Connection ID Help Needed...Please
Postby chargedbird [OP] » August 16th 2011, 2:18am
Howday all,
I have a 1996 Astro Van Vin "W" and I found this connector located by the AC/Heat Fan, in the engine compartment, its a 2 wire connector, Gray/White and Black. I have looked all around this area for the plug but I can seem to find anything. Here is pic of the connector. Any and all information will be greatly appreciated.
Cheers~~~
unknown connector
chargedbird
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: chargedbird has been a member for 9 full yearschargedbird has been a member for 9 full yearschargedbird has been a member for 9 full yearschargedbird has been a member for 9 full yearschargedbird has been a member for 9 full yearschargedbird has been a member for 9 full yearschargedbird has been a member for 9 full yearschargedbird has been a member for 9 full yearschargedbird has been a member for 9 full years
Extra Info: RWD
  • rear door plug ID?
    by markmitchmarkmitch is online! » May 11th 2020, 2:02am in Electrical
    May 14th 2020, 12:25am
  • Help! Voltage drain with new everything! 1998 astro
    by CoffeeBee » June 18th 2020, 12:46am in Electrical
    Last post by rootbeer99 View the latest post
    July 16th 2020, 4:12am
    32
    October 29th 2020, 2:14am
Re: Connection ID Help Needed...Please
Postby chevymaher » August 16th 2011, 2:42am
Look at the bottom of the water bottle for the windshield washer motor.It is almost identical.It is a unused dead circuit.If your van had been chosen to be a safari it would be on the water bottle motor and the one on it now would be dead.All these vans have an extra like that.
Postby redfury » August 16th 2011, 3:03am
sure it's not the wiring for the rear heat solenoid located behind the accumulator?
redfury
Firing on 8 Cylinders (L3)
Topics: 53
Images: 13
Extra Info: LT 5.7L 4wd
Postby chargedbird [OP] » August 16th 2011, 3:43pm
Thanks Chevymaher and redfury....
I will check out this evening...the windshield washer does work...and I don't have a rear heater, I have only the rear AC. but let me verify and I will get back to you both...
thanks~~~
chargedbird
Fueling (1/2 tank)
Fueling (1/2 tank)
Extra Info: RWD
Postby redfury » August 17th 2011, 5:23am
chargedbird wrote:Thanks Chevymaher and redfury....
thanks~~~
Well, I think one of us is right, it's a dead end connection for an option your van doesn't have. If it's for the washer, it's because you have double doors instead of dutch doors.
redfury
Topics: 53
Images: 13
It is currently October 29th 2020, 2:14am
Leeann_93Leeann_93 is online!
Date: 34 minutes ago
Time: 1:40am
Date: Oct 27 '20
Time: 4:29am
Date: Oct 24 '20
Time: 3:02pm
donbenny1915
Date: Oct 23 '20
Time: 1:44am
nwisehart
Date: Oct 21 '20
Time: 12:44am
