will my 4l60e option g30 in my 01 safari work wit pre 87 350
Postby Fivelitereater [OP] » August 16th 2015, 6:01am
what do i have to do to keep my 4 spd auto tranny in my van.The 4.3 in it now spun a bearing. I have a brand new Goodwrench 350 that i will be throwing in it as soon as i can figure out the tranny. Any help would be awsome. New member first post
Fivelitereater
Years of Membership: Fivelitereater has been a member for 5 full yearsFivelitereater has been a member for 5 full yearsFivelitereater has been a member for 5 full yearsFivelitereater has been a member for 5 full yearsFivelitereater has been a member for 5 full years
Van Model Year: 2001
Extra Info: RWD Soon 2 B V8
Re: will my 4l60e option g30 in my 01 safari work wit pre 87
Postby chevymaher » August 16th 2015, 1:03pm
As long as the engine and the computer are compatible it is a bolt in.
So a TBI intake with the correct TBI for the engine size. Injectors are different sized. Computer programming is a tad different. But it works. Fine tuning is done with fuel pressure change. The TBI's regulator can be modified so it is adjustable. It mat just work fine as is.
Or get a computer from a same year truck. It is a direct plug in.
Topics: 91
Postby Vandiction » August 17th 2015, 3:44pm
Use the flex plate off the 4.3
'05 Astro, AWD| 6.0 LQ4 cam'd/rods/lifters/ Slowhawk tuning| FLT 4L65 Stage VI| Yank Pro Truck 2800| Silverado SS X-fer case| 5" lift body/keys| Ride Rite| Rancho 9000XL| 245/70/16 AT| A/R 23 wheels| The SS Astro GM never made.
Vandiction
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: Vandiction has been a member for 5 full yearsVandiction has been a member for 5 full yearsVandiction has been a member for 5 full yearsVandiction has been a member for 5 full yearsVandiction has been a member for 5 full years
Topics: 13
Images: 36
Postby Fivelitereater [OP] » August 18th 2015, 4:30am
i dont think u understand . the motor is a goodwrench 350 carberated one wire alternator hei distributor no fuel injection no computers . i heard i can rig up a tps to my carb [fabracate a bracket] hook up the purple and white wire to my tack output on my distributor and i should be good to go.I just want to have everything in place before i start.I know people have done this swap any help on the subject will be greatly appreicated thanks in advance
Fivelitereater
Postby chevymaher » August 18th 2015, 2:17pm
They sell carbs with TPS sensors on them.
Now for the RPM input required to make the computer work. If it does I am all ears. This is a question no one ever answered or tried. I got some nice parts I can put on if it does.
Topics: 91
Return to Automatic
It is currently June 18th 2021, 3:48am
Automatic Forum
fryaeggontheground
in Automatic
Date: May 05 '21
Time: 5:30pm
OldSchoolNoe
in Automatic
Date: May 03 '21
Time: 7:56pm
Bikley
in Automatic
Date: Mar 29 '21
Time: 5:42am
95AstroLT
in Automatic
Comments: 19
Date: Mar 06 '21
Time: 3:49am
95AstroLT
in Automatic
Comments: 19
Date: Mar 06 '21
Time: 3:42am
