1995 Astro, no electricity to starter
Postby WaltDaddy [OP] » March 13th 2011, 11:07pm
My fiancee has a 1995 Astro. Two weekends ago, she was out running errands and while she was at the beauty parlor the van wouldn't start. I had it towed home and today was my first chance to work on it.
I got underneath and pulled the starter. I had the starter tested at the auto parts store and it's good. I got back underneath with a test light and determined that there is no power getting to the starter.
I do not know the technical terms, but the big wires that are supposed to have constant power have nothing and the small wire that is supposed to be switched with the ignition also has nothing.
I do not know what to check next, hopefully one of you knowledgeable folks can point me in the right direction.
Walt
WaltDaddy
Years of Membership: WaltDaddy has been a member for 9 full yearsWaltDaddy has been a member for 9 full yearsWaltDaddy has been a member for 9 full yearsWaltDaddy has been a member for 9 full yearsWaltDaddy has been a member for 9 full yearsWaltDaddy has been a member for 9 full yearsWaltDaddy has been a member for 9 full yearsWaltDaddy has been a member for 9 full yearsWaltDaddy has been a member for 9 full years
Alias (AKA): Walt Daddy
Extra Info: V6 RWD
RESOLVED: 1995 Astro, no electricity to starter
Postby WaltDaddy [OP] » March 14th 2011, 12:45am
I decided to start from the beginning. I disconnected the positive and negative cables from the battery and then reassembled everything and the van started.
WaltDaddy
Extra Info: V6 RWD
Re: 1995 Astro, no electricity to starter
Postby Leeann_93 » March 14th 2011, 3:16am
Might just have been corrosion on the ends and disassembling/reassembling cleaned them off. Might have been a loose ground wire that you reconnected tightly. Who knows? Just glad you got her starting.
Postby GaryZ » March 15th 2011, 3:58am
I'll bet that Leeann_93 has it right. The large cable on the starter is a direct link to the battery. No relays, connections, fuses, etc. The battery cable ends had to have been dirty. I suggest that you take them off again and clean them with a wire brush.
'98 Astro AWD, white with gray interior,
3.42:1 diffs, 235/70 x 15 tires,
195,000 miles on original engine and trans
'99 Kawasaki ZX11D
'85 Yamaha Venture Royale with 1300 engine & Vmax cams
GaryZ
Years of Membership: GaryZ has been a member for 11 full yearsGaryZ has been a member for 11 full yearsGaryZ has been a member for 11 full yearsGaryZ has been a member for 11 full yearsGaryZ has been a member for 11 full yearsGaryZ has been a member for 11 full yearsGaryZ has been a member for 11 full yearsGaryZ has been a member for 11 full yearsGaryZ has been a member for 11 full yearsGaryZ has been a member for 11 full yearsGaryZ has been a member for 11 full years
Postby chevymaher » March 15th 2011, 12:24pm
GaryZ wrote:I'll bet that Leeann_93 has it right. The large cable on the starter is a direct link to the battery. No relays, connections, fuses, etc. The battery cable ends had to have been dirty. I suggest that you take them off again and clean them with a wire brush.
Pour coke the drink on them before you use brush.Something in coca-cola eats battery corrosion.melts it like hot water on snow.
It is currently December 1st 2020, 3:25pm
Dbleeger
Comments: 14
Date: Nov 27 '20
Time: 11:29pm
tungtide
Date: Nov 23 '20
Time: 4:40pm
Comments: 24
Date: Nov 20 '20
Time: 8:18am
Date: Nov 20 '20
Time: 1:16am
Date: Nov 19 '20
Time: 8:00pm
