Alternator Model(nsfw)
Postby Positive P [OP] » July 24th 2011, 3:32pm
Looking for a tip on where to look for the info on what model alternator I have on my stock '90 Astro.
I know it's Delco, but I'm needing a model # and can't seem to locate that info.
Thanks In Advance!
Positive P
Years of Membership: Positive P has been a member for 11 full yearsPositive P has been a member for 11 full yearsPositive P has been a member for 11 full yearsPositive P has been a member for 11 full yearsPositive P has been a member for 11 full yearsPositive P has been a member for 11 full yearsPositive P has been a member for 11 full yearsPositive P has been a member for 11 full yearsPositive P has been a member for 11 full yearsPositive P has been a member for 11 full yearsPositive P has been a member for 11 full years
Topics: 47
Alias (AKA): The Tongue-Fu Master
Van Model Year: 1990
Extra Info: 4.3L
  • Good High End Alternator?
    July 4th 2020, 2:16am
  • alternator questions
    by markmitch » July 6th 2020, 6:22pm in Electrical
    July 7th 2020, 11:30pm
    October 22nd 2020, 7:13am
Re: Alternator Model(nsfw)
Postby Phantom » July 24th 2011, 3:51pm
Enter your VIN in this link and scroll down and look at the generator , it will give some info
there is a code like "K68" , K60 , LU2 , ......
It varies depending on what accessories came on it from factory , some had more and had a higher output alternator
http://www.compnine.com/vid.php?vin=1gndm19w5xb126525
Phantom
Firing on 7 Cylinders (L4)
Postby JaxSPL » July 27th 2011, 4:32am
CS-130D usually, I think. I've never ran into a later model van (like ours) with a different factory alternator
"Installer's Nightmare" has officially come to life. Only 1 sub, but loud and clear.
Subwoofer enclosure designer. PM For More Info
JaxSPL
Firing on 8 Cylinders (L1)
Years of Membership: JaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full years
Topics: 45
Images: 9
Extra Info: 4.3L V6 SPL
Postby Positive P [OP] » July 28th 2011, 3:15am
JaxSPL wrote:CS-130D usually, I think. I've never ran into a later model van (like ours) with a different factory alternator
I discovered that from '87-'90 Astro/Safari used the CS-130.
I found a complete 220 amp rebuild kit for these alternators for $104.00 plus tax
Positive P
Topics: 47
Extra Info: 4.3L
Postby 'cudapaul » July 28th 2011, 3:32am
If you want more "real" amps, go look at the Tahoe and Suburban CS-144 alternators.
They will fit the location and give you more legitimate power.
http://www.alternatorparts.com/cs130-cs130d-series-alternators.htm
'cudapaul
Years of Membership: 'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years
Alias (AKA): 'cudapaul
Extra Info: LT AWD
It is currently October 22nd 2020, 7:13am
nwisehart
Time: 12:44am
Olivier02
Date: Oct 11 '20
Time: 8:34pm
Date: Oct 10 '20
Time: 5:08pm
Date: Oct 10 '20
Time: 4:52pm
Maddog
Date: Oct 09 '20
Time: 4:08pm
