Another Fuel Gauge Problem!
Postby GMCGUY [OP] » December 11th 2011, 7:19am
:confused: Sorry guys, I searched for an hour and couldn't find a definite answer on this issue. I have 2 Astros with erratic fuel gauges, they are both 2000 model year vans. The first one which I have owned for a year and a half, we'll call it #1, has 138,000 miles on it, suddenly the fuel gauge reads all over the place until it gets below about half tank and then seems somewhat accurate but I don't chance it and run by mileage and refill early, it seems that the gauge kinda follows the fuel level but its erratic above 1/2 tank. On to #2, just picked up this one for a buddy of mine, has 168,000 miles on it and the fuel gauge reads E sometimes and then I looked down its at about 3/4 and vibrating rapidly, the previous owner said when it gets below 1/2 tank it starts reading normal but his wife always refilled it then, he couldn't say how many gallons it took at that point. So both problems seem similar in the fact that they read somewhat accurately below 1/2 tank, what I want is real life experience answers, NOT GUESSES, meaning, if you have had one of these exact problems and fixed it tell me what you replaced or repaired that you are sure fixed it. I think these "Diagnosis of weird problem" posts have a tendency to turn into a "Just throw parts at it and spend $500 bucks...that's how I fixed it", post. I'm no stranger to using a volt/ohm meter, ASE Certified Tech here that just wants a good answer, or at least a trend of the same answer, when I go to fix it I promise I will tally up the "Sender" "Gauge Cluster" and "Wiring" answers and replace the highest numbered part with a nice write up and lots of pictures. Thanks A Ton! Make the first word of your post the part you replace that fixed it.
:feedback:
2000 GMC Safari AWD 127,000 Miles 1997 Chevy Astro AWD 233,000 Miles
GMCGUY
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: GMCGUY has been a member for 9 full yearsGMCGUY has been a member for 9 full yearsGMCGUY has been a member for 9 full yearsGMCGUY has been a member for 9 full yearsGMCGUY has been a member for 9 full yearsGMCGUY has been a member for 9 full yearsGMCGUY has been a member for 9 full yearsGMCGUY has been a member for 9 full yearsGMCGUY has been a member for 9 full years
  • Erratic Fuel Gauge
    by scanmanvt » July 16th 2020, 7:03pm in Electrical
    Last post by crittermo View the latest post
    July 28th 2020, 12:12am
  • New bulbs for my gauge cluster/dashboard?
    by JaseyT » April 7th 2020, 1:50am in Electrical
    Last post by JaseyT View the latest post
    April 8th 2020, 6:43pm
    9
    36
    August 12th 2020, 4:38am
Re: Another Fuel Gauge Problem!
Postby Phantom » December 11th 2011, 7:40am
GMCGUY wrote::confused: I'm no stranger to using a volt/ohm meter, ASE Certified Tech here
:feedback:
:nono: :rofl:
Phantom
Firing on 7 Cylinders (L4)
Postby Jasen » December 11th 2011, 8:42am
Many problems with modern vehicles aren't as simple as changing a light bulb you saw the element burn out in. This typically tends to be a ground issue.
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
Postby Lumpy » December 11th 2011, 1:42pm
GMCGUY wrote:
... real life experience answers, NOT GUESSES...
...ASE Certified Tech here that just wants a good answer...
...Make the first word of your post the part you replace that fixed it.
:feedback:
Were you looking for feedback on your mechanical problem?
Or feedback on your posting style?
Postby chevymaher » December 11th 2011, 3:13pm
Being a certified tech you know there is nothing ever that easy.I have never run into it to have to figure it out.So to avoid throwing throwing money at it to fix it like at work.You just gotta do like us seat of the pants Dyno,shadetree mech type like me do.Can't think of anything else nasty I been called.Take it completely apart and test everything.Personally I can't work in an atmosphere of a shop with all the arrogance and back biting.Been there done that.
Postby RECox286 » December 11th 2011, 4:55pm
I like your certification certificate. What is it for ?
Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby Black89cs » December 12th 2011, 12:16am
I'm not a mechanic but I'm sure not every single problem is exactly the same, however I can't effectively comment on the topic. GMCGUY, If you don't agree with the posting styles of this community then please keep your comments to yourself. Members are here to help each other, not troll the boards. Topic locked before it spirals out of control.
Black89cs
Firing on 8 Cylinders (L1)
Years of Membership: Black89cs has been a member for 11 full yearsBlack89cs has been a member for 11 full yearsBlack89cs has been a member for 11 full yearsBlack89cs has been a member for 11 full yearsBlack89cs has been a member for 11 full yearsBlack89cs has been a member for 11 full yearsBlack89cs has been a member for 11 full yearsBlack89cs has been a member for 11 full yearsBlack89cs has been a member for 11 full yearsBlack89cs has been a member for 11 full yearsBlack89cs has been a member for 11 full years
Topics: 81
It is currently August 12th 2020, 4:38am
Sailing_Faith
Comments: 17
Date: Aug 10 '20
Time: 2:17am
doogaloo
Comments: 17
Date: Aug 09 '20
Time: 8:52pm
Attached by: kittenflaps
kittenflaps
Comments: 18
Date: Aug 07 '20
Time: 12:46am
Sailing_Faith
Comments: 17
Date: Aug 06 '20
Time: 4:48pm
Attached by: bowtie262
bowtie262
Date: Aug 02 '20
Time: 8:41pm
Users browsing this forum: Google [Bot] and 7 guests
