How can I tell if I have a deep or shallow transmission pan, it is rear wheel drive. I dropped the pan and pulled the filter( looked original) and it was thicker than the new one i bought. Is there a specific filter I should go with. For now the cheapos will work because I am changing the fluid and filter every 500 miles to flush everything out.
I want to put a drain plug in the pan and I noticed a place where there is an indent in the pan. Looks like a nice place to put the plug, however it is elevated above the rest of the pan, meaning not everything will drain that way. I always worry about the clearance issue when putting in a drain plug.
