Full battery but won't crank
Postby butch27 [OP] » December 16th 2016, 5:25pm
My '92 Astro ran fine yesterday BUT nothing today. Won't crank feels like ign switch isn't connecting at all. Help. Thanks Butch
butch27
Years of Membership: butch27 has been a member for 12 full yearsbutch27 has been a member for 12 full yearsbutch27 has been a member for 12 full yearsbutch27 has been a member for 12 full yearsbutch27 has been a member for 12 full yearsbutch27 has been a member for 12 full yearsbutch27 has been a member for 12 full yearsbutch27 has been a member for 12 full yearsbutch27 has been a member for 12 full yearsbutch27 has been a member for 12 full yearsbutch27 has been a member for 12 full yearsbutch27 has been a member for 12 full years
Topics: 37
Alias (AKA): butch27
Re: Full battery but won't crank
Postby TurnNburn » December 16th 2016, 5:59pm
How are your battery terminals and connections? A voltmeter would say you had a full battery but if the wires are loose then your going to get a no go situation. Or ignition switch. Did you try jumping around in the back above the gas tank?
TurnNburn
Green Status (L4)
Green Status (L4)
Alias (AKA): iGoogle
Postby AstroWill » December 16th 2016, 6:19pm
TurnNburn wrote:Did you try jumping around in the back above the gas tank?
:rofl:
Images: 472
Postby WimpTech » December 16th 2016, 6:22pm
Look for corrosion between wire strands on the battery cable, green is no go.
WimpTech
Firing on 4 Cylinders (L5)
Topics: 38
Images: 322
Alias (AKA): =Wimpy=
Extra Info: AWD 3+1 Lift
Postby butch27 [OP] » December 16th 2016, 7:44pm
Have not jumped in rear. The fuel pump doesn't even cycle.
butch27
Topics: 37
Postby WimpTech » December 16th 2016, 7:48pm
....and the cables? Terminals?
WimpTech
Topics: 38
Images: 322
Postby Astro Pop » December 16th 2016, 8:04pm
^^^^^^ I second the motion. sounds like corrosion at battery.
Astro Pop
Topics: 41
Images: 9
Alias (AKA): Xfirepop
Van Model Year: 1996
Extra Info: AWD - 5 inch lift
Postby TurnNburn » December 16th 2016, 8:11pm
Does every thing else in the car work? Door locks, dash lights, windows? If nothing works, probably still your battery.
Your fuel pump not cycling wont cause your starter not to turn.
TurnNburn
Green Status (L4)
Green Status (L4)
Postby astrotardis » December 16th 2016, 9:11pm
Check wire connections on the starter , alternator, battery, and the ground connections ,check starter relay fuse the 50amp one I think . may be the ignition but I would check. Them all
astrotardis
Years of Membership: astrotardis has been a member for 4 full yearsastrotardis has been a member for 4 full yearsastrotardis has been a member for 4 full yearsastrotardis has been a member for 4 full years
Topics: 16
Images: 3
Alias (AKA): Rick
Postby butch27 [OP] » December 17th 2016, 4:09pm
Where is the starter relay fuse located??
butch27
Topics: 37
Postby WimpTech » December 17th 2016, 4:21pm
Fuse box under hood, diagram on lid.
Did you check the other things we listed?
WimpTech
Topics: 38
Images: 322
Postby butch27 [OP] » December 18th 2016, 10:51pm
It was the BATTERY. Read full charge on meter and would not charge up anymore, dead cell overnight.Stupid me.
butch27
Topics: 37
Postby AstroWill » December 19th 2016, 12:04am
butch27 wrote:It was the BATTERY. Read full charge on meter and would not charge up anymore, dead cell overnight.Stupid me.
Glad to hear you got it figured out!
Images: 472
It is currently February 28th 2021, 4:35pm
tungtide
Date: Feb 23 '21
Time: 1:54am
Rockridge
Date: Feb 20 '21
Time: 1:28am
Coronavan
Date: Feb 17 '21
Time: 7:21pm
Attached by: Primusblack
Primusblack
Comments: 21
Date: Feb 17 '21
Time: 4:26am
OldSchoolNoe
Comments: 9
Date: Feb 13 '21
Time: 11:56pm
