Alternator Removal/Replacement How-To (2003 Astro)
Postby chemist [OP] » July 6th 2008, 9:53pm
Replacement of an alternator is a general repair. In my case, this happened around 110K miles. There are ways to know you have a bad alternator before your van dies on the middle of the road. In my case, the battery light came on. A battery test revealed the battery was fine. That left another possible suspect--the alternator...uhg. Looking at the voltage output guage was a pretty good indicator too. The folks who tested the battery told me it should be indicating closer to 16/17, but in my case it was reading 14/15.
Now you may have a short somewhere. But some shops, like Advance, will test your alternator for free, so you're just out some time and sanity in pulling it out. Also maybe your battery just dies when parked overnight. That could be a voltage regulator. Unless I'm mistaken, GM put the voltage regulator in your alternator (different from Ford). A bad alternator may leave you needing a tow. Worse, a bad voltage regulator may also fry your battery, so don't waste time waiting for the nerve to get this done. There's no good reason for a backyard mechanic to fail on this, despite how daunting the job of accessing the alternator appears. No specialty tools are required. It just takes a little longer than on your sedan. To give an idea of what is meant here, this is a pic of the alternator:
It's between the air filter housing, the AC lines and just below the oil dipstick...no reason to be discouraged.
To begin, proceed as follows:
Edit (addition): This should have been number 1--safety first. Disconnect the battery. SWMBO made me do this, despite the fact that I like to listen to the radio as I work... The bolts on the side terminals of mine were 8 mm.
1. Remove the air intake as per this procedure:
https://www.astrosafari.com/viewtopic.php?f=9&t=1142
2. Remove the upper fan housing as per this procedure:
https://www.astrosafari.com/viewtopic.php?f=9&t=1143
3. To remove the belt from the alternator, slip a 3/8" extention into the belt tensioner, and pull up on the rachet. A good pic of the tensioner wasn't possible, but here's one showing the location with extension already inserted:
For more details on how to deal with that belt, refer to the removal procedure, here:
https://www.astrosafari.com/viewtopic.php?f=9&t=1144
4. Using a 13mm socket with extension(s) remove the two alternator bolts, located at the bottom of the alternator:
5. The alternator won't just lift right out. It needs coaxing with a pry bar and sturdy screwdriver, seen behind the coolant hose in this pic:
6. Don't just try to yank it out once you've unseated the part, because it's still attached via two wires.
6a. One is on the top, going in through a harness. Pull the clip out and pull the wire harness.
6b. The other is in the back of the alternator, covered by a slip on rubber boot. Slip the boot off and unbolt it (8 or 9 mm socket if memory serves me, but I may be wrong).
7. Now half the job is done. Pull out the alternator, maneuvering as needed, and taking care not to break the plastic fan. And this is what your left with:
Replacement is the exact reverse of this procedure. To seat the alternator properly, I recommend removing the transmission and oil dipsticks and coaxing with a long socket extension (or screwdriver) and mallet.
2003 Chevy Astro, AWD, 124,000 mi
a must read
chemist
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: chemist has been a member for 12 full yearschemist has been a member for 12 full yearschemist has been a member for 12 full yearschemist has been a member for 12 full yearschemist has been a member for 12 full yearschemist has been a member for 12 full yearschemist has been a member for 12 full yearschemist has been a member for 12 full yearschemist has been a member for 12 full yearschemist has been a member for 12 full yearschemist has been a member for 12 full yearschemist has been a member for 12 full years
Topics: 26
  • Good High End Alternator?
    July 4th 2020, 2:16am
  • alternator questions
    by markmitch » July 6th 2020, 6:22pm in Electrical
    July 7th 2020, 11:30pm
    39
    August 9th 2020, 6:36am
Re: Alternator Removal/Replacement How-To (2003 Astro)
Postby rayjay » July 6th 2008, 10:19pm
excellent informative post mate,better than the book!!
