Starts up, then a loud grind for a moment, as if the ignition had been turned twice.
-OR-
Rough start up, van shakes, warning lights go crazy for a moment, then settles down and idles normally.
As a novice, what I've read suggests replace the starter. Does that seem correct or is there anything else I should check as well?
https://www.rockauto.com/en/catalog/che ... motor,4152
What is the opinion on remanufactured vs new parts? My reading also suggests that I'd want to stick with ACDelco parts whenever possible?
