battery lite stays on
Postby felcan [OP] » May 2nd 2011, 1:30am
On my 1990 van with the digital dash the battery icon flashes ever so often this started after I had Altenator replaced ....it reads 13+ volts but still flashes any ideas as why this is happening .........also have lost my cruise control ....no light on dash nothing when button is pushed .....check fuse ......is good ...am wondering if it is a vacumm line ....but thought the cruise icon would be visible just not work ....any ideas....thanks
felcan
Years of Membership: felcan has been a member for 10 full yearsfelcan has been a member for 10 full yearsfelcan has been a member for 10 full yearsfelcan has been a member for 10 full yearsfelcan has been a member for 10 full yearsfelcan has been a member for 10 full yearsfelcan has been a member for 10 full yearsfelcan has been a member for 10 full yearsfelcan has been a member for 10 full yearsfelcan has been a member for 10 full years
Topics: 9
Alias (AKA): t
Van Model Year: 1990
Extra Info: Gt.4.3 v6 2wd
  • Mounting Aux battery where rear heater would go...
    by Sailing_Faith » June 17th 2020, 4:42am in Electrical
    June 17th 2020, 2:47pm
  • Battery tray
    by donbenny1915 » July 8th 2020, 5:16am in Electrical
    July 8th 2020, 2:28pm
    28
    December 2nd 2020, 1:45pm
Re: battery lite stays on
Postby redfury » May 2nd 2011, 1:51am
You should be getting 14.5v out of the alternator. I would make sure the connection is physically good at the alternator, and also clean the battery connections...a poor ground will cause all sorts of these kinds of troubles.
redfury
Firing on 8 Cylinders (L3)
Topics: 53
Images: 13
Extra Info: LT 5.7L 4wd
Postby throrope » May 2nd 2011, 5:38am
2x on the ground. Also, in addition to vacuum, a chain linkage may pull the throttle for cruise control. Years ago after a service, Mr. Good-wrench forgot to re-connect the linkage. I probably would have spent less time connecting it than I did schlepping it back to them.
Hope this helps, good luck and keep us posted.
throrope
Years of Membership: throrope has been a member for 9 full yearsthrorope has been a member for 9 full yearsthrorope has been a member for 9 full yearsthrorope has been a member for 9 full yearsthrorope has been a member for 9 full yearsthrorope has been a member for 9 full yearsthrorope has been a member for 9 full yearsthrorope has been a member for 9 full yearsthrorope has been a member for 9 full years
Extra Info: LT 4.3L AWD
Postby RECox286 » May 2nd 2011, 11:41pm
Edit: delete, Sorry
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby felcan [OP] » June 11th 2011, 12:19am
Have checked all the vacumm lines ...still no cruise control.....put new battery in ......no difference ...battery light still flashes once in awhile.....now going to double check ground (s) ....any idea where they might all be....1990 safari.....thanks
felcan
Topics: 9
Alias (AKA): t
It is currently December 2nd 2020, 1:45pm
Dbleeger
Comments: 14
Date: Nov 27 '20
Time: 11:29pm
tungtide
Date: Nov 23 '20
Time: 4:40pm
Comments: 24
Date: Nov 20 '20
Time: 8:18am
Date: Nov 20 '20
Time: 1:16am
Date: Nov 19 '20
Time: 8:00pm