rayjay
Years of Membership: rayjay has been a member for 12 full yearsrayjay has been a member for 12 full yearsrayjay has been a member for 12 full yearsrayjay has been a member for 12 full yearsrayjay has been a member for 12 full yearsrayjay has been a member for 12 full yearsrayjay has been a member for 12 full yearsrayjay has been a member for 12 full yearsrayjay has been a member for 12 full yearsrayjay has been a member for 12 full yearsrayjay has been a member for 12 full yearsrayjay has been a member for 12 full years
Alias (AKA): DOG
Postby rmassaro » July 19th 2008, 4:34am
spot on- I was trying to do it at night and didn't remove the fan shroud- talk about some angled torque on a flex head socket! When it gets light out I will do as you show and then take a break. Thanks for the details and pictures.
rmassaro
Years of Membership: rmassaro has been a member for 12 full yearsrmassaro has been a member for 12 full yearsrmassaro has been a member for 12 full yearsrmassaro has been a member for 12 full yearsrmassaro has been a member for 12 full yearsrmassaro has been a member for 12 full yearsrmassaro has been a member for 12 full yearsrmassaro has been a member for 12 full yearsrmassaro has been a member for 12 full yearsrmassaro has been a member for 12 full yearsrmassaro has been a member for 12 full yearsrmassaro has been a member for 12 full years
Alias (AKA): AstroMan959698
Extra Info: Both conversions
Postby Matrixx » September 5th 2008, 1:19am
Hi chemist
Great write up thanks. Just a side note for the older models like my 96, is the alternator with mine has a bracket at the back which bolts up to the rear of it as well as the ones you mentioned above, This is a 10MM bolt which is located in the upper left hand rear corner of the alternator when you face it. I can't see that bracket with your model year but I have on mine. Again thanks very much for the write up chemist, great work. :)
Matrixx
Postby The Many » February 13th 2009, 2:01pm
Great stuff. I am just considering buying an Astro that drains its battery every couple of days (suspect alternator) so this is just what I need!
Thanks.
The Many
Years of Membership: The Many has been a member for 11 full yearsThe Many has been a member for 11 full yearsThe Many has been a member for 11 full yearsThe Many has been a member for 11 full yearsThe Many has been a member for 11 full yearsThe Many has been a member for 11 full yearsThe Many has been a member for 11 full yearsThe Many has been a member for 11 full yearsThe Many has been a member for 11 full yearsThe Many has been a member for 11 full yearsThe Many has been a member for 11 full years
Postby Duck Hunter » February 14th 2009, 5:03am
HI all.... Just replaced my Alternator.. did not take me long get it put in than getting old one out was bit stress!
here's some pictures I just take when put in new ALT in. sorry did not get any on old one coming out.
I did not have to take out the fan cover at all..
at first it was kind hard to get wires off the old ALT.. so go easy on it.
enjoy!
:layrubber:
1998 Chevy Astro
80,000 miles, RWD, 3.23 Gear, 24mpg, LS. Passagers.
Tires 225-70-15R BFGoodRich Long Trail T/A
Duck Hunter
Years of Membership: Duck Hunter has been a member for 11 full yearsDuck Hunter has been a member for 11 full yearsDuck Hunter has been a member for 11 full yearsDuck Hunter has been a member for 11 full yearsDuck Hunter has been a member for 11 full yearsDuck Hunter has been a member for 11 full yearsDuck Hunter has been a member for 11 full yearsDuck Hunter has been a member for 11 full yearsDuck Hunter has been a member for 11 full yearsDuck Hunter has been a member for 11 full yearsDuck Hunter has been a member for 11 full years
Topics: 27
Extra Info: LS 4.3L V6 2WD
Postby Matrixx » February 14th 2009, 12:42pm
Those are great pictures Duck Hunter, Thanks.:)
Matrixx
Postby Raindropp » June 29th 2009, 7:03pm
Does anybody know if a 1999 safari has two or three alternator bolts?
I can only find two, but the car books and "alldata" say there are three.
I don't want to pry on the alternator if there are three!!
