HELP!!! Severed wires
Postby ralphstudders [OP] » May 2nd 2018, 4:53am
Howdy all,
I am in the process of camperizing an '02 astro.
after installing and removing and installing a plywood subfloor several times I began to experience failure with the mechanisms of the rear door.
1. key fob would no longer lock/ unlock rear swing hatch (dutch doors).
2. rear swing hatch would not lock at all
3. swing hatch lock actuator (i think) stopped working (rear swing hatch will not open without manually moving release mechanism)
4.power locks stopped working in general.
after problem 3 occurred I started looking at all of my wiring and found that I had severed a couple of wires that lead to a white (fuse?) box that is attached the the wall behind the rear passenger side wheel well.
I used butt joints to rejoin the wires in hope to fix the issue but it did not work. I have looked in the fuse boxes underneath the hood and beneath the steering wheel and there seem to be no fuses that are blown. I pried open the white box to which the wires connect but all seems to be alright in there as well.
This is the only damage to the wiring (that I can find).
Does any one have any insight as how to proceed.
Thanks all.
R.S.
ralphstudders
Years of Membership: ralphstudders has been a member for 2 full yearsralphstudders has been a member for 2 full years
Images: 2
Van Model Year: 2002
Re: HELP!!! Severed wires
Postby WimpTech » May 2nd 2018, 5:14am
That would be the rear door lock relay. What about that lonely green wire that doesn't appear to go anywhere?
WimpTech
Firing on 4 Cylinders (L5)
Topics: 38
Images: 322
Alias (AKA): =Wimpy=
Extra Info: AWD 3+1 Lift
Postby WinnieVan » May 2nd 2018, 5:38am
Wimpazz wrote:That would be the rear door lock relay. What about that lonely green wire that doesn't appear to go anywhere?
It is in there Wimp. It's just hiding behind the other wires.
Based on my schematic, it should be the 25A PWR ACCY CIRCUIT BREAKER in the instrument panel box... I've never seen it... but it is there...
Otherwise, it is a mystery to me. If all those wires are in the right places it should work. Even if you broke that relay, I think the other power door locks would work.
WinnieVan
Firing on 3 Cylinders (L3)
Years of Membership: WinnieVan has been a member for 4 full yearsWinnieVan has been a member for 4 full yearsWinnieVan has been a member for 4 full yearsWinnieVan has been a member for 4 full years
Topics: 63
Images: 27
Postby ralphstudders [OP] » May 2nd 2018, 5:53am
Thanks for responding to the SOS
I'll recheck my fuses in the am. Is there a box I am missing somewhere in the van?
Is there a chance I need to order another relay?
Appreciate the knowledge gentlemen
ralphstudders
Images: 2
Postby WinnieVan » May 2nd 2018, 6:12am
Not a problem man. Only fuse boxes I know of are under the dash and under the hood.
I doubt you busted the relay.. because even if you did I think the other door locks would work.
Check this thread too...
viewtopic.php?p=120816
PS: if you right click on Leeann's schematics in that thread and select "open in new tab" you'll be able to see those VERY nice schematics.
WinnieVan
Topics: 63
Images: 27
Postby dchan51360 » May 2nd 2018, 6:44am
If you actually shorted some of those wires to each other or grounded them it is possible that the module that drives that relay has been damaged. You mention power locks not working. Is this using the switches on the doors if you have them? or is it just a keyfob issue. There is a module way up under the dash for people that have remote door locks that is the receiver for the keyfobs. This is what drives that relay and the power locks.
DC
dchan51360
Firing on 7 Cylinders (L1)
Postby ralphstudders [OP] » May 3rd 2018, 3:40am
Sure as snot, blown fuse.
The cig lighter fuse (13 under the dash) had popped.
After replacing it the rear hatch once again opens, locks both from the keyfob and the door switch, and power lock switches on both front doors are firing.
Thanks for the advice gentle men.
ralphstudders
Images: 2
Postby The Drummer » May 3rd 2018, 3:54am
As i worked on the van i left the gate open under rain ,then all hell broke lose with door locks , the button key switch for the the gate/hatch had failed , there s a small curcuit inside of it with a few contacts , i replaced it and boom all fixed , it happend again to me couple years later , replaced it again and it fixed it , that may have nothing to do with your problem but just in case..... :shrug:
''USE THE TORQUE LUKE ''
and beware of trees ,them nasty wooden things are evil .
The Drummer
Years of Membership: The Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full years
Topics: 16
Images: 42
Extra Info: SLT 4.3 AWD
Postby WinnieVan » May 3rd 2018, 5:50am
ralphstudders wrote:Sure as snot, blown fuse.
Good deal. Glad you’re back in business.
Sent from my iPhone using Tapatalk
WinnieVan
Topics: 63
Images: 27
It is currently March 3rd 2021, 3:32pm
OldSchoolNoe
Comments: 0
Date: Mar 01 '21
Time: 12:53am
tungtide
Date: Feb 23 '21
Time: 1:54am
Rockridge
Date: Feb 20 '21
Time: 1:28am
Coronavan
Date: Feb 17 '21
Time: 7:21pm
Attached by: Primusblack
Primusblack
Comments: 21
Date: Feb 17 '21
Time: 4:26am
