4L60E 3rd gear problem?
Postby jeff's93astro [OP] » April 7th 2010, 7:35am
my 4l60E has had the fluid and filter changed when i first bought the van had just a little grey sludge on magnet no shavings and shifted great but now weather its warm or cold the trans takes R almost instantly but D takes about 2-3 seconds to grab. but it shifts fine except for about 70% of the time when it shifts into 3rd it feels like it goes from second to neutral then to 3rd in about a second its quick about it but i can feel it and also hear the slight rev through the exhaust. also TC lockup doesnt feel as firm as either 700R4's i've had. i'm not sure if its the original tranny are not but the van has 229,000miles and the motor is out of a 89 astro. Easy fix or time for new tranny
95 Astro 5.3L RWD 3/3 drop
03 Suburban 5.3L 2wd 3/5 drop
jeff's93astro
Topics: 55
Images: 19
Extra Info: CS 4.3L V6 RWD
  • Lost 3rd (D) gear, Ideas???
    by soutthpaw » June 29th 2020, 2:54am in Automatic
    Last post by soutthpaw View the latest post
    June 29th 2020, 11:23pm
  • Will a 4l60e from another vehicle fit an Astro van?
    by Diablito » April 23rd 2020, 2:43pm in Automatic
    April 24th 2020, 6:48pm
    27
    October 22nd 2020, 7:20am
Re: 4L60E 3rd gear problem?
Postby astro355 » April 7th 2010, 8:28am
Does this describe the symptom accurately?
30. 1-2 or 2-3 shift is slow/soft above part throttle: Trans is on its way out. R&R.
https://www.astrosafari.com/viewtopic.php?f=70&t=5956
astro355
Firing on 4 Cylinders (L6)
Extra Info: 355 V8 700R4
Postby jeff's93astro [OP] » April 8th 2010, 12:34am
i got to driveing it again today and this time at certain throttle positions it would shift normal sometimes light throttle sometimes heavy but not everytime i'm expecting it to be a rebuild but is it possible it could be tps or as bad as i hate to is there a snake oil/treatment that could help it last a little longer or just drive it till it goes out
jeff's93astro
Topics: 55
Images: 19
Postby mot_art » April 8th 2010, 12:43am
if it was the TPS.. I think It wont take long before it engages when you put it to D, neither go into neutral before upshifting.... I think your tranny is slipping... try the Lucas thing see if it fixes it.. if not I think it is going to be a Remove and Rebuild previously mentionned.
1995 BMW 740il
1999 Ford escort
1996 Dodge Dakota
-*-*-*-1996 GMC Safari *-*-*-*
mot_art
Years of Membership: mot_art has been a member for 10 full yearsmot_art has been a member for 10 full yearsmot_art has been a member for 10 full yearsmot_art has been a member for 10 full yearsmot_art has been a member for 10 full yearsmot_art has been a member for 10 full yearsmot_art has been a member for 10 full yearsmot_art has been a member for 10 full yearsmot_art has been a member for 10 full yearsmot_art has been a member for 10 full years
Extra Info: LT 4.3L V6 RWD
Postby jeff's93astro [OP] » April 9th 2010, 5:34am
just for curosity i changed out the computer with the one that came out of my other 93 i had and it didn't do the slip thing in 3rd. and i agree with astro355 about the computers rarely going bad. and if my original is bad something had to cause it :confused:
jeff's93astro
Topics: 55
Images: 19
Postby astro355 » April 9th 2010, 8:01am
jeff's93astro wrote:just for curosity i changed out the computer with the one that came out of my other 93 i had and it didn't do the slip thing in 3rd. and i agree with astro355 about the computers rarely going bad. and if my original is bad something had to cause it :confused:
What are the serial numbers of the two computers?
astro355
Postby jeff's93astro [OP] » April 9th 2010, 8:48am
my original computer is 16168625 BBMY and the one in my van now is a reman. i'll look for a number on it tomorrow.
jeff's93astro
Topics: 55
Images: 19
Return to Automatic
It is currently October 22nd 2020, 7:20am
Automatic Forum
Chunkstyle
in Automatic
Date: Aug 11 '20
Time: 8:25pm
in Automatic
Date: Jul 26 '20
Time: 1:22pm
Olivier02
in Automatic
Date: Jun 13 '20
Time: 9:22pm
SoccerMom4x4
in Automatic
Date: Jun 12 '20
Time: 2:50pm
SoccerMom4x4
in Automatic
Date: Jun 11 '20
Time: 2:12pm
