Quick NP136 transfer case question
Postby jaywoo65 [OP] » February 24th 2015, 1:34am
I was out today in the snow and the front wheels aren't pulling. I checked the ATC fuse and it's good. When I turn on the ignition, the Service AWD light comes on and goes out like it's supposed to. It's not on any other time. So I figure what the heck, it might be the encoder motor. I had recently changed out the transfer case, the old one was making a bunch of noise when the AWD engaged. Basically I have two spare encoder motors. So, I decided to put in one of the others. Which leads me to my question:
When I put the front drive shaft back on, I am able to spin it and the transfer case freely (not hooked up to the front Diff yet - I was aligning it). I really don't remember if this was the case on the old transfer case or even if it should spin. Kinda seems like it should since the clutches aren't engaged to put it in AWD. But I could freely spin it.
Anyway, put the front driveshaft back on and took it out in the snow. Still no AWD and no service light. I need a SCAN tool I think. Or take it and have it checked. I was just wondering if anyone knew if it was supposed to spin. I should have kept the old transfer case that I swapped out.
1999 AWD Astro - under construction
"She may not look like much kid but she's got it where it counts"
jaywoo65
Years of Membership: jaywoo65 has been a member for 5 full yearsjaywoo65 has been a member for 5 full yearsjaywoo65 has been a member for 5 full yearsjaywoo65 has been a member for 5 full yearsjaywoo65 has been a member for 5 full years
Topics: 12
Extra Info: AWD baby
  • 1997 AWD - can you assist re my trans/ xfer case
    by swing » October 26th 2020, 6:01am in Automatic
    October 29th 2020, 10:44pm
  • Transmission question
    by tungtide » May 30th 2020, 3:39pm in Automatic
    Last post by tungtide View the latest post
    May 31st 2020, 1:00pm
    48
    November 25th 2020, 3:38pm
Re: Quick NP136 transfer case question
Postby Meterpig » February 24th 2015, 7:06am
If you aren't getting any errors, it be your clutch plates are worn. If you have changed encoders with no change, either you are getting no signal to the encoder (bad connection) or your clutch plates are toast. Check for signal and then go from there. The NP's have several failure points.
Your old one..did you diagnose why it failed? Noisy? Like Forks in a blender noisy?
Meterpig
Firing on 5 Cylinders (L2)
Years of Membership: Meterpig has been a member for 5 full yearsMeterpig has been a member for 5 full yearsMeterpig has been a member for 5 full yearsMeterpig has been a member for 5 full yearsMeterpig has been a member for 5 full years
Topics: 63
Alias (AKA): meterpig
Van Model Year: 2002
Extra Info: Not a minivan
Postby jaywoo65 [OP] » February 24th 2015, 4:01pm
Yeah. Really noisy when the and would nagged. I think it's time for a rebuild.
jaywoo65
Topics: 12
Postby jaywoo65 [OP] » February 24th 2015, 7:20pm
viewtopic.php?f=70&t=9856
Swap out with a 98 or older transfer case:
viewtopic.php?f=70&t=11612&p=124109#p124109
Just putting this link where I can find it. :)
jaywoo65
Topics: 12
Postby thefixer0508 » March 6th 2015, 3:57am
If it's engaging the tcase (you may need someone moving the van and you looking at the dtiveshaft) it's more than likely the actuator on the axle. They tend to get stuck from rust etc.
thefixer0508
Years of Membership: thefixer0508 has been a member for 5 full yearsthefixer0508 has been a member for 5 full yearsthefixer0508 has been a member for 5 full yearsthefixer0508 has been a member for 5 full yearsthefixer0508 has been a member for 5 full years
Alias (AKA): BigDaddy
Return to Automatic
It is currently November 25th 2020, 3:38pm
Automatic Forum
Chunkstyle
in Automatic
Date: Aug 11 '20
Time: 8:25pm
in Automatic
Date: Jul 26 '20
Time: 1:22pm
Olivier02
in Automatic
Date: Jun 13 '20
Time: 9:22pm
SoccerMom4x4
in Automatic
Date: Jun 12 '20
Time: 2:50pm
SoccerMom4x4
in Automatic
Date: Jun 11 '20
Time: 2:12pm
