Fuel pump blowing fuse on left turns 98 Safari.
Postby RCB [OP] » August 13th 2018, 2:30am
So, this is my third fuel pump in two weeks. So, I'm positive the pump is ok. I can drive fine for hours, but if I come to a stop and make a left turn it will sometimes blow the fuse. It's not every time but maybe every 10 or so left turns. However it only does it on left turns. Never right and never straight. I've been over the wires with an ohm meter and no shorts are showing up. I've looked over the wiring loom as far as I can with nothing visibly wrong. Has anyone encountered that? I'm really scratching my head. I would think this is a short that's making contact near suspension or steering but it doesn't look like the loom goes anywhere near it. This is a 98 Safari.
RCB
Years of Membership: RCB has been a member for 11 full yearsRCB has been a member for 11 full yearsRCB has been a member for 11 full yearsRCB has been a member for 11 full yearsRCB has been a member for 11 full yearsRCB has been a member for 11 full yearsRCB has been a member for 11 full yearsRCB has been a member for 11 full yearsRCB has been a member for 11 full yearsRCB has been a member for 11 full yearsRCB has been a member for 11 full years
Topics: 9
Alias (AKA): RC
Extra Info: 4.3 AWD
Re: Fuel pump blowing fuse on left turns 98 Safari.
Postby Zebediah III » August 13th 2018, 2:51am
Have you put 3 pumps in it? Was it due to failure during left turns? Were the fuses blowing? I'm confused. Have you tried with a full tank of gas? Or try with the van idling and on jacks or a couple people could rock it really hard to see if stalls. It could be a wire to wire short, it does not necessarily have to hit ground. It could also be something in the pump unit when it tilts too far. Need more info. Stalls on left turns is vague, but you can narrow it down. Especially if you know the fuse is blowing and the pump is ok. On some left turns, the van will raise up on the left side quite a bit, so try to re-create that extreme. Two people rocking it vigorously may make it stall. if not, start wiggling wiring.
Zebediah III
Images: 16
Extra Info: 383 Crate Motor
Postby AstroWill » August 13th 2018, 3:00am
You can isolate it at the fuel pump relay, disconnect and bypass the fuel pump relay and power the pump directly with a fused jumper wire. If it does blow, then it's on the pump side of the relay, if it doesn't, then it's on the relay side.
That will at least get you to which side of the harness it's happening at. I guess you could do the same thing at the fuel pump connector near the filter if you wanted to narrow it down some more.
Also, the GM Techline eSI will have all of the wiring/routing diagrams that you might need.
Images: 460
Postby RCB [OP] » August 13th 2018, 11:48am
Initially the pump was replaced two years ago. Then it blew a fuse and kept blowing fuses. So I replaced the fuel pump. Drove it for a week and then it started doing it again. I could idle but under any load it would blow the fuse. Then I discovered the fuel filter was basically clogged. So I replaced that. That didn't stop it from blowing fuses though so I thought I had already burned up the pump due to the clog. Replaced the pump again. Now with this one it drove fine but every now and again it will blow a fuse. Only on left turns.
Now to step back, for the past 6 months on left turns it had a tendency to stumble and hesitate. But it wouldn't blow fuses, but the gas gauge would drop out for a moment. This mainly happened on a left turn I have to make onto the highway uphill. Same for blowing fuses now.
With the pump disconnected I've moved the wire harness as far as I could by hand with power on as far forward as I could reach. No fuses blew. It seems to be a very vague problem.
RCB
Topics: 9
Alias (AKA): RC
Extra Info: 4.3 AWD
Postby AstroWill » August 13th 2018, 2:26pm
It's going to take work, the fuses are blowing for a reason. If there has ever been a higher amperage fuse installed, then all of the wiring along the entire circuit is suspect. Isolate the section of harness that is a problem, and then thoroughly inspect that section. Or don't isolate it and thoroughly inspect the entire circuit.
Just remember that some parts of that circuit go to different places(see wiring diagrams). For example to the PCM and the oil pressure switch, so the intermittent short to ground could be anywhere along that circuit.
Images: 460
Postby RCB [OP] » September 6th 2018, 11:26pm
Now it does it under load. Idles fine but under load (in drive) it blows the fuse. I'm selling it but until it's sold I'm tinkering. I can't imagine that an EGR could blow the fuse could it? Surely the fuel pump couldn't be bad again. The problem is it's intermittent. When I finally get it home I'm considering removing the whole harness. I shudder to think how difficult that will be on this van.
RCB
Topics: 9
Alias (AKA): RC
Extra Info: 4.3 AWD
Postby AstroWill » September 7th 2018, 2:48am
Good luck.
Images: 460
Postby RCB [OP] » September 7th 2018, 7:38pm
I'll need it, lol.
RCB
Topics: 9
Alias (AKA): RC
Extra Info: 4.3 AWD
Postby Mmusicman » September 8th 2018, 3:08pm
Just make right turns...
3 right turns = 1 left turn! Problem solved! :D
Option 2: Bypass the fuse and you'll "find" the short.
Just kidding... do not do this... ^^
Firing on 7 Cylinders (L5)
Topics: 73
Images: 49
Postby AstroWill » September 8th 2018, 10:57pm
Have you looked at the wiring diagrams yet so that you know everywhere that circuit goes?
Images: 460
Postby MechBob » September 12th 2018, 3:13am
Fuel pump is controlled by the ECM B fuse.If this is the one that is blowing,check your wiring at the oil pressure sender,as it is part of the fuel pump control.
MechBob
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
It is currently January 23rd 2021, 5:53pm
OldSchoolNoe
Date: Jan 19 '21
Time: 2:15am
OldSchoolNoe
Date: Jan 16 '21
Time: 9:23pm
Comments: 9
Date: Jan 15 '21
Time: 5:08am
Attached by: markmitch
Date: Jan 04 '21
Time: 6:15pm
doogaloo
Date: Jan 04 '21
Time: 11:53am
