Best cold weather Battery
Postby Jhouserjr [OP] » September 22nd 2016, 1:01pm
I am going to spend a month camping and skiing in the Colorado Rockies this winter. It is about time for me to replace the battery on my 2004 Astro. Would somebody from where the winters are bitterly cold give me a recommendation on which battery I should buy?
TIA,
John
Jhouserjr
Years of Membership: Jhouserjr has been a member for 10 full yearsJhouserjr has been a member for 10 full yearsJhouserjr has been a member for 10 full yearsJhouserjr has been a member for 10 full yearsJhouserjr has been a member for 10 full yearsJhouserjr has been a member for 10 full yearsJhouserjr has been a member for 10 full yearsJhouserjr has been a member for 10 full yearsJhouserjr has been a member for 10 full yearsJhouserjr has been a member for 10 full years
Topics: 21
Extra Info: AWD passenger
  • Anybody relocate the the engine battery?
    by Ironhide » July 28th 2020, 1:37am in Electrical
    Last post by Old Barney View the latest post
    August 2nd 2020, 2:11pm
  • battery drain
    by chris in b'ham » August 3rd 2020, 8:09pm in Electrical
    Last post by maximus7001 View the latest post
    August 3rd 2020, 9:56pm
    58
    January 23rd 2021, 8:35am
Re: Best cold weather Battery
Postby Corsemoto » September 22nd 2016, 4:38pm
I would look at AGM batteries, I've had good results with Sears Diehard Platinum AGM (Odyssey brand though no longer sold by Sears) and Pep Boys Bosch Platinum AGM (Exide Edge) that has a great warranty - 4 year free replacement & 3 year free roadside/jumpstart.
AGM are good in cold temperatures, lower internal resistance, low self discharge, less prone to sulfation and can charge faster though may require using charger with AGM specific charging profile.
I picked up the Bosch at Pep Boys with 30% online promo and $20 mail in rebate. That being said, having a battery with a good warranty and easily accessible locations to replace if necessary can be pretty important too.
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Postby MI_Ghost » September 22nd 2016, 8:07pm
If your are going to be parked for more than a couple days. A battery blanket might help also.
https://www.amazon.com/10952544-Battery ... 879&sr=1-3
~Ghost
Ast' Cargo: 2001 Astro Cargo
Beauty: 2009 Impala LT
MI_Ghost
Images: 107
Alias (AKA): Ghost
Van Model Year: 2001
Extra Info: Big White RWD Box
Postby paulo57509 » September 22nd 2016, 9:52pm
IMO, any new battery will be fine. There are other things that you can do as well to prep for harsh winters.
I spent three winters in Butte, MT where it could (and did) stay cold for months at a time at temps between 20F and -40F. Never had an issue with starting the engine with a generic (Sears) lead-acid battery.
I installed an engine heater and always carried an extension cord. I used the type that you just splice into one of the heater hoses. I forget the brand but the heater would also circulate the coolant. If it sat overnight, it was plugged in. I also used a straight 10w oil in the engine in case I couldn't find an electrical outlet.
Don't forget to pack a shovel and a bag of kitty litter.
paulo57509
Firing on 7 Cylinders (L1)
Topics: 24
Extra Info: RWD
Postby dramey » September 27th 2016, 8:27am
No matter which battery you buy, look at the Cold Cranking Amps. The higher the CCA, the easier it will start in the cold and the longer the charge will last.
dramey
Extra Info: AWD Cargo Van
Postby AstroWill » September 28th 2016, 7:28am
Personally, I go for the largest one that will fit, and I like the ones with side and top terminals. Keep it topped up with a solar/trickle charger when not being actively used. Other than that any decent battery will work just fine. Never had a problem with my cheap *** walmart batteries while living in, wow I hate to admit living there, but it was only for a few years, Maine.
Just to be clear, I'm not FROM Maine, never reproduced with anyone there, I was only on an extended visit ;)
Images: 460
It is currently January 23rd 2021, 8:35am
OldSchoolNoe
Date: Jan 19 '21
Time: 2:15am
OldSchoolNoe
Date: Jan 16 '21
Time: 9:23pm
Comments: 9
Date: Jan 15 '21
Time: 5:08am
Attached by: markmitch
Date: Jan 04 '21
Time: 6:15pm
doogaloo
Date: Jan 04 '21
Time: 11:53am
