Where's the best place 2 run positive cable for Dual battery
Postby webcat [OP] » October 16th 2011, 2:30pm
webcat
Firing on 3 Cylinders (L3)
Topics: 253
Alias (AKA): Larry aka Rambo
Extra Info: g10 5.7L vortec
  • Chasis shorted to positive
    by solardude » October 11th 2020, 11:53pm in Electrical
    October 13th 2020, 1:36pm
  • Dual battery w/isolator w/remote start?
    by AstroOafAdventurer » August 13th 2020, 4:36pm in Electrical
    Last post by AstroOafAdventurer View the latest post
    December 16th 2020, 11:10pm
    9
    13
    January 23rd 2021, 7:44am
Re: Where's the best place 2 run positive cable for Dual bat
Postby Lumpy » October 16th 2011, 3:30pm
Where's your battery(s)?
What's your setup?
Just a tiny bit more information?
Postby webcat [OP] » October 16th 2011, 4:24pm
I have two 6 volt golf cart batterys wired in series to make a 12 volt battery , the batterys set in a vented box at the very rear of the van on the drivers side ,, my starting battery is under the hood but is on the passenger side because i have a Express van ,,, i was wondering how you guys route your positive cable through the engine compartment , once you get past the engine compartment it seems pretty easy to find a good place to run the cable the rest of the way back but there doesn't seem to be any where good to run it in the engine compartment
webcat
Topics: 253
Postby Phantom » October 16th 2011, 8:27pm
Here is a pic of the GM factory auxiliary battery cable ,,item number 4 positive cable and is 149 inches long item number 14 is ground cable and is 18 inches long
part number is ,,I believe
GM 12157149
You may already have it and not know it , or you can add it :D
G10 battery cable.png (30.68 KiB) Viewed 2003 times
Phantom
Firing on 7 Cylinders (L4)
Postby Jasen » October 16th 2011, 10:06pm
That's my thinking, either run it along the back of the cross member or take it all the way up and run it along the bottom of the rad core support.
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
Postby webcat [OP] » October 17th 2011, 1:00am
Wow , that's a nice picture Phantom , Thanks
webcat
Topics: 253
Postby Lumpy » October 17th 2011, 2:39pm
I'm not familiar with what it looks like under an Express Van hood. But in my 89 Astro,
there's a convenient couple of pipes/hoses running from the passenger side eng compartment,
down and across the back of the engine, above the transmission, that are the supply and
return lines to the rear heater core. I have disconnected my rear heater but the lines are
still in place. I have more than one set of cables and wires for various things zip tied to
those pipes to get from rear to front of the van.
But it seems like getting out of the eng compartment is the simplest part of the journey.
Perhaps Express vans are more cluttered in that area than Astros.
Got pics, Webcat?
Postby JaxSPL » October 20th 2011, 3:38am
I ran my 4/0 down to the frame, somewhat like #4 at the top of that picture Phantom linked. It runs to just in front of the wheel well where I drilled a hole. I used a electrical box conduit connector to pass the 4/0 through the floorboard of the van. This allows me to place my battery bank anywhere in the rear of the van, from the wheel well to the rear doors.
When I start on my new build, the subwoofer wall will actually enclose the battery bank, and vent to the rear of the van. This will help keep the van level and provide a clean look.
"Installer's Nightmare" has officially come to life. Only 1 sub, but loud and clear.
Subwoofer enclosure designer. PM For More Info
JaxSPL
Firing on 8 Cylinders (L1)
Years of Membership: JaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full years
Topics: 45
Images: 9
Extra Info: 4.3L V6 SPL
Postby webcat [OP] » October 21st 2011, 6:50am
Lumpy wrote:I'm not familiar with what it looks like under an Express Van hood. But in my 89 Astro,
Got pics, Webcat?
When you first mentioned this i had a thought in my head that you ran it inside the hose which would be really cool , i think i'm gonna try to run mine like yours and tie it to the heater hose , Iv'e been meaning to post pictures but i have to take some , I'll put it on my to do list LOL
webcat
Topics: 253
Postby webcat [OP] » October 24th 2011, 5:33am
Lumpy , i put the pictures in my Gallery ( folder titled battery box
Its still under construction ,The LED light wiring is a little bit of a mess because I'm currently working on them , i need to clean up my wiring , all the black wood is going to be covered with Formica ,,
bottom battery switch is going to be replaced with a remote controlled switch.
All of my electronics except my alarm get there poewer from between them 2 battery switches , if top switch is closed the electronics get power from rear battery , i normally leave the top switch closed and then close the bottom switch whenever i want to charge rear batterys
pic 1 Back door of van , the white thing is a toilet paper holder to feed propane LOL
pic 2 green Propex Propane heater in battery box
pic 5 new LED lights , the center light rack is going to be removed
, Still working on the sunroof
pic 6 amp for laptop or mp3 player
http://www.google.com/url?q=http://www. ... QQgwgwAzgA
webcat
Topics: 253
Postby Lumpy » October 24th 2011, 2:40pm
webcat wrote:
Lumpy , i put the pictures in my Gallery...
I sure don't see them.
How about simply post them here in the forum? I'd bet lots of
people would like to see 'em.
Postby webcat [OP] » October 24th 2011, 6:27pm
webcat
Topics: 253
Postby T.Neff » October 25th 2011, 4:01pm
I measured the length and how wide a normal battery is and found(believe it or don't) that you can fit two batteries in the original location by building a battery tray to hold them length wise front to back of the van and by tucking the outside battery slightly under the fender.They fit and that makes wiring them much easier.Most battery trays are rotted out anyways,so while replacing them might as well do this conversion welding some angle iron for trays.
T.Neff
Years of Membership: T.Neff has been a member for 9 full yearsT.Neff has been a member for 9 full yearsT.Neff has been a member for 9 full yearsT.Neff has been a member for 9 full yearsT.Neff has been a member for 9 full yearsT.Neff has been a member for 9 full yearsT.Neff has been a member for 9 full yearsT.Neff has been a member for 9 full yearsT.Neff has been a member for 9 full years
Topics: 21
Postby Bread Van » October 27th 2011, 8:42pm
T.Neff is this two batteries under the hood setup something you did in an Astro? or an Express van (the OP's vehicle)
I'd like to install a house battery at some point but would prefer to have both under the hood, if possible.
I've also thought about buying the biggest damn battery I can fit in the stock location and just putting a protector/alarm on it so I know when I'm running near the minimum voltage to start. I'm not familiar w/ these, but pretty sure I read about them somewhere.
Bread Van
Years of Membership: Bread Van has been a member for 10 full yearsBread Van has been a member for 10 full yearsBread Van has been a member for 10 full yearsBread Van has been a member for 10 full yearsBread Van has been a member for 10 full yearsBread Van has been a member for 10 full yearsBread Van has been a member for 10 full yearsBread Van has been a member for 10 full yearsBread Van has been a member for 10 full yearsBread Van has been a member for 10 full years
Topics: 36
Alias (AKA): mapper
Extra Info: AWD 2 inch lift
It is currently January 23rd 2021, 7:44am
OldSchoolNoe
Date: Jan 19 '21
Time: 2:15am
OldSchoolNoe
Date: Jan 16 '21
Time: 9:23pm
Comments: 9
Date: Jan 15 '21
Time: 5:08am
Attached by: markmitch
Date: Jan 04 '21
Time: 6:15pm
doogaloo
Date: Jan 04 '21
Time: 11:53am
Users browsing this forum: AstrojohnAstrojohn is online! and 14 guests
