Brake lights, parking lights on at same time.
Postby 1990moonbeam [OP] » March 14th 2018, 3:15am
Hey guys, i have a problem with my lights in my van. when i press my brakes the left parking light turns on as well as the turn indicator in the gauge cluster. when i turn on the parking lights the right one turns on but the left one does too but its dim, i flip the turn signal switch and its fine but both indicators are on. same problems with the headlights. but the headlights are fine, its just the the parking lights and the tail lamps. when i make a left turn the light stays on, but when i turn right it goes at a normal pace or it goes quick sometimes. Can it be a bad ground, bad bulb or a switch?
90' Astro CL AWD 4.3L 241K Restoring: 55%
96' Beretta Z26 3100 85K
1990moonbeam
Years of Membership: 1990moonbeam has been a member for 5 full years1990moonbeam has been a member for 5 full years1990moonbeam has been a member for 5 full years1990moonbeam has been a member for 5 full years1990moonbeam has been a member for 5 full years
Van Model Year: 1990
Extra Info: AWD CL 4.3L V6
Re: Brake lights, parking lights on at same time.
Postby Astrofarian » March 14th 2018, 3:23am
Start with the easiest to check; bad bulb.
-M!ke-
Astrofarian
Alias (AKA): M!ke
Extra Info: Someday......
Postby chevymaher » March 14th 2018, 8:42am
Take the brake light bulbs out and clean the factory grease out of the sockets. It has gummed up and turned to the nasty.
Postby vwghiarob » March 14th 2018, 1:56pm
Weak grounds can do some strange things!
vwghiarob
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: vwghiarob has been a member for 8 full yearsvwghiarob has been a member for 8 full yearsvwghiarob has been a member for 8 full yearsvwghiarob has been a member for 8 full yearsvwghiarob has been a member for 8 full yearsvwghiarob has been a member for 8 full yearsvwghiarob has been a member for 8 full yearsvwghiarob has been a member for 8 full years
Topics: 9
Images: 8
Extra Info: passenger AWD
Postby 1990moonbeam [OP] » March 16th 2018, 1:18am
yep it was the bulbs, i was gearing up for a electrical war. went to auto zone, got some bulbs for it. cleaned the sockets and works like a charm. i thought that it was a bad ground of some sorts. Thank you to all. have a good day!
1990moonbeam
It is currently February 28th 2021, 11:06pm
tungtide
Date: Feb 23 '21
Time: 1:54am
Rockridge
Date: Feb 20 '21
Time: 1:28am
Coronavan
Date: Feb 17 '21
Time: 7:21pm
Attached by: Primusblack
Primusblack
Comments: 21
Date: Feb 17 '21
Time: 4:26am
OldSchoolNoe
Comments: 9
Date: Feb 13 '21
Time: 11:56pm
Users browsing this forum: No registered users and 21 guests
