ODB1 trouble codes.. need help!
Postby Bassistofbodines [OP] » July 15th 2011, 4:56am
I was driving my van home today when I noticed the brake light started flashing. It flashes 8 times then holds on the 9th flash... Any idea what this means? And what I have to do to make it stop? thanks a lot!
-Joe
Bassistofbodines
Years of Membership: Bassistofbodines has been a member for 9 full yearsBassistofbodines has been a member for 9 full yearsBassistofbodines has been a member for 9 full yearsBassistofbodines has been a member for 9 full yearsBassistofbodines has been a member for 9 full yearsBassistofbodines has been a member for 9 full yearsBassistofbodines has been a member for 9 full yearsBassistofbodines has been a member for 9 full yearsBassistofbodines has been a member for 9 full years
Alias (AKA): Joe Flair
Extra Info: 4.3L Automatic
Re: ODB1 trouble codes.. need help!
Postby Phantom » July 15th 2011, 1:38pm
How are your brakes working ? as this is usually an indicator that something has gone wrong with the braking system ,,,,,proportioning valve damage or some other malfunction , if it be OBD related a code will be stored in the memory ,
Phantom
Firing on 7 Cylinders (L4)
Postby paintdrying » July 15th 2011, 1:41pm
I had that exact same thing happen to the brakes on my 1988 silverado. It was traced back to a false alarm. People on the forums told me it was the switch under the pedal
paintdrying
Topics: 94
Extra Info: 108 000
Postby Bassistofbodines [OP] » July 15th 2011, 8:31pm
brakes seem fine, just a little mushy, need bled. but other than that fine
Bassistofbodines
Postby throrope » July 21st 2011, 4:54am
Bassistofbodines wrote:brakes seem fine, just a little mushy, need bled. but other than that fine
Should never be mushy.
I like changing out calipers at 100K whether I think they need to or not. Calipers frequently cycle between cold and hot and I treat them as maintenance items. Rebuilt units are cheap and mine came with lifetime guarantee from Advanced Auto. I also replaced the hydro boost unit with one bought online for $136 free shipping. In every case, I didn't notice the degradation until after the new stuff.
I had my brake light come on and found the parking brake lever didn't fully return. A shot of WD40 fixed that.
Beyond that, I suggest you chase down any and all codes and correct if only to eliminate possibilities. Jumping two of the OBD1 contacts will flash stored codes via the SES light and charts are easy to find on line. Car accidents are much more costly and painful.
Good luck and keep us posted.
throrope
Years of Membership: throrope has been a member for 10 full yearsthrorope has been a member for 10 full yearsthrorope has been a member for 10 full yearsthrorope has been a member for 10 full yearsthrorope has been a member for 10 full yearsthrorope has been a member for 10 full yearsthrorope has been a member for 10 full yearsthrorope has been a member for 10 full yearsthrorope has been a member for 10 full yearsthrorope has been a member for 10 full years
Extra Info: LT 4.3L AWD
It is currently March 1st 2021, 1:24pm
OldSchoolNoe
Comments: 0
Date: Today
Time: 12:53am
tungtide
Date: Feb 23 '21
Time: 1:54am
Rockridge
Date: Feb 20 '21
Time: 1:28am
Coronavan
Date: Feb 17 '21
Time: 7:21pm
Attached by: Primusblack
Primusblack
Comments: 21
Date: Feb 17 '21
Time: 4:26am
