where does this connector plug in?
Postby fourwheelwheelie [OP] » November 16th 2016, 4:36am
Hi all,
While hunting down why the panel vents were not working on the climate control (vacuum leak), I happened to look down and see a 2 wire plug just hanging there. 5 wires come out of main loom, 1 ground, 2 in a connector for the A/C accumulator, and 2 others in another grey push on connector with a clip just like the other one. Where does it plug into? There is enough wire to reach about 6" away from the A/C accumulator. Help?
62561
fourwheelwheelie
Years of Membership: fourwheelwheelie has been a member for 4 full yearsfourwheelwheelie has been a member for 4 full yearsfourwheelwheelie has been a member for 4 full yearsfourwheelwheelie has been a member for 4 full years
Topics: 21
Images: 20
Alias (AKA): Jebbster
Extra Info: Tiara Conversion
Re: where does this connector plug in?
Postby AstroWill » November 16th 2016, 4:38am
lol, I think we really need a sticky about these connectors.
Images: 463
Postby fourwheelwheelie [OP] » November 16th 2016, 4:45am
does nothing.
welcome to the next level?
thank you astrowill :)
fourwheelwheelie
Topics: 21
Images: 20
Postby MI_GhostMI_Ghost is online! » November 16th 2016, 6:05am
IIRC That is a test connector used for diagnostics for things like the fuel pump.
~Ghost
Ast' Cargo: 2001 Astro Cargo
Beauty: 2009 Impala LT
Images: 107
Alias (AKA): Ghost
Van Model Year: 2001
Extra Info: Big White RWD Box
Postby WoodButcher » November 16th 2016, 1:18pm
Yep, there are a number of them on the harness, there is a fuel pump test connector, rear window washer pump, bunch of others too for options the van may or may not have. Cheaper to make one harness with everything than to stock different ones for each application.
WoodButcher
Firing on 5 Cylinders (L6)
Topics: 30
Images: 514
Alias (AKA): Bruce
Extra Info: 5.7L RWD
Postby sixsix » November 16th 2016, 3:56pm
fourwheelwheelie wrote:Where does it plug into?
Just as Woody said:
Xtra Plugs and Connectors - GM = Generous Motors.
That plug is generally referred to as the "Rear or Hatch Window Washer Power" plug. I have heard that there are 2 motors in one tank servicing both Windows.
If wrong - chime in.
Mike
Well, after all... what would Banacek say ?... Anyone that condones the actions of the American People during the Storming of the Capitol are as complicit as the Assholes themselves.
But no way does this let the Democrats or the MSM off the Hook.
Firing on 5 Cylinders (L5)
Topics: 38
Images: 1320
Postby One-Eye » March 11th 2017, 12:26am
Well, yes and no Mike. There is a plug there for the second washer motor, but there is also one there that is not plugged into anything that has a different plug color. Seems to be on most if not all Astros.
'85 Cargo - First Astro, Recycled.
'89 Customized Shorty - Up for Sale, 225k, still running.
'03 Regency Hightop, 4.3L, X VIN
Mods: AWD converted to RWD (More mods to follow).
One-Eye
Years of Membership: One-Eye has been a member for 4 full yearsOne-Eye has been a member for 4 full yearsOne-Eye has been a member for 4 full yearsOne-Eye has been a member for 4 full years
Alias (AKA): Bernie
Extra Info: Regency Hightop
Postby Rinny » March 11th 2017, 12:41am
Might be for the rear heater?
03Astro AWD/4WD
TorsenDiffs,3:73'S,VettServo
NP236TC
Dual Piston Rear Calipers
GY DTrac 235/85/R16
ARB &/Custom bumpers
2x6x1/4 Rockrails
Rinny
Years of Membership: Rinny has been a member for 5 full yearsRinny has been a member for 5 full yearsRinny has been a member for 5 full yearsRinny has been a member for 5 full yearsRinny has been a member for 5 full years
Images: 6
Extra Info: 5.7L NP236
Postby sixsix » March 11th 2017, 1:32am
One-Eye wrote: ... but there is also one there that is not plugged into anything that has a different plug color. Seems to be on most if not all Astros.
Seems if it's a smaller conn. than the one that was pictured by the OP - it is probably the "Fuel Pump Test" conn. - it is in the same vicinity / by the AC stuff / washer bottle area.
Leeann clued me in on this - might want to double check w/ her.
Mike
Topics: 38
Images: 1320
It is currently January 25th 2021, 9:34pm
OldSchoolNoe
Date: Jan 19 '21
Time: 2:15am
OldSchoolNoe
Date: Jan 16 '21
Time: 9:23pm
Comments: 9
Date: Jan 15 '21
Time: 5:08am
Attached by: markmitch
Date: Jan 04 '21
Time: 6:15pm
doogaloo
Date: Jan 04 '21
Time: 11:53am
Users browsing this forum: No registered users and 17 guests
