I have a 2001 GMC Safari van that would not start and all indications pointed to the neutral safety switch. I purchased a new switch and installed it and the van started and idled until it reached operating temperature. I headed out and only made it about 1 mile away when the van shut off and would not restart.
The shift light indicator does not display what gear the van is in and I know that it will not start unless the computer reads that the van is in Park.
I started to wiggle the shifter and the ignition switch as well. To see if it's possibly an ignition issue. I noticed that while playing with both the ignition and the shifter that every so often the indicator would jump between gears.
I replaced the ignition switch still the same issue. When the ignition switch is in position1 it will illuminate the gear but not until I am in reverse. When in position2 in illuminates nothing.
EXAMPLE: ignition switch in position1 van in park. when shifting out of park and into reverse slowly, halfway there P lights up and immediately shows R. when shifted back into Park it shows nothing..
Anyone have any idea whats going on here?
Thanks
