This just started today when I turned the van on..... With switches off, the wipers both come on when ignition is turned to run.... I thought maybe the multifunction switch, but then realized the rear wiper wiring is on a separate circuit (pulling the wiper fuse does not deactivate the rear wiper).... Only place I can think of them being connected is at the washer, but I don't see anything amiss there.....
Also, the right turn signal indicator glows very softly when ignition is on, and when the switch is turned to right signal position, it blinks hypoerfast.... Left turn signal functions as normal....
Thoughts?
