Best place for battery cable
Postby Black89cs [OP] » November 18th 2011, 2:20pm
So I'm putting a small subwoofer setup in the van which will require running a cable from the battery to the rear. I've drilled a small hole for the tach wire for my remote start, however I don't think I can drill a larger hole beside it for the AWG4 battery cable without causing issues with the doghouse. What's a good spot to either fish through or drill and grommet a hole for this cable?
Black89cs
Firing on 8 Cylinders (L1)
Years of Membership: Black89cs has been a member for 12 full yearsBlack89cs has been a member for 12 full yearsBlack89cs has been a member for 12 full yearsBlack89cs has been a member for 12 full yearsBlack89cs has been a member for 12 full yearsBlack89cs has been a member for 12 full yearsBlack89cs has been a member for 12 full yearsBlack89cs has been a member for 12 full yearsBlack89cs has been a member for 12 full yearsBlack89cs has been a member for 12 full yearsBlack89cs has been a member for 12 full yearsBlack89cs has been a member for 12 full years
Topics: 81
Re: Best place for battery cable
Postby Jasen » November 18th 2011, 6:21pm
This is where I ran mine. It did come up just in front of the wheel well, but I've sense moved it to come up in front of the fuel neck.
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
Postby Black89cs [OP] » November 18th 2011, 6:24pm
Hmm.. that looks doable, maybe exit by the filler neck bump then run it the rest of the way back. The only thing is the box and wire must be able to sit all the way in the back or be put between the front seats. The ground will be relocatable of course, but the battery cable should be somewhat mobile.
Black89cs
Topics: 81
Postby Jasen » November 18th 2011, 6:35pm
You can ground it anywhere, a nice big screw to the floor will be fine with bare metal contact. Both my amps are grounded to one of the bolts that hold my security partition to the floor.
Take the wire back to the wheel well, them inside and go over the wheel well to the back or maybe theres a good place to run it all the way under the van, that will offer it some protection.
200k
Ultra gauge
Topics: 260
Images: 101
Postby Shad0wXCalibur » November 18th 2011, 9:41pm
Interesting... I just ran my subwoofer power cable through the firewall then underneath the plastic panels. I covered the power wire in wire loom at the firewall so it doesn't chafe and short out.
1987 Astro
2000 Safari
Shad0wXCalibur
Years of Membership: Shad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full years
Topics: 41
Extra Info: Lifted 2wd
Postby Jasen » November 18th 2011, 9:51pm
I didn't have room to run my 4ga under the door sill, got 3 RCA's going back and 2 sets of speaker wire going back up. It's pretty full under there :lol:
200k
Ultra gauge
Topics: 260
Images: 101
Postby Shad0wXCalibur » November 18th 2011, 10:07pm
That is pretty thick. Mine's only like 10ga . Amp is only 200 watts RMS. I have that and another 10ga wire (aux reverse lights) on the driver's side trim and the RCA cables and amp trigger wire on the passenger side trim.
1987 Astro
2000 Safari
Shad0wXCalibur
Topics: 41
Postby Jasen » November 18th 2011, 10:15pm
Shad0wXCalibur wrote:That is pretty thick.
Hey!!! I resemble that remark :twisted:
200k
Ultra gauge
Topics: 260
Images: 101
Postby toddb » November 18th 2011, 10:53pm
A word of caution. I HIGHLEY RECOMMEND THAT YOU FUSE THAT WIRE (at the battery). if it ever shorts out you will lose your van.
1997 Safari 2WD 3:73 locking. 300,000 km - almost full load.
2000 Safari AWD 3:73 locking. 275,000 km - Full load.
toddb
Years of Membership: toddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full years
Postby Black89cs [OP] » November 20th 2011, 2:55am
toddb wrote:A word of caution. I HIGHLEY RECOMMEND THAT YOU FUSE THAT WIRE (at the battery). if it ever shorts out you will lose your van.
Absolutely. It's fused right out at the battery. I'll have to get pics of how I did it but I found a flat spot by the shifter cable that was clear on both sides so I drilled there. It's hidden on the inside and doesn't look too bad on the outside. I can tell these kits aren't really made for vans, since the RCA's barely reached the back, let alone the amp, so I had to finesse it a little bit to make it work. The battery cable wasn't as bad and I found a decent spot for the ground. I'm going to go back and solder the connections though, the ring terminals didn't clamp down on the wires all that great and I've already got a dodgy connection.
Black89cs
Topics: 81
Postby toddb » November 21st 2011, 3:35am
CAN'T BEAT KLIENS, they make the best crimpers.
toddb
Postby Big_kid » November 21st 2011, 4:09am
I've never owned a real pair of Kliens, I have one or two knockoffs. I LOVE my Thomas & Betts though.
Firing on 7 Cylinders (L7)
Topics: 185
Images: 337
Extra Info: 2WD 5.7 V8
Postby Jasen » November 21st 2011, 6:12am
I've got an old *** set of the cheap die cut crimp pliers that I put some better grips on from something else. They have the little nodes in the crimp jaw like the Kliens and other good ones. You wanna see a man tare apart the house when he's got some crimp connectors to put on and can't find his pliers.
Oh, and I do love my Klien tin snips.
200k
Ultra gauge
Topics: 260
Images: 101
It is currently January 23rd 2021, 8:57am
OldSchoolNoe
Date: Jan 19 '21
Time: 2:15am
OldSchoolNoe
Date: Jan 16 '21
Time: 9:23pm
Comments: 9
Date: Jan 15 '21
Time: 5:08am
Attached by: markmitch
Date: Jan 04 '21
Time: 6:15pm
doogaloo
Date: Jan 04 '21
Time: 11:53am
