CS130D to AD244 145 amp Alternator upgrade - '94 Astro
Postby wiky_d_whack [OP] » January 25th 2017, 12:19am
The Background:
Since I am looking to charge an aux battery and run a few extra lights I decided to upgrade my alternator. After searching the forums and only finding upgrades to 200+ amp alternators, dual alternators ( I am not trying to power half a city block) or ones that involved custom brackets mounts I decided to check out forums for other trucks that had the GM vortec 4.3L engine.
I found this wonderful s-10 forum detailing exactly the swap I wanted to do:
http://www.s10forum.com/forum/f27/how-to-high-output-ad244-alternator-for-80-a-376788/
This guy did all the hard work researching various alternators and explains pretty well how most high amp alternators do not charge well at low rpm (like or Astros that Idle at about 600-700 rpm) and why the AD244 is a great option to upgrade the stock CS130D alternator
So I decided to purchase an AD244 alternator. I will probably kick myself in the *** later for purchasing a rmfd Alternator, but I was getting impatient and O'Riley had a Rmfd Delco/Delphi series alternator for $150.
O'Riley part number R112011A
Napa Part number RAY2134812
The compatibility lists: Chevy Avalanche, Express, Silverado, Suburban, Tahoe, Trailblazer etc. (most are 2003-2004 or 2005-2006 model years)
couple other links and purchasing options, some with same case and higher amps:
http://www.motorcityreman.com/gmad2441wire.html
http://store.alternatorparts.com/ad244hd145-heavy-duty-145-amp-alternator.aspx
*** You will need a longer belt. I used one that is 1" longer then the stock belt so for my '94 with AC that would make it 100 1/2".
The Swap:
Note: I do not currently have my AC lines in place so I am not sure how easy this swap is if you have all the lines connected. I would assume they are not too much in the way...
First I removed the old alternator.
After taking the belt off there are 3 bolts holding the alternator down: two in the front and one to the back of the case most easily accessed if you remove the dog house. The front passenger side bolt is a 10mm and screws directly into the alternator case. The right passenger bolt is I think a 14mm or 13mm and has a nut on the back side of the bracket.
I unplugged the weather pack connector and detached the cable of the post in the back. The alternator comes right out. I also removed the extension for my oil dipstick just to get it out of the way.
Here is the picture of the two alternators side by side.
64353
Both connectors are identical
AD244
64361
CS130D
64369
I removed the tensioner to give myself more room it is held on by a 13mm bolt that has a nut in the back.
Next I realized that the bolt that came out of the passenger side front bracket was a) too short and b) smaller diameter then the corresponding hole in the new alternator bracket. Since the mount is held in place by 3 14mm bolts I decided to take it off to make it easier to drill out the hole to fit a M10 bolt.
Alternator mount
64377
64385
If you are crafty you might be able to do it in place although it is pretty tight in there.
This step I don't think is necessary but in case it was I decided to give it a try:
There is a black bracket in the back of the mount whose only purpose was to hold the back of the old alternator. After doing this quick mod I don't think it is was entirely necessary (as pointed out in the s-10 forum) But since it is done I will talk about it anyways.
I decided to cut one end of it off to rotate the bracket just enough that once I get a longer bolt and shim I can thread a bolt through the front passenger side bracket all the way to the back mount to give the alternator a little more support. Like I said I don't think this is necessary because as Dkgarnet96 pointed out the AD244 has a much wider bracket then the CS133D alternator on that side and that should keep the alternator from wanting to be pulled down and to the front by the tension of the belt.
64393
64401
64409
I lined the black bracket up on the back of the mount in line with the hole on the front of the mount. I threaded in the 14mm bolts to hold the mount back in its original place on the engine and tightened it just enough to eliminate any play but not so tight that I can't adjust the placement of the back bracket. I then put the alternator in place. Threaded the driver side bolt in (used the bolt and nut that came off the old alternator)
and place a 1/4" long extension through the mount, the bolt hole on the alternator all the way to one of the holes of the back bracket.
Now that I had all that lined up I tightened down the 3 14mm bolts of the mount. I took out the long extansion and connected all the wires and put the last bolt in.
Front view
64417
Back view
64425
Back to the swap
For the bolt on the driver side part of the mount I used a ~3" M10 bolt through the hole I drilled and into the mounting hole on the alternator with a nut on the back. It was a pretty tight fit and had to basically screw it into place to get it through both the mounts.
