Heated seats
Heated seats
Postby smokinjoe [OP] » December 26th 2016, 5:32pm
So firstly Merry Christmas Happy New Year to all.
So I have had heated seat covers for a while now but want to hard wire them into a switched power source. Partly to not take up plug space but also to not kill my battery when I forget them on like I did yesterday on Christmas.
Do I use a relay to run power or just a switched power supply? I am thinking something in the console/doghouse that is switched. Probly a fused line to avoid unwanted fires.
Any ideas or anyone do similar?
These are the ones I bought. They work well.
http://www.ebay.com/itm/Travel-Warmer-P ... Swd3dXFr3e
smokinjoe
Firing on 5 Cylinders (L2)
Topics: 268
Alias (AKA): smokinjoe
Van Model Year: 2002
Extra Info: RWD
Re: Heated seats
Postby WimpTech » December 26th 2016, 5:59pm
Maybe wire in a relay and use account 12v to trigger it? You could still use a switch down stream if you want.
WimpTech
Firing on 3 Cylinders (L5)
Topics: 38
Images: 322
Alias (AKA): =Wimpy=
Extra Info: AWD 3+1 Lift
Re: Heated seats
Postby WoodButcher » December 26th 2016, 6:11pm
I'd use an ignition switched relay using the ACC power, key needs to be in the run or ACC to be on. It would save your battery when you pull the key but you could also run it while the bride is shopping w/o running the motor.
WoodButcher
Firing on 5 Cylinders (L6)
Topics: 30
Images: 514
Alias (AKA): Bruce
Extra Info: 5.7L RWD
Re: Heated seats
Postby Big_kidBig_kid is online! » December 26th 2016, 7:50pm
I haven't put them in the Astro yet (I have a pair of factory heated PT Cruiser seats I might install), but I did heat the seats in the buggy. The kit came from amazon.com. It was about $60, and included everything to do 2 seats except the hog rings and pliers. I bought them seperately and wound up using zip ties instead. I wired them to a switched fuse, the kit came with a relay.
Similar to this one:
https://www.amazon.com/Motosupply-Unive ... ters&psc=1
Firing on 7 Cylinders (L7)
Topics: 185
Images: 337
Extra Info: 2WD 5.7 V8
Re: Heated seats
Postby AstroWill » December 28th 2016, 1:24am
Definitely use a relay, prefer a trigger that is only on when the key is on, not when cranking.
Images: 460
It is currently January 23rd 2021, 5:52pm
OldSchoolNoe
Date: Jan 19 '21
Time: 2:15am
OldSchoolNoe
Date: Jan 16 '21
Time: 9:23pm
Comments: 9
Date: Jan 15 '21
Time: 5:08am
Attached by: markmitch
Date: Jan 04 '21
Time: 6:15pm
doogaloo
Date: Jan 04 '21
Time: 11:53am
