2002 Astro Battery Tray 15020343 Options
Postby Raleigh [OP] » December 3rd 2017, 11:28pm
I replaced my battery today with the ACDelco AGM78 (fantastic battery, btw, at $181), and of course I took the old battery out and the tray is rusted out so bad it's gone, just the pieces around the bolts are still hanging on. So I've found that 15020343 is the correct replacement part, but it's like $90-135 while there are tons of other trays out there for like $16. Are there other options that people have tried for this? If I need to shell out $100, fine, but thought it would be worth checking to see if others have had success with other parts or creative options. Thanks!
RALEIGH, Grand Rapids, MI
-2002 Chevrolet Astro LS AWD 4.3 - April 2016-Current
-1993 Jeep Cherokee 4x4 4.0HO - 2014-2016 (Sold)
-1997 Jeep Cherokee 4x4 4.0 - 2012-2014 (Sold)
-1989 Volvo 740 Sedan 16v - Died
-1994 Volvo 850 Sedan 5cyl - Died
Raleigh
Years of Membership: Raleigh has been a member for 4 full yearsRaleigh has been a member for 4 full yearsRaleigh has been a member for 4 full yearsRaleigh has been a member for 4 full years
Topics: 7
Images: 13
Van Model Year: 2002
Extra Info: LS 4.3L AWD
  • Battery tray
    by donbenny1915 » July 8th 2020, 5:16am in Electrical
    July 8th 2020, 2:28pm
  • Mounting Aux battery where rear heater would go...
    by Sailing_Faith » June 17th 2020, 4:42am in Electrical
    June 17th 2020, 2:47pm
    59
    December 1st 2020, 4:08pm
Re: 2002 Astro Battery Tray 15020343 Options
Postby Rinny » December 3rd 2017, 11:45pm
get one from a JY sand blast it and POR it. Better than new
03Astro AWD/4WD
TorsenDiffs,3:73'S,VettServo
NP236TC
Dual Piston Rear Calipers
GY DTrac 235/85/R16
ARB &/Custom bumpers
2x6x1/4 Rockrails
Rinny
Years of Membership: Rinny has been a member for 4 full yearsRinny has been a member for 4 full yearsRinny has been a member for 4 full yearsRinny has been a member for 4 full years
Topics: 56
Images: 6
Extra Info: 5.7L NP236
Postby markmitch » December 4th 2017, 2:53am
I agree
Firing on 6 Cylinders (L6)
Topics: 615
Images: 20
Extra Info: RS V8
Postby MI_Ghost » December 4th 2017, 4:02am
And find an old rubber mudflap to cut out a liner to place under the battery. This will stop electrical flow through the tray.
~Ghost
Ast' Cargo: 2001 Astro Cargo
Beauty: 2009 Impala LT
MI_Ghost
Images: 107
Alias (AKA): Ghost
Van Model Year: 2001
Extra Info: Big White RWD Box
Postby 1lowcab » December 4th 2017, 4:15am
That ^^^
And that ^^^
1lowcab
Firing on 8 Cylinders (L3)
Topics: 58
Images: 165
Postby sfeaver » December 5th 2017, 4:06am
The factory tray is probably obsolete or close to it, thats why its so expensive now. A few years back it was only 15 bucks. It also has the mount for the PCM. If the cheaper one you found is the same, then go for it. Otherwise a junkyard one and clean it up is the way to go.
sfeaver
Firing on 8 Cylinders (L1)
Topics: 29
Images: 21
Extra Info: LT RWD 350ci V8
Postby RECox286 » December 5th 2017, 10:30pm
Once, when I needed to replace a tray, the plate part of the assy was toast, so, I just fabricated a new plate out of
3/16" mild steel, and made the one leg, where the cable goes thru, into a three piece bolt together affair. Saved
having to take the cable apart getting the tray out and then back into position. Wasn't really that difficult to do.
If you're not set up to fabricate, I can see that my easy job would become more of a stinker to do.
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby jdemaris » December 12th 2017, 3:29am
I needed a new battery tray for my 2002 Astro. I found plenty for late 90s Astros that were cheap. Easy fit into my 2002. Only difference is the 2002 tray has two channels for the plastic computer mount to slide into. I just drilled two holes and bolted the bracket to the older style tray and it worked fine.
jdemaris
Years of Membership: jdemaris has been a member for 2 full yearsjdemaris has been a member for 2 full years
Topics: 5
Alias (AKA): John
Postby AstroWill » December 12th 2017, 3:43pm
jdemaris wrote:I needed a new battery tray for my 2002 Astro. I found plenty for late 90s Astros that were cheap. Easy fit into my 2002. Only difference is the 2002 tray has two channels for the plastic computer mount to slide into. I just drilled two holes and bolted the bracket to the older style tray and it worked fine.
Making it work, I like that, thanks for the tip!
Images: 443
Postby TheLAD » October 28th 2018, 4:00am
where did you find cheap battery trays for 90's astros? I need one for my '96.
TheLAD
Years of Membership: TheLAD has been a member for 12 full yearsTheLAD has been a member for 12 full yearsTheLAD has been a member for 12 full yearsTheLAD has been a member for 12 full yearsTheLAD has been a member for 12 full yearsTheLAD has been a member for 12 full yearsTheLAD has been a member for 12 full yearsTheLAD has been a member for 12 full yearsTheLAD has been a member for 12 full yearsTheLAD has been a member for 12 full yearsTheLAD has been a member for 12 full yearsTheLAD has been a member for 12 full years
Topics: 5
It is currently December 1st 2020, 4:08pm
Dbleeger
Comments: 14
Date: Nov 27 '20
Time: 11:29pm
tungtide
Date: Nov 23 '20
Time: 4:40pm
Comments: 24
Date: Nov 20 '20
Time: 8:18am
Date: Nov 20 '20
Time: 1:16am
Date: Nov 19 '20
Time: 8:00pm