Thanks,
raindropp
Raindropp
Years of Membership: Raindropp has been a member for 11 full yearsRaindropp has been a member for 11 full yearsRaindropp has been a member for 11 full yearsRaindropp has been a member for 11 full yearsRaindropp has been a member for 11 full yearsRaindropp has been a member for 11 full yearsRaindropp has been a member for 11 full yearsRaindropp has been a member for 11 full yearsRaindropp has been a member for 11 full yearsRaindropp has been a member for 11 full yearsRaindropp has been a member for 11 full years
Postby kidhauler » June 29th 2009, 10:25pm
i just did my alt on my 99 two weeks ago. There are only two bolts. The alt is kind of smushed in place. This post is identical to your 99. Once the bolts are loose pry on the side closest to the drivers side with a flat blade screw driver and it will slowly pop up. To put the new one in I had to tap on mine with a rubber mallet and a socket extension to squeeze it back into the mount. I found that this job takes about 30 min to line it all up and make sure you don't beat the heck out of it putting it in just tap it in. If you can move the front little spring clip things back as posted it would make life easier I just didn't see a way to move them when I did my alt.
Good luck.
Gone to happier grounds.
kidhauler
Years of Membership: kidhauler has been a member for 12 full yearskidhauler has been a member for 12 full yearskidhauler has been a member for 12 full yearskidhauler has been a member for 12 full yearskidhauler has been a member for 12 full yearskidhauler has been a member for 12 full yearskidhauler has been a member for 12 full yearskidhauler has been a member for 12 full yearskidhauler has been a member for 12 full yearskidhauler has been a member for 12 full yearskidhauler has been a member for 12 full yearskidhauler has been a member for 12 full years
Postby Greg_gp1 » July 29th 2009, 1:47am
I just replaced the Alternator on my 1994 Safari 4.3 L High Output engine option.
There is a third mounting bolt, found at the rear left of the alternator, approx 1/2 way down. It is a 10 mm bolt. Access to the bolt is limited at the rear, I ended up removing the engine cover so a friend could help from that side to get the bolt re-aligned and back in. Removing the engine cover also gave me more confidence about what I was doing at the rear of the alternator. I ended up moving the upper oil dipstick channel out of the way, to make it easier to use a 10 mm short socket and ratchet instead of a wrench to get the bolt back on. (Only move the upper oil dipstick channel if you have removed the engine cover, since the channel comes apart in the middle, and you will need access to re-insert the top of the oil dispstick channel into the bottom)
Another pointer, test the threads in your replacement alternator before trying to re-install. One of the threads on mine needed to get re-threaded for the bolt to actually screw into it.
I noticed some posts suggesting one should remove the belt tensioner inorder to get the alternator out. Certainly for my model and year Van, this was absolutely not required.
If your doing a 94 Safari, and need more confidence building info, email me, and I'll send you a detailed set of steps I followed, along with some supporting photos.
[email protected]
Greg_gp1
Years of Membership: Greg_gp1 has been a member for 11 full yearsGreg_gp1 has been a member for 11 full yearsGreg_gp1 has been a member for 11 full yearsGreg_gp1 has been a member for 11 full yearsGreg_gp1 has been a member for 11 full yearsGreg_gp1 has been a member for 11 full yearsGreg_gp1 has been a member for 11 full yearsGreg_gp1 has been a member for 11 full yearsGreg_gp1 has been a member for 11 full yearsGreg_gp1 has been a member for 11 full yearsGreg_gp1 has been a member for 11 full years
Alias (AKA): Greg_gp1
Extra Info: XT 4.3L V6 RWD
Postby gillbates » July 29th 2009, 2:05am
On my 97 the fan shroud is easy to remove and gives you a lot more room to work in there. Most of them are split (top/bottom) so you really only remove the top. There's two rubber pads that sit between the radiator edges and the shroud. Make sure you put those back when you put the shroud back on. I've removed it twice to replace the alternator and once to replace the tensioner. Piece of cake and the front of the engine magically appears once it's off.
