changed starter,now alternator doesnt charge.
Postby Johnnysparx [OP] » May 25th 2017, 4:17pm
i changed my starter in a parking lot during a rainstorm laying in a puddle.they never seem to go bad on nice days. now the battery light is on and alternator isnt charging the battery. did i do something wrong? any advise?
Johnnysparx
Years of Membership: Johnnysparx has been a member for 5 full yearsJohnnysparx has been a member for 5 full yearsJohnnysparx has been a member for 5 full yearsJohnnysparx has been a member for 5 full yearsJohnnysparx has been a member for 5 full years
Extra Info: LT AWD
  • no alt charge and engine idles only
    by Astro plain jane » August 31st 2020, 9:15pm in Electrical
    Last post by Astro plain jane View the latest post
  • Question about the starter
    by bradaskins » June 1st 2020, 7:43pm in Electrical
    Last post by Astrofarian View the latest post
    June 2nd 2020, 2:00pm
    7
    34
    October 26th 2020, 2:07am
Re: changed starter,now alternator doesnt charge.
Postby 97cargocrawler » May 25th 2017, 4:25pm
You can start by checking continuity between the alternator + bolt and the battery + terminal. The fuse-able link might be toast.
97cargocrawler
Topics: 42
Alias (AKA): KING OF OVERKILL
Postby Johnnysparx [OP] » May 25th 2017, 4:48pm
my meter shows 1.4 megohm resistance.good? no good?
Johnnysparx
Extra Info: LT AWD
Postby TurnNburn » May 25th 2017, 4:55pm
very not good... seems like you found your problem. If properly installed, expect to see less then 1 ohm. Ideally less then .5 ohms.
If all connectors and wires were new and installed correctly, resistance should be around .1 ohms.
TurnNburn
Green Status (L4)
Green Status (L4)
Alias (AKA): iGoogle
Postby Johnnysparx [OP] » May 25th 2017, 5:49pm
so i need to run a new wire? where is this fuseable link?
Johnnysparx
Extra Info: LT AWD
Postby AstroWill » May 25th 2017, 9:27pm
Johnnysparx wrote:so i need to run a new wire? where is this fuseable link?
At the starter end of the wire leading to the alternator.
Topics: 106
Images: 438
It is currently October 26th 2020, 2:07am
Date: Oct 24 '20
Time: 3:02pm
donbenny1915
Date: Oct 23 '20
Time: 1:44am
nwisehart
Date: Oct 21 '20
Time: 12:44am
Olivier02
Date: Oct 11 '20
Time: 8:34pm
Date: Oct 10 '20
Time: 5:08pm
Users browsing this forum: Google [Bot], vangogovangogo is online! and 12 guests
