Hi all,
Have an interesting issue. I have an '02. When I turn the key to the start position, all electrical appears fine, but the engine doesn't crank. If I hold the key to the start position, about 5 seconds later the engine will start without issues. Some days it will be 2 seconds, some days virtually instant, and other days it can take up to 10 seconds.
It was taking up to 30 seconds some day, so I brought it to a garage and they replaced the ignician switch which they said was burnt out. This helped for a week, although it still never started instantly, it would take about 1 second to crank the start. Since then it feels like it takes a little longer each day, but again, sometimes it will take longer than others.
What's odd is it doesn't crank slow, once it cranks it starts immediately.
Does this sound like a starter issue? Bad wiring? What could possibly cause a "delay" in the starter cranking?
Any thoughts would be appreciated.
Adrian
