low oil pressure after distributor install
Postby frozenice [OP] » May 17th 2018, 7:48pm
I recently did a full tune-up including plugs, wires, coil, cap, rotor and distributor trying to chase down an intermittent rough or no- start condition. After the distributor swap my oil pressure has dropped considerably. On cold start I am around 60lbs, cruising on the highway warm I am at 40lbs, but at hot idle I am dipping down below 20lbs. Before the swap, hot idle was closer to 40lbs. (I know about the 10 lbs/1000rpm rule, but the drop in pressure is what I can't quite figure out) I did swap out the sending unit, oil and filter, but got no change in pressure. Is there a chance the re-man distributor shaft is a little short and not driving the oil pump? Wouldn't I just have no pressure at all? I unfortunately used the old distributor as a core so it is not here to measure against. Van is running fine otherwise w/210k on the clock.
I have searched the site and found a couple similar threads but no resolution has been posted.
Thanks for your time.
frozenice
Years of Membership: frozenice has been a member for 2 full yearsfrozenice has been a member for 2 full years
Van Model Year: 2002
Extra Info: awd
  • Distributor brand/from?
    by DriveDog » November 18th 2020, 10:33pm in Electrical
    Last post by DriveDog View the latest post
    December 9th 2020, 11:45pm
  • no low beams
    by Dorwink » October 24th 2020, 1:38am in Electrical
    October 28th 2020, 11:50pm
    7
    53
    February 28th 2021, 5:00am
Re: low oil pressure after distributor install
Postby AstroWill » May 17th 2018, 9:38pm
It's either going to be driving it or not. Maybe moving the wiring for the oil pressure sensor did something.
Images: 472
Postby DentManDave » January 11th 2020, 4:57pm
Did you replace the distributor with a cheaper parts store one? It may be the machining is off enough to allow oil to seep past it. Had a similar issue on a 5.7 in a gm truck.
DentManDave
Years of Membership: DentManDave has been a member for 4 full yearsDentManDave has been a member for 4 full yearsDentManDave has been a member for 4 full yearsDentManDave has been a member for 4 full years
Van Model Year: 2001
Postby Big_kid » January 12th 2020, 1:50am
If you have oil pressure at all, the pump is being driven.
There's the answer. If you have any doubts, put an actual mechanical gauge on it for a "real" reading. If you know the 10/1000 rule, you probably know what low oil pressure sounds and feels like.
A distributor would have to be WAY off to not engage the pump. If the diameter was off where it passed through the manifold, it might weep oil from crankcase pressure, but it wouldn't cause low oil pressure.
Firing on 7 Cylinders (L7)
Topics: 185
Images: 342
Extra Info: 2WD 5.7 V8
Postby Astro Pop » January 12th 2020, 8:17am
It's a long shot but is the new distributor seated all the way down? There's a screwdriver like slot in the bottom of the distributor and has to line up perfectly with the oil pump. If you're off a tooth you could be sitting a little high and only friction is driving the pump. I know... not likely, I'm just spitballin here.
Astro Pop
Topics: 41
Images: 9
Alias (AKA): Xfirepop
Van Model Year: 1996
Extra Info: AWD - 5 inch lift
Postby MechBob » January 16th 2020, 12:27am
LOL I see people responding to a 11/2 year old post. However, for future reference, the distributor on small blocks(well big blocks,also), block off an oil passage. If you got a low quality distributor, that the outer housing was machined undersized, you can have this problem. V8 guys have run into this quite a few times.
MechBob
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
It is currently February 28th 2021, 5:00am
tungtide
Date: Feb 23 '21
Time: 1:54am
Rockridge
Date: Feb 20 '21
Time: 1:28am
Coronavan
Date: Feb 17 '21
Time: 7:21pm
Attached by: Primusblack
Primusblack
Comments: 21
Date: Feb 17 '21
Time: 4:26am
OldSchoolNoe
Comments: 9
Date: Feb 13 '21
Time: 11:56pm
