Backup Signal under Dash
Postby jimi_lee [OP] » July 15th 2018, 5:05am
Can anybody help me locate a reverse signal under the dash? It seems stupid to have to run a wire from the tail lights up to the the dash when there is already a wire carrying that signal going the opposite direction.
Am I right to assume the wire is light green (the color of the reverse signal in the tow harness)?
There are 3-4 light green wires coming from the steering column. Would one of those be it?
jimi_lee
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: jimi_lee has been a member for 3 full yearsjimi_lee has been a member for 3 full yearsjimi_lee has been a member for 3 full years
Images: 117
Extra Info: Awd
  • another turn signal post
    by paulbot » January 21st 2021, 1:12am in Electrical
    Last post by paulbot View the latest post
    January 25th 2021, 1:20am
  • Ignition switched power source under hood
    by snailsafari » September 4th 2020, 10:45pm in Electrical
    Last post by Sailing_Faith View the latest post
    September 6th 2020, 6:12pm
    7
    94
    March 2nd 2021, 9:17pm
Re: Backup Signal under Dash
Postby Leeann_93 » July 15th 2018, 3:45pm
Postby jimi_lee [OP] » July 16th 2018, 4:58pm
Thanks to those who replied. Several others had posted the same question on this forum looking for a somewhere they could tap into to install a backup camera. There did not seem to be an answer other than "Just wire it back to the brake light/tow package."
Yesterday I poked around and found what I was looking for.
Here is a picture of the backup signal wire.
96280
It is right where Leeann's diagram shows it should be. The wire is light green. It is in a giant bundle of wires leaving the fuse box in the drivers foot well. I think it is the only light green wire in this cluster. In this photo I have already cut the wire and crimped on spade connectors (pink). Hope this is helpful.
jimi_lee
Fueling (7/8 tank)
Fueling (7/8 tank)
Images: 117
Extra Info: Awd
Postby chr_sei » July 16th 2018, 9:49pm
Thanks for figuring this out! This should be helpful for wireless cameras.
However if you buy a regular reverse camera most have the cable for the reverse signal with the camera cable which you have to run anyways. It was quite easy to fish the cable under the headliner in my case.
chr_sei
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: chr_sei has been a member for 2 full yearschr_sei has been a member for 2 full years
Alias (AKA): Chris
Extra Info: RWD
Postby jimi_lee [OP] » July 16th 2018, 10:24pm
chr_sei wrote:Thanks for figuring this out! This should be helpful for wireless cameras.
I am not sure that is how backup cameras are supposed to be set up. At least it wasn't for my head unit/camera.
My head unit, a Sony xav-ax100, connects to the camera by the composite video connection. The head unit has a separate wire, labelled "reverse", which tells the head unit to switch video inputs when the car is in reverse. The video input will switch back when the car is out of reverse. I can also go through the settings and manually change the video input to the back up camera when the car is not in reverse.
Wiring for the camera include 1) a positive lead, 2) a negative lead, and 3) a composite video connection. The positive goes to an accessory power cable (something that turns on when the car is on and off when the car is off) so that the camera is still on if I want to manually change the video input.
jimi_lee
Fueling (7/8 tank)
Fueling (7/8 tank)
Images: 117
Extra Info: Awd
Postby Leeann_93 » July 16th 2018, 10:32pm
Glad I could help.
Postby Andejo » September 13th 2020, 4:29pm
jimi_lee wrote:Thanks to those who replied. Several others had posted the same question on this forum looking for a somewhere they could tap into to install a backup camera. There did not seem to be an answer other than "Just wire it back to the brake light/tow package."
96280
Just stopping by to thank you for your 2018 post and photo. It helped me greatly.
Andejo
Extra Info: AWD passenger van
Postby Theslaking » January 15th 2021, 1:06am
Just bought a n Astro and trying to get the radio installed so I drive this thing around.
Jimi lee do you still have a picture of the reverse wire location?
Theslaking
Van Model Year: 2001
Extra Info: RWD
Postby SportsBoy » January 15th 2021, 3:49am
It's up above in this post....
SportsBoy
Topics: 23
Images: 23
Alias (AKA): Blake
Extra Info: 4.3 AWD
Postby AstroWill » January 15th 2021, 5:01am
Theslaking wrote:Jimi lee do you still have a picture of the reverse wire location?
jimi_lee wrote:Here is a picture of the backup signal wire.
96280
I will just throw these in here as well.
104012
104014
Images: 472
It is currently March 2nd 2021, 9:17pm
OldSchoolNoe
Comments: 0
Time: 12:53am
tungtide
Date: Feb 23 '21
Time: 1:54am
Rockridge
Date: Feb 20 '21
Time: 1:28am
Coronavan
Date: Feb 17 '21
Time: 7:21pm
Attached by: Primusblack
Primusblack
Comments: 21
Date: Feb 17 '21
Time: 4:26am
