe I'll just go ahead and swap it out.
john
99Super
Topics: 7
Postby 99Super [OP] » June 19th 2009, 11:34pm
Well, I figured out my shifting issues.
After changing the tranny fluid, filter and both shift solenoids, there was very little change in the shifting.
So, I changed my gas! I stopped using gas w/ ethanol and found a local station that didn't use any.. Shifting is firm, but there is no more missed shifting! WooHoo!
99Super
Topics: 7
Postby astro355 » June 20th 2009, 5:22am
Yep, any change in the amount of power going thru the transmission will change how it shifts. My favorite is when the first hot day of the year comes around and people start to use their a/c and think their transmission is suddenly junk. If I was crooked, I would give them a tune-up for the price of a transmission rebuild. :whistle:
astro355
Firing on 4 Cylinders (L6)
Extra Info: 355 V8 700R4
Postby rev_les » June 20th 2009, 7:02am
The alcohol definitely makes a difference in the way these things run.Stations here around Houston advertise 10% ethanol, it's closer to 20% usually according to Yamaha and Honda from test results they've had figuring out problems on bikes. Fuel mileage goes down as well. I try to leave the tank a little low if I know I'll be in outlying areas that sell straight gasoline. ( BTW, don't leave that crap in your lawn equipment long without running it, the alcohol eats up the insides of the carb. All my lawn stuff runs on Sunoco 110 lowlead with Blendzall, lol)
NRA Lifetime Member
2'nd amendment supporter
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Firing on 2 Cylinders (L3)
Years of Membership: rev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full years
Topics: 39
Alias (AKA): Les
Extra Info: LS 4.3 RWD
Postby 99Super [OP] » June 20th 2009, 3:46pm
Exactly. I just had to replace the carb on my Mower...
99Super
Topics: 7
Postby Leeann_93 » June 20th 2009, 4:39pm
You can't buy gas here in Maryland that doesn't have ethanol. None of my cars (newest is '93) likes that crap.
Neighbor just borrowed our lawn mower yesterday 'cause he can't get his to start...you guessed it, the carb needs to be rebuilt. We put leftover race fuel in ours - avgas from the airport just down the street. No alcohol ;)
Return to Automatic
It is currently March 7th 2021, 6:26pm
Automatic Forum
95AstroLT
in Automatic
Time: 3:49am
95AstroLT
in Automatic
Time: 3:42am
in Automatic
Date: Mar 01 '21
Time: 7:14pm
AngryPunk
in Automatic
Date: Feb 18 '21
Time: 11:47pm
Youngblood
in Automatic
Date: Jan 15 '21
Time: 1:24am
