98 Astro Daytime Running Lights Wiring Diagram
Postby thor124 [OP] » May 24th 2011, 9:38pm
Hi Guys,
I'm fighting with my daytime running lights on my 98 Astro. Can anyone post a wiring diagram for this year? I'm 99% sure its the DRL Diode that GM so helpfully hid behind the drivers side door pillar, but I'd like to checkout the rest of the circuit before I rip apart my interior to get to the diode (is there a short cut to that? or was GM really helpful enough to put a expendable part in a PITA to get to location?). The circuit shown in my Chilton manual is WAY off. I dug threw a bunch of old posts here and there were a few dead links to the schematic.
Thanks in advance!
thor124
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: thor124 has been a member for 9 full yearsthor124 has been a member for 9 full yearsthor124 has been a member for 9 full yearsthor124 has been a member for 9 full yearsthor124 has been a member for 9 full yearsthor124 has been a member for 9 full yearsthor124 has been a member for 9 full yearsthor124 has been a member for 9 full yearsthor124 has been a member for 9 full years
Topics: 9
  • Turning off Daytime Running Lights
    by Mr.P » August 2nd 2020, 6:13pm in Electrical
    Last post by Mr.P View the latest post
    August 7th 2020, 5:30am
  • Day time running light indicator suddenly on
    by JodiSouza » July 7th 2020, 11:31am in Electrical
    Last post by JodiSouza View the latest post
    July 9th 2020, 2:12pm
    7
    16
    September 18th 2020, 3:12pm
Re: 98 Astro Daytime Running Lights Wiring Diagram
Postby Leeann_93 » May 24th 2011, 10:59pm
It's easier to get to than you think. Open the driver's door, undo the one screw on the L-shaped part of the panel that wraps into the driver's door area. Feed the seatbelt through the slots to free it and disconnect the wiring connector to the courtesy light. Now open the slider and pull off the panel that the cupholder and bin are in - it's held on by metal clips.
The 'diode' is on the right, on the pillar with a heatsink attached (follow the yellow/orange wires behind the white/orange wires to the courtesy light):
Postby Leeann_93 » May 24th 2011, 11:03pm
And the '99 Headlight/DRL wiring
Postby Phantom » May 24th 2011, 11:15pm
I had noticed that Leann could post pics , so I thought I'd try to post the Headlight wiring and see if it would work,
It still will not let me post a .pdf file diagram :(
this is the error message
"Could not upload attachment to ./files/5306_4d2523a587b5dee5de26435bb07c0f22."
How is it that in just a few minutes it gets broken?
Phantom
Firing on 7 Cylinders (L4)
Postby Leeann_93 » May 25th 2011, 12:10am
I didn't - I linked to photos on Photobucket.
Postby thor124 [OP] » May 25th 2011, 12:40am
Thanks guys! Looks like the diode is only required to dim the drls. Screw replacing it, I'll just bypass it and run with full brightness drls.
thor124
Fueling (5/8 tank)
Fueling (5/8 tank)
Topics: 9
Postby thor124 [OP] » May 25th 2011, 2:15am
Sucess. Removed daytime running light diode. Jumpered out the connector and the DRL's came on, although at full low beam brightness. Should pass safety. I'll post a pic of my workaround in a bit.
thor124
Fueling (5/8 tank)
Fueling (5/8 tank)
Topics: 9
Postby Leeann_93 » May 25th 2011, 2:21am
Good!
It is currently September 18th 2020, 3:12pm
Date: Sep 16 '20
Time: 1:08am
Attached by: WinnieVan
WinnieVan
Date: Aug 28 '20
Time: 10:45pm
Date: Aug 27 '20
Time: 9:51pm
thenextdon13
Date: Aug 28 '20
Time: 3:09am
AstroOafAdventurerAstroOafAdventurer is online!
Comments: 18
Date: Aug 26 '20
Time: 4:00pm
