which brand of mount?
Postby pannebreaux [OP] » January 29th 2016, 3:13pm
been looking around and reading about transmission mounts from "different manufacturers". they all point back and forth saying each other's product sucks. dug a bit deeper and it seems they are all made by DEA. reading around different forums, the users seem to agree with the manufacturers. what's the latest consensus on the best mount to use on a rwd?
pannebreaux
Years of Membership: pannebreaux has been a member for 5 full yearspannebreaux has been a member for 5 full yearspannebreaux has been a member for 5 full yearspannebreaux has been a member for 5 full yearspannebreaux has been a member for 5 full years
Topics: 27
Images: 47
Re: which brand of mount?
Postby chevymaher » January 29th 2016, 3:47pm
Stock one on the trans. Poly on the engine mounts. Trans tailshaft needs to move. It is a weak point. The like to break the tailcase if they held tight and the front moves. So that the best move. Hold it tight in front. Rear use rubber and let it do what it needs to do.
Postby AstroWill » January 29th 2016, 4:29pm
I like to use the 'Frau' brand, when mounting is desired.
Images: 463
Postby pannebreaux [OP] » January 29th 2016, 5:12pm
chevymaher wrote:Stock one on the trans. Poly on the engine mounts. Trans tailshaft needs to move. It is a weak point. The like to break the tailcase if they held tight and the front moves. So that the best move. Hold it tight in front. Rear use rubber and let it do what it needs to do.
when you say stock does that mean direct from the gm stealership?
pannebreaux
Topics: 27
Images: 47
Postby chevymaher » January 29th 2016, 5:21pm
Just rubber as opposed to a poly or solid mount. Any old one will do. Anchor is the brand I went with.
Postby Lumpy » January 29th 2016, 6:20pm
I agree with Maher. I put poly on my trans rear mount and it added a lot of vibration to my van. Somewhere on my list of things to do is "Replace poly with softer rubber".
Postby pannebreaux [OP] » January 29th 2016, 7:06pm
Lumpy wrote:I agree with Maher. I put poly on my trans rear mount and it added a lot of vibration to my van. Somewhere on my list of things to do is "Replace poly with softer rubber".
that's exactly what i'm up to, vibration elimination. it grumbles going down the road making me think i had a crunchy axle bearing. my extension housing bushing is worn out, so i figured while i have it apart i'd swap the circa 98 mount that has cracks and crusty abounding. it seems likes it's still intact, but ...
i saw a tool that pulls and presses the bushing from the outside without having to remove the cone. it's a bit pricey but figured i might be able to rent it from a big box laps. has anyone used it to swap their bushing? http://www.transmissionpartsusa.com/v/v ... 161A-2.jpg
pannebreaux
Topics: 27
Images: 47
Return to Automatic
It is currently January 25th 2021, 9:08pm
Automatic Forum
Youngblood
in Automatic
Date: Jan 15 '21
Time: 1:24am
allenstoltzfus
in Automatic
Date: Jan 14 '21
Time: 7:36pm
runawayjim
in Automatic
Date: Jan 07 '21
Time: 2:09pm
Attached by: SportsBoy
SportsBoy
in Automatic
Date: Jan 05 '21
Time: 11:16pm
Chunkstyle
in Automatic
Date: Aug 11 '20
Time: 8:25pm
