Electric door locks and dutch door
Postby mrosspa [OP] » September 25th 2011, 5:43am
I'm going to try to make sense of this and not make it convoluted.
1. Rear hatch won't open. Initially I thought it was solely mechanical, but when I insert the key and turn the lock, it neither locks or unlocks the door.
2. When you press the electric door lock control on either the driver or passenger side, the door locks don't respond. They neither lock or unlock the door.
3. When you place the car in drive, the doors lock. When you place the car in park, the doors unlock.
4. I also noticed the front cigarette lighter socket stopped working, while the connections for power on the passenger side of the console works.
I was reading that the dome light is on the same circuit, but my dome light still works.
Any suggestions are greatly appreciated
Michael
2005 AWD Astro
mrosspa
Years of Membership: mrosspa has been a member for 12 full yearsmrosspa has been a member for 12 full yearsmrosspa has been a member for 12 full yearsmrosspa has been a member for 12 full yearsmrosspa has been a member for 12 full yearsmrosspa has been a member for 12 full yearsmrosspa has been a member for 12 full yearsmrosspa has been a member for 12 full yearsmrosspa has been a member for 12 full yearsmrosspa has been a member for 12 full yearsmrosspa has been a member for 12 full yearsmrosspa has been a member for 12 full years
Topics: 12
  • Dutch Door keylock location, because I'm curious.
    by augidog » July 11th 2020, 5:07pm in Electrical
    Last post by augidog View the latest post
    July 14th 2020, 6:27pm
  • Another Dutch door button issue
    by Wokka » August 1st 2020, 10:36am in Electrical
    Last post by Wokka View the latest post
    August 2nd 2020, 7:20am
    76
    October 20th 2020, 12:48pm
Re: Electric door locks and dutch door
Postby mrosspa [OP] » September 25th 2011, 6:12am
I looked on the old site, and found this.
More specifically, if you find that the rear latch button, the interior automatic door lock switches, AND the cigarette lighter on the center console do not work:
Check the cigarette lighter 20 amp fuse.
If this fuse burns out, all three of these items will not work.
Buzzerooni
'99 Safari
I'll check this in the daylight.
Michael
mrosspa
Topics: 12
Postby mrosspa [OP] » September 25th 2011, 7:42am
It was the fuse. I've a 24hr Walmart, and I just replaced it.
Life is good.
The old list still has great information.
Michael
mrosspa
Topics: 12
Postby Jasen » September 25th 2011, 8:30am
Nothin like a post where to poster helps them selves :lol:
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
Postby CougarsLS » September 27th 2011, 3:51pm
I had the same problem with my door lock. After reading your post problem solved. Thanks for posing your results. Cougar
CougarsLS
Years of Membership: CougarsLS has been a member for 9 full yearsCougarsLS has been a member for 9 full yearsCougarsLS has been a member for 9 full yearsCougarsLS has been a member for 9 full yearsCougarsLS has been a member for 9 full yearsCougarsLS has been a member for 9 full yearsCougarsLS has been a member for 9 full yearsCougarsLS has been a member for 9 full yearsCougarsLS has been a member for 9 full years
Topics: 18
Extra Info: LS
It is currently October 20th 2020, 12:48pm
Olivier02
Date: Oct 11 '20
Time: 8:34pm
Date: Oct 10 '20
Time: 5:08pm
Date: Oct 10 '20
Time: 4:52pm
Maddog
Date: Oct 09 '20
Time: 4:08pm
Maddog
Date: Oct 08 '20
Time: 8:19pm
