Running wires into slider door for Actuator
Postby hardnock [OP] » September 9th 2017, 6:03pm
Hello all,
I am installing actuators into my '02 Chevy Cargo Astro and need some ideas on how to correctly run wiring into the slider door.
If anyone would be so kind as to post some pictures of existing wiring harnesses into the slider I would greatly appreciate it.
Thanks and God Bless!
hardnock
Years of Membership: hardnock has been a member for 3 full yearshardnock has been a member for 3 full yearshardnock has been a member for 3 full years
Van Model Year: 2002
Extra Info: Cargo Van RWD
  • Wires everywhere
    by GungaAgunga » May 7th 2020, 6:04pm in Electrical
    May 9th 2020, 5:34am
  • Day time running light indicator suddenly on
    by JodiSouza » July 7th 2020, 11:31am in Electrical
    Last post by JodiSouza View the latest post
    July 9th 2020, 2:12pm
    7
    52
    October 28th 2020, 6:29pm
Re: Running wires into slider door for Actuator
Postby AstroWill » September 9th 2017, 7:28pm
hardnock wrote:I am installing actuators into my '02 Chevy Cargo Astro and need some ideas on how to correctly run wiring into the slider door.
There is a 2 pin spring loaded contact at the front of the sliding door, it only makes contact when you close the door. Would probably benefit you to swing by your local junk yard, not sure if they are available to buy new.
Could check chevypartsprime.com
Welcome to the site!
Topics: 106
Images: 440
Postby Don1806 » September 9th 2017, 8:47pm
If you can't find one on a junk van, aftermarket are available from various manufacturers. https://www.amazon.com/uxcell-Vehicles-Central-Locking-Sliding/dp/B00AKWPWE2
99 Astro LT - Orginal Owner.
Don1806
Years of Membership: Don1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full years
Topics: 18
Images: 2
Alias (AKA): Don
Extra Info: AWD 170K
Postby hardnock [OP] » September 10th 2017, 4:45am
Thanks so much for the confirmation. My friend and I figured it out when looking at the door tonight and you guys confirmed it. Thanks so much for the help. This community is great!
hardnock
It is currently October 28th 2020, 6:29pm
Time: 4:29am
Date: Oct 24 '20
Time: 3:02pm
donbenny1915
Date: Oct 23 '20
Time: 1:44am
nwisehart
Date: Oct 21 '20
Time: 12:44am
Olivier02
Date: Oct 11 '20
Time: 8:34pm
