Lost 3-4th gear in recon box, possible electronic fault
Postby BulgarianAstro [OP] » February 9th 2015, 8:25pm
Hi, All,
I am new to AstroVans and have purchased a 1996 AWD DayVan conversion.
Was sold to me with a reconditioned gearbox fitted by previous owner, but done very little mileage since. Been sitting around for last 4-5 years since fitting, with a few other jobs done.
I've done about 100 miles in it and last night it lost 3-4 gear while running around town.
Have checked oil levels (topped up by 1/2 ltr) but no change (literally)
Wondering if an electronic fault may be the problem, perhaps connection or wire shaken loose over speed humps in town.
Any thoughts on what I should look for?
With gratitude
Andrew
BulgarianAstro
Years of Membership: BulgarianAstro has been a member for 6 full yearsBulgarianAstro has been a member for 6 full yearsBulgarianAstro has been a member for 6 full yearsBulgarianAstro has been a member for 6 full yearsBulgarianAstro has been a member for 6 full yearsBulgarianAstro has been a member for 6 full years
Alias (AKA): Andrew
Van Model Year: 1996
Extra Info: AWD DayVan Conversio
  • Fresh 4l60e low line pressure no 2nd or 4th
    by Bikley » January 17th 2021, 10:40am in Automatic
    February 17th 2021, 2:42am
    7
    83
    June 18th 2021, 3:00am
Re: Lost 3-4th gear in recon box, possible electronic fault
Postby AstrofarianAstrofarian is online! » February 10th 2015, 4:19am
Get under there and have a look-see. Could be as simple as adjusing the shift linkage or the TV (Detent) cable.
-Mike-
Alias (AKA): M!ke
Extra Info: Someday......
Postby paulo57509 » February 10th 2015, 4:24am
If you lost 3rd gear (and by default, 4th because it won't shift past 3rd) the trans is pretty much dead. The 3-4 clutches have incinerated themselves. You have my sympathies.
:crying-blue:
You can still drive it in manual 2nd without doing further damage. Just watch your engine RPM's. You can also use reverse without causing further damage as well.
How many miles are on the transmission?
If you drop the pan you'll see something like this:
paulo57509
Firing on 7 Cylinders (L1)
Topics: 24
Extra Info: RWD
Return to Automatic
It is currently June 18th 2021, 3:00am
Automatic Forum
fryaeggontheground
in Automatic
Date: May 05 '21
Time: 5:30pm
OldSchoolNoe
in Automatic
Date: May 03 '21
Time: 7:56pm
Bikley
in Automatic
Date: Mar 29 '21
Time: 5:42am
95AstroLT
in Automatic
Comments: 19
Date: Mar 06 '21
Time: 3:49am
95AstroLT
in Automatic
Comments: 19
Date: Mar 06 '21
Time: 3:42am
