complete standard trans set up
Postby markmitch [OP] » August 30th 2020, 4:56am
Today August 29th I went to a pick n pull in Stockton Ca I seen a 198 chevy Astro with 4.3 & 5 speed transmission complete set up ped , clutch assembly master cylinder and transmission. If anyone is looking for this stuff its there.
Firing on 5 Cylinders (L6)
Topics: 606
Images: 20
Extra Info: RS V8
Re: complete standard trans set up
Postby Casey » September 11th 2020, 4:42am
Wow, someone should grab as much as they can. Must've been an '86 or '87 (IIRC, those were the two years the 4.3L & T-5 were offered from the factory...and assuming the parts on the van are factory installed here). The shifter assembly, trans case, and pedal bracketry are all unique to the M-van.
Casey
Years of Membership: Casey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full years
Topics: 24
Extra Info: 4.3L LT 5-speed
Postby markmitch [OP] » September 11th 2020, 5:00am
Its an 89 and its still there as I grabbed the dash gauge assembly today. But its to much work for me to grab and to much to spend hoping to recoup the money since I can't use a stick with y bad shoulder.
Topics: 606
Images: 20
Extra Info: RS V8
Postby Casey » September 11th 2020, 5:10am
I understand. I wasn't meaning you personally, but if someone close sees this, they shouldn't hesitate.
If you wouldn't mind, could you post a picture of the instrument cluster, please? I've still got the auto cluster in my '95, and am curious what the manual cluster looks like. Is it a digital or analog (sweep style) cluster?
Casey
Topics: 24
Postby AstroWill » September 11th 2020, 5:16am
Getting harder to find all the time for the very few people that want to install a manual transmission. Hopefully someone will save it.
Topics: 106
Images: 438
Postby markmitch [OP] » September 12th 2020, 2:08am
the gauge assembly looks exactly like mine since mine is an 89 the only difference is the little spot that shows what gear your in is blacked out. But it will not fit in the 95 totally different assembly.
Topics: 606
Images: 20
Extra Info: RS V8
Postby icebrrg3rd » September 12th 2020, 5:19am
Hey Mark, if you do go back, could you take a picture (or a few) of the under dash showing how and where the clutch pedal is mounted? If you actually grab the part (I think it's bolted in, IIRC) I will gladly pay the cost of the part, the shipping, and a few extra for you for doing it. I don't need the master cylinder or linkage, just the pedal assembly. If you do grab the part, could you take a few pics of the mounting location for reference? I would much appreciate it.
-Andrew
91 Chevy Astro 5L 5-speed, Ford 9" 261k mi
02 Chrysler Sebring Conv. 2.7L 5-speed 213k mi
10 Chrysler Town & Country 3.8L 180k mi
icebrrg3rd
Firing on 5 Cylinders (L3)
Topics: 49
Alias (AKA): Andrew
Van Model Year: 1991
Postby markmitch [OP] » September 24th 2020, 3:22am
Sorry I have not been back there and most likely won't till the last week of this month when I get paid again. I will take a peak and if its there I sure will grab the pedal and take some pictures. Mark
Topics: 606
Images: 20
Extra Info: RS V8
Return to Manual
It is currently October 21st 2020, 1:30pm
Manual Forum
ManualGM Astro/Safari vans were produced with a 4-speed manual or a 5-speed manual transmission. Manual transmissions feature a driver-operated clutch and a movable gear stick which are commonly swapped with automatics in custom applications and transmission conversions.
To create a new topic in Manual, click this button:
Casey
in Manual
Date: Sep 11 '20
Time: 5:20am
Attached by: icebrrg3rd
icebrrg3rd
in Manual
Date: Jun 06 '16
Time: 8:18pm
doyoulikeithere
in Manual
Date: Jan 22 '12
Time: 10:25pm
Casey
in Manual
Comments: 13
Date: Nov 14 '09
Time: 9:32pm
Attached by: SS Astro
SS Astro
in Manual
Comments: 19
Date: Jul 21 '09
Time: 6:45am
