Ground Locations - 2004
Postby WinnieVan [OP] » October 6th 2017, 11:59pm
I've tried finding this in the FSM but I cannot.
Does anyone have a complete list of engine/body/interior grounds and their locations?
I've seen them for other vehicles online but not the Astro.
I can find the wiring diagrams in the FSM but I can't find a list of where the grounds are connected.
Sent from my iPhone using Tapatalk
WinnieVan
Firing on 2 Cylinders (L3)
Years of Membership: WinnieVan has been a member for 3 full yearsWinnieVan has been a member for 3 full yearsWinnieVan has been a member for 3 full years
Topics: 62
Images: 27
Re: Ground Locations - 2004
Postby CopperFiremistCopperFiremist is online! » October 7th 2017, 1:36am
I sent them all to you in chat the other day! Did you not write them down?
Pullin The Pass
Firing on 1 Cylinder (L2)
Topics: 24
Images: 6
Alias (AKA): B
Extra Info: LS Swap
Postby WinnieVan [OP] » October 7th 2017, 3:44pm
CopperFiremist wrote:I sent them all to you in chat the other day! Did you not write them down?
Here they are -- I thought that list wasn't complete for some reason!
Is there any indication which of these are PCM grounds?
Ground Locations:
- Front of eng on Tstat housing
- Left side of firewall behind battery
- Radio grounds right side of dash
- Back of driver's side head
- left rear side of frame
- left rear eng
- LF radiator support
- lower right engine block
- right kick panel left kick
- upper half of right d pillar
- behind bottom of left b pillar
- upper half of left d pillar
- left rear of vehicle
- front of left rear wheel well
WinnieVan
Topics: 62
Images: 27
Postby WinnieVan [OP] » October 21st 2017, 4:38am
I'm assuming everything is facing the front of the vehicle so:
Left = Driver's side and Right = Passenger side?
WinnieVan
Topics: 62
Images: 27
Postby AstroWill » October 21st 2017, 6:04am
It's all in the GM Techline eSI, just saying :)
Images: 443
Postby WinnieVan [OP] » October 22nd 2017, 8:36pm
Thanks Will. I've looked but had a hard time finding the location of the grounds -- I find the ground schematics but nowhere that says: Ground 201 is located at X.
WinnieVan
Topics: 62
Images: 27
Postby WinnieVan [OP] » October 23rd 2017, 4:53am
Ok I think I found it finally. Stupid me. :doh:
For anyone else using the Techline eSI all the wiring information is under at:
Body --> Wiring Systems --> Component Locator --> Master Electrical Component List
Body --> Wiring Systems --> Schematic and Routing Diagrams
WinnieVan
Topics: 62
Images: 27
Postby AstroWill » October 23rd 2017, 7:49am
That's the place ;) Glad you found it, takes a little while to get used to the way they organized everything in there.
Images: 443
Postby WinnieVan [OP] » October 23rd 2017, 8:25am
AstroWill wrote:That's the place ;) Glad you found it, takes a little while to get used to the way they organized everything in there.
Yea -- not that intuitive when even searching "wiring" doesn't pull it up. Even "ground" doesn't get you that far.
It's weird to categorize wiring under body IMO -- it should probably just be its own category!
WinnieVan
Topics: 62
Images: 27
Postby dramey » October 23rd 2017, 8:45pm
That is a holdover from when GM had the bodies made by Fisher Body. You had 2 different wiring diagrams. The engine wiring diagram would be in the car repair manual and the chassis wiring digram would be in the Fisher Body manual.
dramey
Firing on 7 Cylinders (L1)
Extra Info: AWD Cargo Van
Postby WinnieVan [OP] » October 23rd 2017, 9:17pm
Ahh... that makes a lot of sense Dramey.
WinnieVan
Topics: 62
Images: 27
It is currently November 27th 2020, 6:40pm
tungtide
Date: Nov 23 '20
Time: 4:40pm
Comments: 24
Date: Nov 20 '20
Time: 8:18am
sixsixsixsix is online!
Date: Nov 20 '20
Time: 1:16am
Date: Nov 19 '20
Time: 8:00pm
Date: Nov 19 '20
Time: 7:31pm
cron
