Lost reverse, then every gear....stuck in park!
Postby CreepiE [OP] » January 11th 2015, 3:41pm
My 99 automatic runs great. However yesterday I went to back it back into the shop and it would not shift into reverse! Drive and the other gears were fine....then they all went out and the van was stuck in park!
-Checked linkage, when gear shifter was selecting, the linkage was moving.
-The van was level, so I checked fluid and it was fine.
Called a tow, he dragged it on the flatbed, backed up, lowered it into the shop.
Before we rocked it off the ramp, I asked if I could try to drive it off.
I got in, applied the brake, and it shifted and I drove it off the ramp!!
After he left, I went thru all the gears, it shifted okay, sometimes it hesitated though.
I have a lot of calls tomorrow! I was going to test drive it today. Yesterday was bitter cold.
I wonder if something got stuck? Then the jerking and incline loosened it up?
CreepiE
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: CreepiE has been a member for 11 full yearsCreepiE has been a member for 11 full yearsCreepiE has been a member for 11 full yearsCreepiE has been a member for 11 full yearsCreepiE has been a member for 11 full yearsCreepiE has been a member for 11 full yearsCreepiE has been a member for 11 full yearsCreepiE has been a member for 11 full yearsCreepiE has been a member for 11 full yearsCreepiE has been a member for 11 full yearsCreepiE has been a member for 11 full years
Topics: 21
Location: So close to Wisconsin I can smell the Cheese!
Extra Info: 4.3L V6 Cargo
  • Lost Reverse & 2nd Gear, Ecode752=Shift Solenoid A stuck on
    by RandyHip » September 21st 2020, 9:03pm in Automatic
    September 21st 2020, 10:26pm
  • GEAR SHIFTER STUCK IN PARK.
    by huddy » October 18th 2020, 2:04pm in Automatic
    October 22nd 2020, 7:30pm
    55
    October 25th 2020, 8:20am
Re: Lost reverse, then every gear....stuck in park!
Postby CreepiE [OP] » January 11th 2015, 6:41pm
Well I went over to see if I could drive the van. Trans appears to engage the gears, but will not drive, or slow to drive. In reverse the van seems like it wants to stall out, but recovers.
:confused:
CreepiE
Fueling (7/8 tank)
Fueling (7/8 tank)
Topics: 21
Postby Meterpig » January 11th 2015, 6:50pm
Here is what I would do first. Make sure that the solenoids are actually receiving a signal from the switch and they are all working. Once that is verified, make sure your filter is in good condition and allowing fluid to cycle through. If both of those are verified, it's time to either pull the transmission out and rebuild it drop it off at a REPUTABLE rebuild place. Also, if you are confident the something is mechanically wrong...you can buy an off the shelf transmission. However, if you are at all handy, you can rebuilt it in your garage with hand tools...its sort of fred flinstone technology.
Meterpig
Firing on 5 Cylinders (L2)
Years of Membership: Meterpig has been a member for 5 full yearsMeterpig has been a member for 5 full yearsMeterpig has been a member for 5 full yearsMeterpig has been a member for 5 full yearsMeterpig has been a member for 5 full years
Topics: 63
Alias (AKA): meterpig
Van Model Year: 2002
Extra Info: Not a minivan
Postby CreepiE [OP] » January 12th 2015, 12:56am
I went over to the shop to do something...
1. I added Seafoam and let the van run 20 minutes
2. Dropped the pan, drained fluids, installed new filter & fluid.
Started van let idle running thru the gears for about 5 minutes.
Test drive....drives fine out of the gate! No uneasy jolts, hesitation, slipping etc. Only about two miles, then got dark.
Nothing found in fluids.
One question. Is the filter SUPPOSED to come out in the pan, or will it be hanging from the trans?
I think the filter came undone, and was not allowing fluids to circulate correctly.
CreepiE
Fueling (7/8 tank)
Fueling (7/8 tank)
Topics: 21
Postby Lumpy » January 12th 2015, 1:35am
It should be pretty firmly up in the trans, not come out with the pan. I'm not sure how much clearance it would have if it weren't up there firmly. Might be close enough that it at least got SOME ATF circulation.
Maybe you didn't drive it too much to do any damage from non-circulation. Maybe that's also why the ride on the flatbed did a temporary fix. Maybe that extreme tilt allowed some juice to get up into the transmission.
Other, more knowledgable transmission experts will chime in. I don't know much about what happens from the filter northward.
Postby CreepiE [OP] » January 12th 2015, 1:49am
I agree! When it went out it was on an angle, then the angle reversed!
CreepiE
Fueling (7/8 tank)
Fueling (7/8 tank)
Topics: 21
Postby chevymaher » January 12th 2015, 2:03am
Filter fell off. Trans was sucking air. If it gets a air bubble it wont do anything.
Postby CreepiE [OP] » January 12th 2015, 7:09pm
Took it to the local mechanic....they were able to pull the old seal out and get the new one in. Reused everything, tire rotation and greased the joints.
Good to go!
CreepiE
Fueling (7/8 tank)
Fueling (7/8 tank)
Topics: 21
Postby chevymaher » January 12th 2015, 7:22pm
CreepiE wrote:Took it to the local mechanic....they were able to pull the old seal out and get the new one in. Reused everything, tire rotation and greased the joints.
Good to go!
Good deal I like happy endings.
Postby DRZ » January 12th 2015, 7:42pm
That happened to a 2000 Astro cargo van I was selling. It was bitter cold when the guy came to look at it and it started right up but wouldn't move in any direction. I could see all the linkage was moving but no go. Got it to my buddys shop and dropped the pan. It was soo cold the seal hardened up and let the filter drop. New filter and seal and back to normal.
DRZ
Years of Membership: DRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full years
Topics: 53
Images: 55
Alias (AKA): HPbyStan
Extra Info: awd cargo Alloys
Return to Automatic
It is currently October 25th 2020, 8:20am
Automatic Forum
Chunkstyle
in Automatic
Date: Aug 11 '20
Time: 8:25pm
in Automatic
Date: Jul 26 '20
Time: 1:22pm
Olivier02
in Automatic
Date: Jun 13 '20
Time: 9:22pm
SoccerMom4x4
in Automatic
Date: Jun 12 '20
Time: 2:50pm
SoccerMom4x4
in Automatic
Date: Jun 11 '20
Time: 2:12pm