gillbates
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: gillbates has been a member for 12 full yearsgillbates has been a member for 12 full yearsgillbates has been a member for 12 full yearsgillbates has been a member for 12 full yearsgillbates has been a member for 12 full yearsgillbates has been a member for 12 full yearsgillbates has been a member for 12 full yearsgillbates has been a member for 12 full yearsgillbates has been a member for 12 full yearsgillbates has been a member for 12 full yearsgillbates has been a member for 12 full yearsgillbates has been a member for 12 full years
Topics: 7
Alias (AKA): Gill Bates
Extra Info: rwd
Postby Bryce77 » September 8th 2009, 5:47pm
currently have my cousins 96 astrovan followed all these instructions but mine too has a back bolt and I'm wondering how to get the damn thing out I don't have a 10mm wrench!!! socket fits but can't move the damn thing!!!! please help!!!!!!!!!!!!!!!!!!!!! :feedback:
Bryce77
Years of Membership: Bryce77 has been a member for 10 full yearsBryce77 has been a member for 10 full yearsBryce77 has been a member for 10 full yearsBryce77 has been a member for 10 full yearsBryce77 has been a member for 10 full yearsBryce77 has been a member for 10 full yearsBryce77 has been a member for 10 full yearsBryce77 has been a member for 10 full yearsBryce77 has been a member for 10 full yearsBryce77 has been a member for 10 full years
Postby fungus2k » September 10th 2009, 11:31am
just make sure you don't pull too hard forward on the alternator once its loose to remove the power cable, I did this and shredded the sensor cable that attaches to the backside of the alternator added an extra day of trouble shooting for doing that in the middle of January, not fun
fungus2k
Years of Membership: fungus2k has been a member for 12 full yearsfungus2k has been a member for 12 full yearsfungus2k has been a member for 12 full yearsfungus2k has been a member for 12 full yearsfungus2k has been a member for 12 full yearsfungus2k has been a member for 12 full yearsfungus2k has been a member for 12 full yearsfungus2k has been a member for 12 full yearsfungus2k has been a member for 12 full yearsfungus2k has been a member for 12 full yearsfungus2k has been a member for 12 full yearsfungus2k has been a member for 12 full years
Postby red98tj » October 7th 2009, 3:07pm
Just replaced mine last weekend. Was not very hard at all, thanks to this post. only trouble was finessing the new alternator into place. Got a 160 amp unit that puts out 105 amps at idle from DB electric for around $180 shipped to me in 3 days.
Vehicles:
2005 Chevy Avalanchesold
2000 Chevy Astro AWDsold
2003 Chrysler T&C AWD
2003 GMC Yukon XL 2500 Quadrasteer
2007 Chrysler Pacifica awd
2012 Keystone Outback 312bh
red98tj
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: red98tj has been a member for 11 full yearsred98tj has been a member for 11 full yearsred98tj has been a member for 11 full yearsred98tj has been a member for 11 full yearsred98tj has been a member for 11 full yearsred98tj has been a member for 11 full yearsred98tj has been a member for 11 full yearsred98tj has been a member for 11 full yearsred98tj has been a member for 11 full yearsred98tj has been a member for 11 full yearsred98tj has been a member for 11 full years
Topics: 10
Alias (AKA): kevin
Extra Info: LT AWD
Postby tommckay » October 24th 2009, 1:16am
Looks like I may be following these instructions soon. Since I bought my Van the amp gauge has been reading at or a touch below 14 volts, today on the way home it dropped to below what would be 12 volts with lights, wipers, defrost, & radio going. I was only a mile from home when I noticed, so I shut the lights, wipers, and blower down. The volts returned to about 12-13 volts. Not good.
Why do the Alternators have to be so pricey?
Why do it if it ain't fun?
95 Astro Cargo (for winter and RC hauling)
90 Honda Goldwing (Ridden as much as possible)
07 Kia Rondo (Wife's car)
tommckay
Years of Membership: tommckay has been a member for 10 full yearstommckay has been a member for 10 full yearstommckay has been a member for 10 full yearstommckay has been a member for 10 full yearstommckay has been a member for 10 full yearstommckay has been a member for 10 full yearstommckay has been a member for 10 full yearstommckay has been a member for 10 full yearstommckay has been a member for 10 full yearstommckay has been a member for 10 full years
Topics: 19
Extra Info: 4.3 RWD Cargo
Postby JayDubya » April 21st 2010, 6:20am
kidhauler wrote: ... If you can move the front little spring clip things back as posted it would make life easier I just didn't see a way to move them when I did my alt. .
In Duck Hunter's first pic, You can see how he moved them out forward. He inserted a bolt with a flat washer from the rear, then put a large, oversize spacer (looks like a lug nut) on the front side, then a flat & a nut. A few turns of the nut and they should be well out of the way.