You may have to grind down the AD244 alternator case and the case of the tensioner a tiny bit at the point where they come together (I just used a hand held file and took off about 1mm each). It is tight in there and I am not sure if it was the new tensioner I put in recently or if they are all exactly that size but once I bolted everything in the tensioner didn't want to budge. So I would suggest putting the new alternator all the way in, screwing the tensioner in place and then seeing if it moves like it should before routing the belt. If it feels stuck. take the tensioner off and file a little bit off where they touch and up to the point where you will need it to rotate to.
Tensioner in place
64433
Where I began to file
64441
I filed off that little tab and then a little bit up and away from the arm.
When it moves smoothly it is time to put the belt on an enjoy your new 145 amp Alternator! :driving: :rockon:
64449
Thanks to CopperFiremist for the support and space to get this done! and Dkgarnet96 for lending a hand and problem solving. :ty:
wiky_d_whack
Years of Membership: wiky_d_whack has been a member for 6 full yearswiky_d_whack has been a member for 6 full yearswiky_d_whack has been a member for 6 full yearswiky_d_whack has been a member for 6 full yearswiky_d_whack has been a member for 6 full yearswiky_d_whack has been a member for 6 full years
Topics: 10
Images: 15
Extra Info: CS 4.3L V6 AWD W
  • New HO 145 Amp Alternator Upgrade
    by Mmusicman » September 22nd 2020, 8:08pm in Electrical
    September 23rd 2020, 5:28pm
  • Good High End Alternator?
    July 4th 2020, 2:16am
    December 4th 2020, 1:17pm
Re: CS130D to AD244 145 amp Alternator upgrade - '94 Astro
Postby dkGarnet96 » January 25th 2017, 2:35am
This is a pretty sweet mod, good write up :thumbup:
-96 AWD 350k- R.I.P with a spun bearing
dkGarnet96
Years of Membership: dkGarnet96 has been a member for 5 full yearsdkGarnet96 has been a member for 5 full yearsdkGarnet96 has been a member for 5 full yearsdkGarnet96 has been a member for 5 full yearsdkGarnet96 has been a member for 5 full years
Images: 6
Van Model Year: 1996
Extra Info: 4.3 awd
Postby CopperFiremistCopperFiremist is online! » January 25th 2017, 3:18am
Think this post is worthy of a Sticky? Maybe it should be called the "Big Four Upgrade" :poke:
Pullin The Pass
Firing on 1 Cylinder (L2)
Topics: 24
Images: 6
Alias (AKA): B
Extra Info: LS Swap
Postby AstroWill » January 25th 2017, 3:22am
Good writeup, it's the most common alternator upgrade and well worth it if you use a lot of juice.
Images: 443
Postby markmitch » January 25th 2017, 3:52am
great write up but it would not work on a 1st gen van , but thanks for adding it to the forum. Mark
Firing on 6 Cylinders (L6)
Topics: 615
Images: 20
Extra Info: RS V8
Postby Astrofarian » January 25th 2017, 4:10am
:whack:
markmitch wrote:great write up but it would not work on a 1st gen van , but thanks for adding it to the forum. Mark
....Uh, did I miss a meeting or is wicky_d_wack's 94 Astro not a 1st Gen van? Or, did you miss that part, Mark? :whack:
Don't mind me, Wicky/Copper/DKGarnet, I just can't let an opportunity to whack someone with a stick pass me by. You know how that works, right? LoL
-M!ke-
Astrofarian
Alias (AKA): M!ke
Extra Info: Someday......
Postby CopperFiremistCopperFiremist is online! » January 25th 2017, 4:14am
Last time I checked it was 1st Gen. :cheers:
Pullin The Pass
Topics: 24
Images: 6
Alias (AKA): B
Extra Info: LS Swap
Postby Astrofarian » January 25th 2017, 4:42am
CopperFiremist wrote:Last time I checked it was 1st Gen. :cheers:
Yeah but I called "DIBS" so I get 1st swing, ok?
-M!ke-
Astrofarian
Alias (AKA): M!ke
Postby AstroWill » January 25th 2017, 4:46am
The difference is the CS-130 vs CS-130D, two different alternators, and they started using the 130D in 94, so it just depends on what you got in there to start with.
You could change the plug on vehicles that came with the CS-130, but it's not plug-and-play like the CS-130D to AD244 swap.
