Fuel Gauge needle "bouncing"
Postby Surfin Safari [OP] » July 13th 2016, 6:48pm
I noticed yesterday that my Fuel gauge bounces around. The PO told me not to trust it so I use the DIC to monitor my fuel usage. when I get to around 18 gal used I head to a fill up Is this a bad float / sending unit?
Fuel Gauge "Bouncing"
Click on the image to see it move (I converted it to a GIF)
Surfin Safari
Years of Membership: Surfin Safari has been a member for 5 full yearsSurfin Safari has been a member for 5 full yearsSurfin Safari has been a member for 5 full yearsSurfin Safari has been a member for 5 full yearsSurfin Safari has been a member for 5 full years
Topics: 9
Alias (AKA): Noah
  • Fuel pump and ECM issue
    by Dbleeger » April 2nd 2021, 12:39pm in Electrical
    April 3rd 2021, 11:08pm
  • Fuel pump relay wire color?
    by SoccerMom4x4 » July 1st 2021, 2:27am in Electrical
    July 2nd 2021, 8:48pm
    9
    40
    July 26th 2021, 1:17am
Re: Fuel Gauge needle "bouncing"
Postby chevymaher » July 13th 2016, 8:03pm
That isn't to bad. Wow drive a chevelle. 3/4 tank and nail it and it goes down to empty. Let off it goes back up. You read it driving at a steady speed.
I wouldn't worry about it. Take a 2 gallon can of gas and run it to empty. I bet it is working fine. Just jiggly. There is a buffer in the system that slows the reading form bouncing like that. I bet that is what is wrong. And no I don't know where it is. Chevelle don't have a buffer at all and that is why they are are over the place.
Topics: 91
Postby redfury » July 14th 2016, 5:03am
The system takes a 240 ohm system and coverts it to a 0-100 ohm signal to the dash. It's a known problem. I replaced my fuel pump with a Delphi and had the same problem of a buzzing gauge to the point where you could hear it some times. I never really engaged in doing much in the way of testing, but I'm guessing there might be a body ground that isn't too happy. My gauge only really ever read accurately when it was down to a quarter tank. I always just filled up between 200-250 miles and kept track of every fill up. If you put the computer into a relearn position though, fill up at 150 miles for at least 2 tanks so you don't risk running out of gas ( ask me how I know? )
redfury
Firing on 8 Cylinders (L3)
Topics: 53
Images: 13
Extra Info: LT 5.7L 4wd
Postby WoodButcher » July 14th 2016, 12:03pm
The PRND lights must look pretty at night,,, :rofl:
In my '97 the gauge bounces with my turn signal and has been like that since I got it in '00.
WoodButcher
Firing on 6 Cylinders (L6)
Topics: 30
Images: 514
Alias (AKA): Bruce
Extra Info: 5.7L RWD
Postby Surfin Safari [OP] » July 14th 2016, 4:18pm
redfury wrote:The system takes a 240 ohm system and coverts it to a 0-100 ohm signal to the dash. It's a known problem. I replaced my fuel pump with a Delphi and had the same problem of a buzzing gauge to the point where you could hear it some times. I never really engaged in doing much in the way of testing, but I'm guessing there might be a body ground that isn't too happy. My gauge only really ever read accurately when it was down to a quarter tank. I always just filled up between 200-250 miles and kept track of every fill up. If you put the computer into a relearn position though, fill up at 150 miles for at least 2 tanks so you don't risk running out of gas ( ask me how I know? )
OK. How do you know?
Surfin Safari
Topics: 9
Alias (AKA): Noah
Postby Leeann_93 » July 14th 2016, 10:39pm
I'm told (but I've never investigated) that the wiring bundle that runs under the battery is the cause of this - battery acid drips down and eats the insulation and you'll have a googy wire (technical term). Or the connection on the firewall is loose and has a burned spot.
Topics: 45
Postby WimpTech » July 14th 2016, 10:43pm
my '99 (Creeper Van) had a fuel gauge that was seriously nervous... or smoked out on crack because it would shake violently. I jiggled wires, didn't help, so I just took the middle of the shake as where it really is and never got under 1/4 tank. Problem solved... OK, not, how about... managed. ALthough I do feel kinda dumb that I didn't think of using the ole navi-computer... D OH!
:dunce:
WimpTech
Firing on 4 Cylinders (L5)
Topics: 39
Images: 322
Alias (AKA): =Wimpy=
Extra Info: Retired
Postby Paradise97401 » July 16th 2016, 7:46am
in my 2002 Safari, had the same issue...it was the fuel pu,p that went out after the gauge started bouncing..replaced the fuel pump...everything is good now
Paul
Eugene, OR
Paradise97401
Years of Membership: Paradise97401 has been a member for 9 full yearsParadise97401 has been a member for 9 full yearsParadise97401 has been a member for 9 full yearsParadise97401 has been a member for 9 full yearsParadise97401 has been a member for 9 full yearsParadise97401 has been a member for 9 full yearsParadise97401 has been a member for 9 full yearsParadise97401 has been a member for 9 full yearsParadise97401 has been a member for 9 full years
Van Model Year: 2002
Extra Info: SLE 4.3L RWD
It is currently July 26th 2021, 1:17am
zz88008
Time: 8:09pm
OldSchoolNoeOldSchoolNoe is online!
Date: Jul 23 '21
Time: 8:34pm
Rockridge
Date: Jul 13 '21
Time: 11:08pm
silverastro
Date: Jul 04 '21
Time: 2:35pm
SoccerMom4x4
Date: Jul 02 '21
Time: 6:21pm