'99 Astro Mark III conversion hack job
JayDubya
Fueling (3/4 tank)
Fueling (3/4 tank)
Years of Membership: JayDubya has been a member for 10 full yearsJayDubya has been a member for 10 full yearsJayDubya has been a member for 10 full yearsJayDubya has been a member for 10 full yearsJayDubya has been a member for 10 full yearsJayDubya has been a member for 10 full yearsJayDubya has been a member for 10 full yearsJayDubya has been a member for 10 full yearsJayDubya has been a member for 10 full yearsJayDubya has been a member for 10 full years
Extra Info: RWD Hightop conv
Postby brilamb2 » June 8th 2010, 7:11am
one good piece of advice is for anybody who can go to a junkyard is to possibly pick up an alt off a 03 or 04 full size truck, the ad244 style puts out about 100 amps at idle, and up to 170 at full tilt. only diffrence is you hve to change out to a tad biit longer belt, either a 96 or 96.8
brilamb2
Years of Membership: brilamb2 has been a member for 10 full yearsbrilamb2 has been a member for 10 full yearsbrilamb2 has been a member for 10 full yearsbrilamb2 has been a member for 10 full yearsbrilamb2 has been a member for 10 full yearsbrilamb2 has been a member for 10 full yearsbrilamb2 has been a member for 10 full yearsbrilamb2 has been a member for 10 full yearsbrilamb2 has been a member for 10 full yearsbrilamb2 has been a member for 10 full years
Alias (AKA): brilamb2
Extra Info: base awd 4.3
Postby astroturf » June 8th 2010, 1:37pm
brilamb2 wrote:one good piece of advice is for anybody who can go to a junkyard is to possibly pick up an alt off a 03 or 04 full size truck, the ad244 style puts out about 100 amps at idle, and up to 170 at full tilt. only diffrence is you hve to change out to a tad biit longer belt, either a 96 or 96.8
Great Info Bri... Thanks a lot. Jim
astroturf
Years of Membership: astroturf has been a member for 10 full yearsastroturf has been a member for 10 full yearsastroturf has been a member for 10 full yearsastroturf has been a member for 10 full yearsastroturf has been a member for 10 full yearsastroturf has been a member for 10 full yearsastroturf has been a member for 10 full yearsastroturf has been a member for 10 full yearsastroturf has been a member for 10 full yearsastroturf has been a member for 10 full years
Topics: 112
Extra Info: 2wd Passenger
Postby brilamb2 » July 13th 2010, 11:55am
update........
the 96 in belt is the one we need. 96.8 is just barely too long for the ad244
brilamb2
Postby yotaman88210 » October 4th 2010, 8:21pm
Gonna tackle this tonight on my 95 astro. Got the hook up from a friend at a parts store. 125 for a brand new 105amp Ultima. Lifetime warranty... we shall see how it holds ups.
I was driving to work this morning and the volt meter in the dash started jumping ariound and then went down to 12ish and the batt light came on and I could hear the nator saying EFFF YOOUU!! :screaming:
Welp, hope its just the nator... Hopefully it goes smooth....
yotaman88210
Years of Membership: yotaman88210 has been a member for 11 full yearsyotaman88210 has been a member for 11 full yearsyotaman88210 has been a member for 11 full yearsyotaman88210 has been a member for 11 full yearsyotaman88210 has been a member for 11 full yearsyotaman88210 has been a member for 11 full yearsyotaman88210 has been a member for 11 full yearsyotaman88210 has been a member for 11 full yearsyotaman88210 has been a member for 11 full yearsyotaman88210 has been a member for 11 full yearsyotaman88210 has been a member for 11 full years
It is currently August 9th 2020, 6:36am
Attached by: kittenflaps
kittenflaps
Comments: 18
Date: Aug 07 '20
Time: 12:46am
Sailing_Faith
Comments: 9
Date: Aug 06 '20
Time: 4:48pm
Attached by: bowtie262
bowtie262
Date: Aug 02 '20
Time: 8:41pm
Attached by: markmitch
Comments: 40
Date: Aug 01 '20
Time: 10:43pm
Attached by: Wokka
Wokka
Date: Aug 01 '20
Time: 11:13am