Images: 443
Postby Lumpy » January 25th 2017, 3:58pm
I'd like to see the pics show as something other than click required thumbnails.
Seeing the work involved in the "other" style alternator mounting makes me really appreciate how simple it is in my 89.
Postby markmitch » January 25th 2017, 4:26pm
Oh sorry you are correct,EXCUSE ME! But I assumed it was second gen by the plug shown in the pictures as my plug/ is tiny compared the the one shown. Also my alternator has a big red wire that goes down to the starter. And my brackets are totally different and are made of steel so this write up will NOT work for me. I have owned many of these vans all 1st gen and it seems to me they used many different set ps for brackets on these early vans. Hope you all have a great day, Mark
Topics: 615
Images: 20
Extra Info: RS V8
Postby AstroWill » January 25th 2017, 9:28pm
Lumpy wrote:I'd like to see the pics show as something other than click required thumbnails.
That is just what happens when you link the images using the gallery function.
Images: 443
Postby Lumpy » January 26th 2017, 2:37pm
Postby AstroWill » January 26th 2017, 2:51pm
Images: 443
Postby Lumpy » January 26th 2017, 3:05pm
Then don't use the **** gallery function.
Postby AstroWill » January 26th 2017, 3:17pm
Lumpy wrote:Then don't use the **** gallery function.
I don't think we have one of those, maybe it's in the explicit section.
Images: 443
Postby sixsix » January 26th 2017, 10:13pm
I saw in his profile that he has the " W " Motor.
Could that possibly be why there is such a difference in some Accessories and their respective Brackets?
His old stuff and bracket looks like our " W " Motor's.
Maybe there are changes in the Alternator - Option, etc requiring more / less Amps. Upfitter or Not.
Just a guess and ...
:twocents-02cents: :twocents-mytwocents: :2:
Mike
Well, after all... what would Banacek say ?... “May be hard to believe... President Trump should rest easy and concede what was in fact a foregone conclusion: Another OLD MAN won with only about 50% of the Change Believers/Fools showing up."
Firing on 4 Cylinders (L5)
Topics: 38
Images: 1303
Postby Lumpy » January 26th 2017, 11:37pm
I"m not sure if it's W vs Z. I think there's som Gen I Z's that had the "other" setup from mine.
As you face my engine looking in from the front bumper -
My AC compressor is at 10 o'clock, alternator at 2 o'clock. Alt is really simple to access. AC is likely the most difficult to install and remove of any component I've ever seen on any vehicle.
Postby gates » February 3rd 2017, 11:51pm
Anyone have a belt part number for the longer one? Or do you just take the old one to the parts store and figure it out?
I'd like to have one ready to go with the install
Also any reason why I shouldn't install this model?
I have two batteries for camping and a single 12 inch subwoofer or is the 145Amp more than enough?
Only 20 dollars more....
http://www.ebay.com/itm/New-Alternator- ... nd&vxp=mtr
gates
Years of Membership: gates has been a member for 4 full yearsgates has been a member for 4 full yearsgates has been a member for 4 full yearsgates has been a member for 4 full years
Topics: 5
Alias (AKA): Kenny
Extra Info: 4.3 AWD Conversion
Postby zach914v8 » February 4th 2017, 12:09am
This was an awesome post and it is going to help me a lot. Thanks for the information.
My Rides:
1974 Porsche 914 powered by a 305 Chevy v8.
1994 GMC Safari TBI 4.3, Lifted 4"
zach914v8
Years of Membership: zach914v8 has been a member for 11 full yearszach914v8 has been a member for 11 full yearszach914v8 has been a member for 11 full yearszach914v8 has been a member for 11 full yearszach914v8 has been a member for 11 full yearszach914v8 has been a member for 11 full yearszach914v8 has been a member for 11 full yearszach914v8 has been a member for 11 full yearszach914v8 has been a member for 11 full yearszach914v8 has been a member for 11 full yearszach914v8 has been a member for 11 full years
Topics: 12
Alias (AKA): ballzach
Extra Info: 4 inch lift
It is currently December 4th 2020, 1:17pm
Dbleeger
Comments: 14
Date: Nov 27 '20
Time: 11:29pm
tungtide
Date: Nov 23 '20
Time: 4:40pm
Comments: 24
Date: Nov 20 '20
Time: 8:18am
Date: Nov 20 '20
Time: 1:16am
Date: Nov 19 '20
Time: 8:00pm
